07-08-2012, 22:39 | #1 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1271541 Status: Offline Thanks Meter: 35 | were withdrawn 3 log while w20i is not unlocking ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01253000607214 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation server error:remote dongle not available Unlock FAILED Elapsed: 12 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 19/11 CARD COUNTERS: FLASH 174, UNLOCK 161 Elapsed: 2 secs. |
07-10-2012, 03:29 | #3 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Poland
Member: 1704846 Status: Offline Sonork: 1617108 Thanks Meter: 117 | Read and unlock phone: 1. select proper model 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery,wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. you MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method. |
07-13-2012, 12:48 | #4 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1322963 Status: Offline Thanks Meter: 1 | SIGNED MODE (USING SERVER) CFG:100011000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01253000560323 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM103 Phone not responds to AT #1, retry 1 Phone not responds to AT #1, retry 2 Phone not responds to AT #1, retry 3 Phone not responds to AT #1, retry 4 Phone not responds to AT #1, retry 5 CSCA UNLOCK FAILED Unlock FAILED Elapsed: 65 secs. |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
