04-16-2010, 18:19 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: India Age: 37
Member: 145082 Status: Offline Thanks Meter: 798 | W850 white light problem ???? worked with flashing but the problem is white light after please wait then later only white light or just vibrates what could be done here..... i have tried reset and gdfs and erom but i am just it for the vbery first time please give me the proper procedure for this thanks this is the log for the phone now @ present : CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:49 PAF:1 IMEI:35282601224234 CERT:N/A FLASH CID:49 COLOR:BROWN Model (from GDFS):W850i MAPP CXC article: R1EJ001 prgCXC1250570_HUTCHISON_CY MAPP CXC version: R1EJ001 Language Package: EUROPE_4 CDA article: CDA102568/13 CDA version: R2A Default article: cxc1250489 Default version: R1ED001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R1EJ001_CXC1250570_HUTCHISON_CY" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 3 secs. |
04-16-2010, 20:49 | #2 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Around The World
Member: 482670 Status: Offline Thanks Meter: 125 | same problem with me today.. i try flash many times n change ui board / flex cable / lcd all no work.. then i rehot the flash ic problem slove =) check the flash ic bro |
The Following User Says Thank You to Brother Hui For This Useful Post: |
04-16-2010, 21:14 | #3 (permalink) |
Registered User Join Date: Apr 2007 Location: ==**Syria**== Age: 44
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks Meter: 526 | first change flex cable and lcd then flash phone ........... |
The Following User Says Thank You to yarra For This Useful Post: |
04-16-2010, 23:46 | #4 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | i changed the lcd , flex and board even though the same now trying to flash again with new hardware if not done then i am gonna rehot the flash ic |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
