03-27-2011, 18:15 | #2 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | Perform reset procedure. that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. |
The Following User Says Thank You to mobile mart For This Useful Post: |
03-27-2011, 19:04 | #3 (permalink) |
No Life Poster Join Date: Jul 2008
Member: 826522 Status: Offline Thanks Meter: 33 | after successful recovery setool shows: CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:3522070 ACTIVE CID:49 COLOR:BROWN can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 32 secs. if flashing it shows this error writing "C:\Users\starter\Desktop\proshivki.org__k790_r1eg 001setool\R1EG001_1250477_GENERIC_EV.ssw.cry" CURRENT FLASH FILE CID: 49 SSW uses full hash, hash len is: 9100 HDR block not accepted,error: 19 Elapsed: 9 secs. i Last edited by srt6; 03-27-2011 at 19:14. |
03-27-2011, 23:08 | #4 (permalink) |
Freak Poster Join Date: Dec 2006 Location: canada
Member: 404967 Status: Offline Thanks Meter: 33 | use search before posting brother... http://forum.gsmhosting.com/vbb/f473...unlock-822592/ |
The Following User Says Thank You to walidprestige For This Useful Post: |
03-28-2011, 09:59 | #5 (permalink) |
Member: 696136 Status: Offline Thanks Meter: 210 | Do exactly as i mention above, should work, remember all procedure should be done in "emptyfill/repair" tab. |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
