Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 08-24-2008, 19:46   #1 (permalink)
Member: 717427
Post how can i repair this k800i with my setool?
v0.914037/UNI
CARD SERIAL: 0007777
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER).
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601725950 CERT:N/A
FLASH CID:53 COLOR:RED
IMEI MISMATCH ! GDFS IMEI:35170701616552
Model:K810i
Brand:Generic
MAPP CXC article: R1KC001 prgCXC1250811_GENERIC_SM
MAPP CXC version: R1KC001
Language Package:EUROPE_4
CDA article: CDA111111/DEV
CDA version: R2A
Default article: cxc1250813
Default version: R1KC001
PROVIDER: 000-00
Network LOCKED
RESTORATION FILE NOT PRESENT
"R1KC001_CXC1250811_GENERIC_SM"
YOU MUST PERFORM FULL FLASHING
WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
Elapsed: 189 secs.
this model is k800i..
if i try to identify this phone with my se tool box
this model of phone show k810i..
how can i repair this using se tool?
TIA
Old 08-24-2008, 19:50   #2 (permalink)
Softway's Avatar
Member: 143889
Sonork: 100.1584685
Thanks Meter: 341
u can use K810 firmware on K800 thats not a problem. by info dont see any major problem. tell us whats the problem on phone???
The Following User Says Thank You to Softway For This Useful Post:
Old 08-24-2008, 19:56   #3 (permalink)
Member: 717427
so i can use flashfile of k810i to k800i?
thats what you mean sir. because this
is the 1st time i encounter this problem sir
by the way thank you for reading my thread
more power to you sir!!
Old 08-25-2008, 07:47   #4 (permalink)
Softway's Avatar
Member: 143889
Sonork: 100.1584685
Thanks Meter: 341
if u need step by step instruction then its impossible to give here. use msn or sonork to contact me directly ill assist u np
Old 08-25-2008, 08:22   #5 (permalink)
Member: 310458
Thanks Meter: 94
repair gdfs with testpoint....
Old 08-25-2008, 08:36   #6 (permalink)
llcoolr's Avatar
Member: 53408
Sonork: 100.1593951
Thanks Meter: 1,261
if u use K810 firmware on K800 u will have keypad light problem but phone will work normal
but tell us what is phone peoblem exactly (red-blink , white screen ,.....)
Old 08-25-2008, 09:04   #7 (permalink)
Temporary banned !!
Member: 716001
Sonork: 100.1597485
Thanks Meter: 46
how to flash lgU8120 with setool bro
Old 08-25-2008, 09:29   #8 (permalink)
NawabN Sahoo's Avatar
Member: 687312
Thanks Meter: 290
Mate just open LG 3G tab in SEtool add file (it have 4 parts file) then go setting tabs and tick mark on FORCE LG 3G CID 17
and Flash it with a fully charged battrey this is all.
GOOD Flash
The Following User Says Thank You to NawabN Sahoo For This Useful Post:
Old 08-25-2008, 09:35   #9 (permalink)
Temporary banned !!
Member: 716001
Sonork: 100.1597485
Thanks Meter: 46
good job man very very nice
The Following User Says Thank You to musmyl For This Useful Post:
Old 08-25-2008, 10:18   #10 (permalink)
Temporary banned !!
Member: 716001
Sonork: 100.1597485
Thanks Meter: 46
i have finish to flash it lg u8120 bro ready to work thanks
v0.914039/UNI
CARD SERIAL: 000.....
Open COM port OK
ChipID:7100,EMP protocol:0301
PHONE IS BROWN
FLASH CID detected:17
Speed:921600
DB2000 only supports 460800,fallback.
OTP LOCKED:1 CID:17 PAF:0 IMEI:35329000693114 CERT:B
Open COM port OK
PHONE IS BROWN
Speed:921600
OTP LOCKED:1 CID:17 PAF:0 IMEI:35329000693114 CERT:BROWN
LDR:041214 0759 MATCXC1325712_PRODUCTION R2Z
Flash ID check:890D
Flash props sent ok
Switching to USB...
interface not changed
writing E:\FLASH FILES\LG\setool\U8120\U8120_UK_Hutchison_v105+\U81 20_V105_UK_PHONE.ssw
CURRENT FLASH FILE CID:17
SSW uses dynamic hash, dynamic hash len is:184
Will flash 184 blocks...
SSW loading returns:0
writing E:\FLASH FILES\LG\setool\U8120\U8120_UK_Hutchison_v105+\U81 20_V105_UK_FS.ssw
SSW uses dynamic hash, dynamic hash len is:528
Will flash 528 blocks...
writing E:\FLASH FILES\LG\setool\U8120\U8120_UK_Hutchison_v105+\U81 20_V105_UK_DRIVEC.ssw
SSW uses dynamic hash, dynamic hash len is:160
Will flash 160 blocks...
writing E:\FLASH FILES\LG\setool\U8120\U8120_UK_Hutchison_v105+\U81 20_V105_UK_DRIVEMEDIA.ssw
SSW uses dynamic hash, dynamic hash len is:56
Will flash 56 blocks...
Setting up GDFS...
Writing simlocks...
Insert any SIM, enter 2945#*88110#, then unlock code
ALL UNLOCK/LOCK CODES SET TO "78284023"
Signing...
control keys complete.
full sig complete.
Phone detached
Unlock Done
Elapsed: 1858 secs.
how can we repaire this? risan WD2 & APE (Symbian Phones) 17 07-22-2013 22:06
How can I repair this nokia 5220 with x-key javierramirez MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-05-2010 04:51
can i repair this 5220 with genie? safvanp Genie Universal 4 11-15-2009 07:46
how can i repair this phone knok95 Infinity-Box 1 09-10-2008 16:46
how can i repair this kind of error by usb smart gsmbac Motorola P2K (USB-Smart) 0 04-19-2006 17:10
Page generated in 0.19352 seconds with 9 queries
