01-14-2009, 13:00 | #1 (permalink) |
Registered User Join Date: Feb 2004 Location: MERSIN, TURKEY
Member: 55026 Status: Offline Thanks Meter: 53 | When unlocking phone always goes off!!! pls urgent help, what to do?? v0.915030/UNI CARD SERIAL: 00083710 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170801377957 CERT:N/A FLASH CID:52 COLOR:RED Model:K800i Brand:Generic MAPP CXC article: R1KG001 prgCXC1250210_GENERIC_WI MAPP CXC version: R1KG001 Language Package:EUROPE_2 CDA article: CDA102295/1 CDA version: R2A Default article: cxc1250490 Default version: R1KG001 PROVIDER: 234-33 Network LOCKED RESTORATION FILE NOT PRESENT "R1KG001_CXC1250210_GENERIC_WI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 164 secs. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170801377957 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 Executing CSCA-based unlock. SECURITY UNITS NOT PREPARED Elapsed: 36 secs. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170801377957 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "C:\Cep Tel\Ericsson\SONY ERICSSON\SETOOL\FLASH\K800\R1KG001_1250210_GENERIC _WI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 Elapsed: 255 secs. SIGNED MODE (USING SERVER) PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 5 secs. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170801377957 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "C:\Cep Tel\Ericsson\SONY ERICSSON\SETOOL\FLASH\K800\R1KG001_1250210_GENERIC _WI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing "C:\Cep Tel\Ericsson\SONY ERICSSON\SETOOL\FLASH\K800\R1KG001_FS_EUROPE_2_WI_ RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:4580 Will flash 229 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing "tpa/preset/custom/C3_PCA_G3v2.cer" writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm" writing "tpa/preset/custom/customize.xml" writing "tpa/preset/custom/DESKTOP_HOOK_2.itm" writing "tpa/preset/custom/Entrust.net Root Certificate.cer" writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt" writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm" writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm" writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm" writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm" writing "tpa/preset/custom/GAMES_HOOK_3.itm" writing "tpa/preset/custom/GTE_CyberTrust_Root.cer" writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt" writing "tpa/preset/custom/Root.cer" writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt" writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm" writing "tpa/preset/custom/ThawtePremium.der" writing "tpa/preset/custom/ThawteServerCA.cer" writing "tpa/preset/custom/Utiroot.cer" writing "tpa/preset/custom/VeriSignClass3Root.cer" writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt" Phone detached Elapsed: 432 secs. THAT ACTION IS ILLEGAL,IF YOU DOING IT FOR ANY PURPOSE, OTHER THAN REPAIR PHONE SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170801377957 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM26 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Trying to launch embedded bootloader... embedded flashloader not responds ! Elapsed: 413 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 8 secs. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Trying to launch embedded bootloader... embedded flashloader not responds ! Elapsed: 35 secs. SIGNED MODE (USING SERVER) PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170801377957 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed (1D) loader GDFS startup failed, that is fatal Elapsed: 11 secs. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Trying to launch embedded bootloader... embedded flashloader not responds ! Elapsed: 37 secs. PRELOADER SECURITY BYPASS ENABLED. PROCEDURE WAS STOPPED BY USER Elapsed: 2 secs. THAT ACTION IS ILLEGAL,IF YOU DOING IT FOR ANY PURPOSE, OTHER THAN REPAIR PHONE SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170801377957 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing "C:\Cep Tel\Ericsson\SONY ERICSSON\SETOOL\FLASH\K800\R1KG001_1250210_GENERIC _WI.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 Elapsed: 250 secs. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Trying to launch embedded bootloader... INT LDRB2020_PRELOADER_FOR_SETOOL2 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170801377957 CERT:RED LDRB2020 LOADER FOR SETOOL2 UPLOADING REST FILE "C:\Cep Tel\Ericsson\SONY ERICSSON\SETOOL\rest\R1KG001_CXC1250210_GENERIC_WI .zip"... bad file, will not flash it. Elapsed: 15 secs. |
01-14-2009, 21:46 | #3 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | add main file than press identify ...rest fill make automatically...then paste rest file in setool rest directory than unlock 100% |
01-15-2009, 10:00 | #5 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Somewhere there Age: 14
Member: 567723 Status: Offline Thanks Meter: 314 | 1. you downloading corresponding archive for your phone platform. 2. unpack archive in some dir,say: c:\makeB\ 3. open setool2, select your model, on settings check ONLY "use signed mode" 4. in misc.edit, select corresponding file, example: C:\makeB\makeB_db2010\makeB.txt 5. press write script, script will be written in phone 6. power on phone. 7. wait until in boots fully, then go to file manager, "other" folder. here you should have files like cexecutor or dexecutor or executor or all 8. send that file using bluetooth,infrared or using cable to yours PC 9. attach it here WITH FULL DETAILED PHONE INFO (IDENTIFY OUTPUT WILL BE JUST GREAT) 10. i will make bypass package and will upload file at support area and attach it in that thread. 11. put bypass package .zip file into REST folder of setool2. DO NOT TRY TO UNZIP IT. br >>> GsmFreeShop << |
01-31-2009, 01:09 | #6 (permalink) |
Junior Member Join Date: Nov 2008
Member: 894326 Status: Offline Thanks Meter: 2 | hy I dv0.915031/UNI CARD SERIAL: Loaded 51 flash descriptors ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35715501968605 CERT:RED FLASH CID:52 COLOR:RED no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 38 secs. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35715501968605 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok phone CID not supported in that mode Elapsed: 65 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35715501968605 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed (1D) loader GDFS startup failed, that is fatal Elapsed: 12 secs. o question how it could ensure a fix? |
E250 when connect Charger, Charger goes Off | Adil Mobiles | Samsung Hardware Repair | 4 | 02-06-2010 12:06 |
When unlocking phone always goes off!!! | KUBAT1 | SETool2 | 11 | 03-22-2009 00:56 |
sl repair phones always goes to WD | mj_0990 | BB5KING | 3 | 03-05-2009 09:40 |
try to unlock and then goes off | gbada | Mitsubishi | 0 | 10-30-2004 10:20 |
A55 v11 when put on it goes off | chafeh | E-Gold Based Phones | 3 | 05-16-2004 13:20 |
