Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 05-25-2009, 08:48   #1 (permalink)
Member: 993362
Thumbs down w850 after tp repair show FLASH LOADER NOT ANSWERING
w850 after tp repair show FLASH LOADER NOT ANSWERING dear sir, w850i gdfs area damage i try write tp repair its show FLASH LOADER NOT ANSWERING, i try rehot flash ic but continue same problem pls help me what i do ????????????
show log_
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:101000000000000
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35282601834629 CERT:N/A
FLASH CID:49 COLOR:RED
Model (from GDFS):K700
MAPP CXC article: R1KG001 prgCXC1250200_GENERIC_CY
MAPP CXC version: R1KG001
Language Package: EUROPE_4
CDA article: CDA102568/13
CDA version: R2A
Default article: cxc1250489
Default version: R1ED001
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
SEARCH:G:\flash\w850\cid52\r1kg001\R1KG001_1250200 _GENERIC_CY.ssw
can't open file G:\flash\w850\cid52\r1kg001\R1KG001_1250200_GENERI C_CY.ssw
RESTORATION FILE NOT PRESENT
"R1KG001_CXC1250200_GENERIC_CY"
YOU MUST PERFORM FULL FLASHING
WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
Elapsed: 6 secs.
CFG:000000000000000
TESTPOINT REPAIR STAGE #1 STARTED
Open COM port OK
Speed:921600
FLASH LOADER NOT ANSWERING !
Elapsed: 4 secs
Old 05-25-2009, 08:51   #2 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
may be flash chip damaged
Old 05-26-2009, 08:45   #3 (permalink)
Member: 361094
Sonork: 100.1597521
Thumbs up w850i
show log_
CFG:101000000000000
Open COM port OK
Speed:921600
Flash ID check:897E
Flash props sent ok
CDA version: R2A
PROVIDER: 000-00
Elapsed: 6 secs.
CFG:000000000000000
Open COM port OK
Speed:921600
Elapsed: 4 secs
bro just write erom red49 to red 52 and then flash 100 ok
try and podt result
help W850 after DGFS Repair HDR block not accepted,error: 19 sniper007 SETool2 2 03-11-2009 18:56
W830 n V630 FLASH LOADER NOT ANSWER david05 SETool2 2 11-16-2008 08:45
W580i dead after tp repair charomk SETool2 0 10-11-2008 12:53
V9 after unlock only show boot loader asad_nomy7 Smart-Clip 16 07-24-2008 09:51
Page generated in 0.39162 seconds with 11 queries
