Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 05-14-2011, 22:59   #1 (permalink)
microera's Avatar
Member: 4923
Thanks Meter: 74
w880 flashing...
SIGNED MODE (USING SERVER)
CFG:101000000000
ChipID:9900,EMP protocol:0301
Speed:921600
LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M
OTP LOCKED:1 CID:51 PAF:1 IMEI:35777401786003
ACTIVE CID:49 COLOR:RED
can't get packet start.
A1_loader_on_loaderrologue error (00)
Elapsed: 48 secs.
i cant flash w880 .....
where is problem?
Old 05-15-2011, 09:54   #2 (permalink)
yuresh's Avatar
Member: 1235816
Thanks Meter: 95
you must write gdfs then flash it
Old 05-15-2011, 13:09   #3 (permalink)
shaikhaltaf_m's Avatar
Member: 510263
Sonork: 100.1601350
Thanks Meter: 99
how can i write gdfs for this phone
give me detail sep by step
how much credit we need to write gdfs fiile
please yuresh thanks in adwane
Old 05-15-2011, 14:08   #4 (permalink)
yuresh's Avatar
Member: 1235816
Thanks Meter: 95
no need cradit
fist go to emptyboard tab
then select proper model
on settings, check "signed mode"
press recovery
after succeful recovery
go emptyboard tab ad db 2020 ss format file in setool folder & flash it
after flash cler it & ad erom db 2020 cid 52 & flash it
now gdfs completely write it
press identity then flash shown identity
dont forget say thanks
Old 05-15-2011, 14:26   #5 (permalink)
microera's Avatar
Member: 4923
Thanks Meter: 74
COM mode:
USBFLASH DRIVER VERSION 02.02.00.05
CFG:100000000000
RESET MODE STARTED
Speed:921600
err: [45/13]
loader prologue returns invalid status
Elapsed: 9 secs.
not possible enter restore mode....and there fore not possible write gdfs
USB mode:
CFG:100000000000
RESET MODE STARTED
PROCEDURE WAS STOPPED BY USER
Elapsed: 80 secs.
not possible write anything!
Old 05-15-2011, 14:38   #6 (permalink)
microera's Avatar
Member: 4923
Thanks Meter: 74
ok....now
I successfuly enter to RECOVERY MODE in SonyEricsson tab (signed mode)
But I now need gdfs and erom equal CID51 or higher .....
current setool2 version: 1.106
Elapsed: 5 secs.
CFG:100000000000
RESET MODE STARTED
Speed:921600
RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA
FLASH ID: 2019
GOT SEED:BDCC172C23808E751530E5BF
P96 AUTH PASSED
PHONE SUCCESSFULLY RESET TO DEVELOPER STATE
Elapsed: 22 secs.
Old 05-15-2011, 14:53   #7 (permalink)
yuresh's Avatar
Member: 1235816
Thanks Meter: 95
you can found it your setool folder
The Following User Says Thank You to yuresh For This Useful Post:
Old 05-15-2011, 15:17   #8 (permalink)
microera's Avatar
Member: 4923
Thanks Meter: 74
this erom is good or not?
because "subblock 000 NAK":
Old 05-15-2011, 16:37   #9 (permalink)
Member: 1034869
Thanks Meter: 9
I think HW problem ... bad flash?
Old 05-16-2011, 05:00   #10 (permalink)
yuresh's Avatar
Member: 1235816
Thanks Meter: 95
erome file bad change it to red 49 file
Old 05-16-2011, 18:57   #11 (permalink)
microera's Avatar
Member: 4923
Thanks Meter: 74
after rehot main board and flashing again:
RUNNING v 1.106/UNI
CARD SERIAL **********
CFG:101000000000
Speed:921600
ACTIVE CID:53 COLOR:RED
PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0
LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015
FLASH ID: 2019
writing "D:\gsm2010\setool3\w880\R8BA024_1250640_GENERIC_A I.ssw"
CURRENT FLASH FILE CID: 53
SSW uses full hash, hash len is: 9200
Will flash 460 blocks...
writing "D:\gsm2010\setool3\w880\R8BA024_FS_CENT_EUROPE_AI _RED_CID53.SOFTWARE"
SSW uses full hash, hash len is: 2740
Will flash 137 blocks...
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader GDFS startup executed
loader FILESYSTEM startup executed
using GENERIC phone customization
tpa/preset/custom/C3_PCA_G3v2.cer
tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
tpa/preset/custom/customize.xml
tpa/preset/custom/DESKTOP_HOOK_2.itm
tpa/preset/custom/Entrust.net Root Certificate.cer
tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
tpa/preset/custom/FM_PICTURES_HOOK_3.itm
tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
tpa/preset/custom/FM_THEMES_HOOK_3.itm
tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
tpa/preset/custom/GAMES_HOOK_3.itm
tpa/preset/custom/GTE_CyberTrust_Root.cer
tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
tpa/preset/custom/Root.cer
tpa/preset/custom/SEMC_E2E_Root_CA.crt
tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
tpa/preset/custom/ThawtePremium.der
tpa/preset/custom/ThawteServerCA.cer
tpa/preset/custom/Utiroot.cer
tpa/preset/custom/VeriSignClass3Root.cer
tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
Phone detached
Elapsed: 819 secs.
work OK.... but not for long time!
It seems to be failure on main board....bad contacts.....
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Nokia Flash Content. Phantom Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-01-2000 23:28
Page generated in 0.19025 seconds with 9 queries
