02-07-2014, 11:52 | #1 (permalink) |
No Life Poster Join Date: May 2010
Member: 1300483 Status: Offline Thanks Meter: 27 | w995 credit lost phone not respond at 3, retry 1 plz help CARD SERIAL 00176895 USBFLASH DRIVER VERSION 03.00.00.00 SIGNED MODE (USING SERVER) CFG:101000000000 short credits consumption list : Services OFFLINE S1 v1,v2,S1 OPEN AID 004,FLASHMODE activation Services ONLINE A1 phones unlock/repair 03 credits S1 OPEN unlock/repair 03 credits A2 phones, CSCA way unlock/repair 03 credits S1 QSD8250,MSM7227,MSM8255 alternative bypass unlock/repair 01 credits S1 QSD8250,MSM7227,MSM8255 alternative bypass STANDALONE activation 10 credits W100,W150 unlock codes 01 credits ST21,ST21i2,ST23 alternative bypass unlock 02 credits ST26,C150x,C160x alternative bypass unlock 02 credits You CAN NOT unlock next phones without S1 server: u1/u5/u8 with loader AID 004, LoCosto,Neptune-based phones with damaged security zone, LoCosto,Neptune-based phones with loader AID 004, w100,w150 full unlock,ck13,ck15,wt13, any SONY phone, released from 2012 year,except ST21,ST21i2,ST23,ST26,C150x,C160x phones current updater version: 0.95 current setool2 version: 1.1405 SERVER CREDITS LEFT/USED: 30/0 CARD COUNTERS: FLASH 118, UNLOCK 432 Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID: E900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01248400146916] OTP: LOCKED:1 CID:81 PAF:1 IMEI:01248400146916 CERT:RED LDR: 2010-03-02 18:01 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:01 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Unlock FAILED Elapsed: 15 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110011000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 7 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID: E900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01248400146916] OTP: LOCKED:1 CID:81 PAF:1 IMEI:01248400146916 CERT:RED LDR: 2010-03-02 18:01 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:01 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM293 Phone not responds to AT #1, retry 1 Phone not responds to AT #1, retry 2 Phone not responds to AT #1, retry 3 Phone not responds to AT #1, retry 4 Phone not responds to AT #1, retry 5 CSCA UNLOCK FAILED Unlock FAILED Elapsed: 1419 secs. SIGNED MODE (USING SERVER) CFG:100001000000 ChipID: E900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01248400146916] OTP: LOCKED:1 CID:81 PAF:1 IMEI:01248400146916 CERT:RED LDR: 2010-03-02 18:01 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:01 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA [A2_usercode_reset] failed, err: 101D Unlock DONE [A2_shutdown] can't get ACK Elapsed: 31 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID: E900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01248400146916] OTP: LOCKED:1 CID:81 PAF:1 IMEI:01248400146916 CERT:RED LDR: 2010-03-02 18:01 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:01 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM293 Phone not responds to AT #1, retry 1 Phone not responds to AT #1, retry 2 Phone not responds to AT #1, retry 3 Phone not responds to AT #1, retry 4 Phone not responds to AT #1, retry 5 CSCA UNLOCK FAILED Unlock FAILED Elapsed: 92 secs. SIGNED MODE (USING SERVER) CFG:100011000000 short credits consumption list : Services OFFLINE S1 v1,v2,S1 OPEN AID 004,FLASHMODE activation Services ONLINE A1 phones unlock/repair 03 credits S1 OPEN unlock/repair 03 credits A2 phones, CSCA way unlock/repair 03 credits S1 QSD8250,MSM7227,MSM8255 alternative bypass unlock/repair 01 credits S1 QSD8250,MSM7227,MSM8255 alternative bypass STANDALONE activation 10 credits W100,W150 unlock codes 01 credits ST21,ST21i2,ST23 alternative bypass unlock 02 credits ST26,C150x,C160x alternative bypass unlock 02 credits You CAN NOT unlock next phones without S1 server: u1/u5/u8 with loader AID 004, LoCosto,Neptune-based phones with damaged security zone, LoCosto,Neptune-based phones with loader AID 004, w100,w150 full unlock,ck13,ck15,wt13, any SONY phone, released from 2012 year,except ST21,ST21i2,ST23,ST26,C150x,C160x phones current updater version: 0.95 current setool2 version: 1.1405 SERVER CREDITS LEFT/USED: 27/3 CARD COUNTERS: FLASH 118, UNLOCK 433 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID: E900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01248400146916] OTP: LOCKED:1 CID:81 PAF:1 IMEI:01248400146916 CERT:RED LDR: 2010-03-02 18:01 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:01 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM293 Phone not responds to AT #3, retry 1 Phone not responds to AT #3, retry 2 Phone not responds to AT #3, retry 3 Phone not responds to AT #3, retry 4 Phone not responds to AT #3, retry 5 CSCA UNLOCK FAILED Unlock FAILED Elapsed: 121 secs. |
