07-01-2010, 19:51 | #1 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 839882 Status: Offline Thanks Meter: 29 | W810i show Please wait Li is your w810i cid 49 Was encrypted and without an international Arab tried rebuked Remained open please wait RUNNING v 1.01/UNI CARD SERIAL 00086318 PLEASE UPGRADE USBFLASH DRIVER 02.01.00.00 CFG:000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35657401958129 CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35906100020285 Model (from GDFS):W810i MAPP CXC article: R4CE012 prgCXC1250320_VODAFONE_HN MAPP CXC version: R4CE012 Language Package: S_ASIA_LEVAN CDA article: CDA102555/110 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE NOT PRESENT "R4CE012_CXC1250320_VODAFONE_HN" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 12 secs. |
07-01-2010, 20:34 | #3 (permalink) | |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Quote:
07-01-2010, 20:38 | #5 (permalink) |
Member: 839882 Status: Offline Thanks Meter: 29 | Turned off the phone after the process this topic ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35657401958129 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDRB2010_RESPIN_ID_LOADER_SETOOL2 LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 897E FOUND VERSION "R4CE012_CXC1250320_VODAFONE_HN" can't open file "C:\Program Files\setool\v1.01\rest\R4CE012_CXC1250320_VODAFON E_HN" Setting up GDFS... can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS Unlock FAILED Elapsed: 120 secs. |
07-01-2010, 20:57 | #6 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
Detail in FAQ | |
The Following User Says Thank You to roney_nexus For This Useful Post: |
07-01-2010, 20:57 | #7 (permalink) |
No Life Poster Join Date: Dec 2008 Location: morocco
Member: 931360 Status: Offline Sonork: 100.1592533 Thanks Meter: 539 | try to repair gdfs go to empty fill & repair and add K810_GDFS_SSW.ssw in main firmware and press flash and add w810_erom_red49.ssw in main firmware and press flash |
The Following User Says Thank You to gsm.magic For This Useful Post: |
07-01-2010, 20:59 | #8 (permalink) |
Freak Poster Join Date: Aug 2008 Location: www.raraphone.com Age: 42
Member: 834709 Status: Offline Thanks Meter: 66 | you need rest file "R4CE012_CXC1250320_VODAFONE_HN" and paste to C:\Program Files\setool\v1.01\rest folder do unlock again goodluck |
The Following User Says Thank You to Kenthus For This Useful Post: |
07-01-2010, 21:22 | #9 (permalink) | |
Member: 839882 Status: Offline Thanks Meter: 29 | Quote:
Elapsed: 41 secs. CFG:000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35657401958129 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" STARTING BOOTLOADER... INT LDRB2010_RESPIN_ID_LOADER_SETOOL2 LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 897E FOUND VERSION "R4CE012_CXC1250320_VODAFONE_HN" can't open file "C:\Program Files\setool\v1.01\rest\R4CE012_CXC1250320_VODAFON E_HN" writing "C:\Program Files\setool\v1.01\gdfs_in_ssw_format\db2020\K810_ GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... writing "C:\Program Files\setool\v1.01\eroms\db2010\w810_erom_red49.ss w" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 4 Will flash 4 blocks... subblock 003 NAK, [44010000/00010000] Elapsed: 83 secs. | |
07-01-2010, 21:29 | #10 (permalink) | |
ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35657401958129 CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35170701616552 PROVIDER: MULTIPLE Network LOCKED USERCODE:6A91CD71000000000000FFFFFFFFFFFF RESTORATION FILE NOT PRESENT "35170701616552" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 6 secs. | |
07-01-2010, 21:45 | #11 (permalink) |
Member: 834709 Status: Offline Thanks Meter: 66 | if u have file w810 R4CE012_CXC1250320_VODAFONE_HN cry. open setool v1.01 go to tab.sonyericsson select phone type and do identify. if there show making restoration file finish. do unlock again |
07-02-2010, 12:12 | #12 (permalink) |
Member: 839882 Status: Offline Thanks Meter: 29 | ... Madrp for the inconvenience You have to return him Tflisch making it operate in dim SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35657401958129 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 FLASH ID: 897E writing "D:\stool\Nouveau dossier (2)\w810i\W810-CID-RED-49-R4CE012-VFE_LIVE_2-SETOOL\R4CE012_1250320_VODAFONE_HN.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 339 Will flash 339 blocks... writing "D:\stool\Nouveau dossier (2)\w810i\W810-CID-RED-49-R4CE012-VFE_LIVE_2-SETOOL\R4CE012_VFE_LIVE_2_fs.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 169 Will flash 169 blocks... LDR:070524 1030 AN2CXC1327364_COMPACT_SEMC_CS_LOADER__R3A010 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 680 secs. . .You read the phone to punch . .SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35657401958129 CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35170701616552 PROVIDER: MULTIPLE Network LOCKED USERCODE:6A91CD71000000000000FFFFFFFFFFFF RESTORATION FILE NOT PRESENT "35170701616552" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 12 secs. |
07-02-2010, 14:28 | #13 (permalink) |
No Life Poster Join Date: Dec 2007 Location: OrbitGsm.Com
Member: 650840 Status: Offline Thanks Meter: 622 | @ jacque abdou YOUR SOLUTION IS------------- UNLOCK REPAIR WITH THESE SETTINGS== 1.PERFORM FULL UNLOCK "INESTEAD OF USERCODE RESET" 2.PATCH "OPT<>GDFS CHECK" IN FARMWARE 3.ALLOW TO CHANGE IMEI WHEN UNLOCKING WHEN IMEI CHANGE WINDOW APPEAR THEN ONLY PRESS OK(NEVER CHANGE IMEI) FINISHED NOW YOUR PHONE WILL BE OK 100% THIS METHOD IS CHECKED BY ME BR, P@lash_c6 |
The Following 2 Users Say Thank You to palash_c6 For This Useful Post: |
07-02-2010, 14:43 | #14 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: U.S.A.
Member: 893209 Status: Offline Thanks Meter: 274 | Quote:
FLASH GDFS@EROMS ONLY on EMPTY FILL TAB,,,,,,,,, Done,,,,,,,,, Br,. Rhyan | |
The Following User Says Thank You to Rhyan777 For This Useful Post: |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
Sp unlocking sim - if you can get or sell please let me know | andrew bennett | Wanted Products | 1 | 09-24-1999 08:43 |
