Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Location: uk
Member: 508100 Status: Offline Sonork: 1600934 Thanks: 75
| W995 unlock 3credit taken but not unlocked Hello Setool team, I tried to unlock sony erricson w995 but no sucess and lost 3 credits here is the log SIGNED MODE (USING SERVER) CFG:100010000000 ChipID: E900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,35947303802136] OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 35947303802136 CERT: RED LDR: 2010-03-02 18:01 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:01 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Unlock FAILED Elapsed: 27 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 10/20 CARD COUNTERS: FLASH 17, UNLOCK 120 Elapsed: 2 secs. it took my 3 credits dont know whats wrong, can you please check and let me know about it and why 3 credits have been taken if the phone is not unlocked |
| The Following User Says Thank You to 00aa For This Useful Post: |
| | #3 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2009 Location: by the mediterranean sea
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks: 668
| first of all. it was some kind of communication error with server, try again and you should have your phone unlocked, no more credits will be used. next time, just select signed mode+bypass method... it is free @matelecom: try to unlock U10 cid81 using your 4se, if you want to help, do it but do not spam. I will suggest that you never use an account that has credits, unless you are sure that you need them. just type: updater/updater or edit setool.ini file so that you do not loose any credits due to accidentaly use the wrong settings. |
| | #4 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2010 Location: In trouble Age: 38
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks: 114
| Quote:
Anyway, about w995 cid 81 unlocking, try 1,5 and 6 as settings | |
| | #6 (permalink) | |
| thanks Quote:
| | #8 (permalink) |
| My mistake I am really sorry, you cannot direct unlock cid81 because s1 v2 server is offline. Have to do it via csca. Tick signed+altbypass+perform full unlock+ disable a2 flash Follow instructions and do NOT disconnect the phone from cable until the phone is fully turn on after all the procedure is over. Enviado desde mi A100 usando Tapatalk 2 |
| | #9 (permalink) | |
| sorry Quote:
ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110011000000 ChipID: E900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,35947303802136] OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 35947303802136 CERT: RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Unlock FAILED Elapsed: 5 secs. did that bruv, not done | |
| | #10 (permalink) |
| OK so today I am not really so clear. Check FAQ and look for a2 csca method. It should be signed+perform full unlock+disable a2 flash Hope this time my memory works better. Enviado desde mi A100 usando Tapatalk 2 |
| | #11 (permalink) |
| 1.select proper model 2.on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3.back to semc a2 tab, press unlock 4.when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5.when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. HAPPY SO HAAPY SIGNED MODE (USING SERVER) CFG:100011000000 ChipID: E900, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,35947303802136] OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 35947303802136 CERT: RED LDR: 2010-03-02 18:01 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:01 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM76 PHONE READY TO PROCEED. GOT SEED: 00C37358 ACTIVATION COMPLETED. USERCODE RESET TO "0000" DO NOT DISCONNECT PHONE FROM CABLE UNTIL PHONE TURNS ON BY ITSELF Unlock DONE Elapsed: 1330 secs. three credits but happy customer |
| | #13 (permalink) | |
| Quote:
A stupid spammer wrote a stupid thing and I corrected him You are not adding anything to the statement. This is setool section, go play with your key at the proper section. What are you saying? Is it not true that your key CANNOT unlock a2 cid81? What else is there that you can add to this thread? Do you really want to keep posting? Even when you are wrong? Enviado desde mi A100 usando Tapatalk 2 | |
| | #14 (permalink) |
| Sorry dude, I just checked your old messages. Today is my day full of mistakes. Sorry again. But this post was about unlocking a2 cid81 via csca... I was carried away. Enviado desde mi A100 usando Tapatalk 2 |
| | #15 (permalink) |
| What is wrong with what I wrote ? I told you to use 1,5 and 6 as settings... Am I just invisible ? ^^ Or is it just useless trying to help... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Sigma Software v1.09.03 is out! New Motorola Android sets are ready to be unlocked! | GSM_Support | SigmaKey | 69 | 05-31-2013 13:33 |
| Carrier: Telus CAN Need unlock | Tom_ptm | Wanted Products | 3 | 07-11-2012 20:35 |
| İ9300 4.04 stp box not possİble but oictopus İs okk | cemeren38 | Octopus LG/Octoplus LG | 0 | 07-11-2012 10:42 |
| Sigma Software v1.09.03 is out! New Motorola Android sets are ready to be unlocked! | GSM_Support | GSM News & Updates | 0 | 07-11-2012 10:39 |
