10-15-2008, 09:47 | #1 (permalink) |
Junior Member Join Date: Apr 2008
Member: 754596 Status: Offline Thanks Meter: 1 | Who can solve this problem i have flashe but error in gdfs area then i repair it (with Se ultimate unlocker) is succes but when i identify with setool the log show like this : v0.914039/UNI 10/15/2008 2:47:07 AM CARD SERIAL: 00068346 10/15/2008 2:47:07 AM Loaded 51 flash descriptors 10/15/2008 2:47:12 AM Open COM port OK 10/15/2008 2:47:16 AM ChipID:8040,EMP protocol:0301 10/15/2008 2:47:16 AM NEW SECURITY (MARITA RESPIN) PHONE 10/15/2008 2:47:16 AM 10/15/2008 2:47:16 AM PHONE IS RED RETAIL PRODUCT 10/15/2008 2:47:16 AM FLASH CID detected:53 10/15/2008 2:47:16 AM Speed:921600 10/15/2008 2:47:17 AM Flash ID check:897E 10/15/2008 2:47:17 AM Flash props sent ok 10/15/2008 2:47:17 AM OTP LOCKED:1 CID:51 PAF:1 IMEI:35201402280431 CERT:RED 10/15/2008 2:47:18 AM FLASH CID:53 COLOR:RED 10/15/2008 2:47:19 AM 10/15/2008 2:47:19 AM Brand: 10/15/2008 2:47:19 AM MAPP CXC article: 10/15/2008 2:47:19 AM MAPP CXC version: 10/15/2008 2:47:19 AM Language Package: 10/15/2008 2:47:19 AM CDA article: 10/15/2008 2:47:19 AM CDA version: 10/15/2008 2:47:19 AM Default article: 10/15/2008 2:47:19 AM Default version: 10/15/2008 2:47:19 AM PROVIDER: 000-00 10/15/2008 2:47:19 AM SIMLOCKS NOT DETECTED 10/15/2008 2:47:19 AM 10/15/2008 2:47:19 AM USERCODE:0000 10/15/2008 2:47:20 AM 10/15/2008 2:47:20 AM RESTORATION FILE NOT PRESENT 10/15/2008 2:47:20 AM "_" 10/15/2008 2:47:20 AM YOU MUST PERFORM FULL FLASHING 10/15/2008 2:47:20 AM WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED 10/15/2008 2:47:20 AM 10/15/2008 2:47:20 AM BYPASS PACKAGE NOT PRESENT 10/15/2008 2:47:20 AM "_.zip" 10/15/2008 2:47:20 AM YOU MUST FLASH SUPPORTED FIRMWARE 10/15/2008 2:47:20 AM TO USE "ALTERNATIVE SECURITY BYPASS" 10/15/2008 2:47:20 AM 10/15/2008 2:47:20 AM Elapsed: 8 secs. any Solution for this |
10-15-2008, 11:10 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Full Flash Phone & than Try To UNLOCK .............! | |
10-15-2008, 11:26 | #5 (permalink) |
Member: 754596 Status: Offline Thanks Meter: 1 | i have flashed the phone with setool the log like this Open COM port OK 10/15/2008 2:48:32 AM ChipID:8040,EMP protocol:0301 10/15/2008 2:48:32 AM NEW SECURITY (MARITA RESPIN) PHONE 10/15/2008 2:48:32 AM 10/15/2008 2:48:32 AM PHONE IS RED RETAIL PRODUCT 10/15/2008 2:48:32 AM FLASH CID detected:53 10/15/2008 2:48:32 AM Speed:921600 10/15/2008 2:48:33 AM OTP LOCKED:1 CID:51 PAF:1 IMEI:35201402280431 CERT:RED 10/15/2008 2:48:33 AM phone CID not supported in that mode 10/15/2008 2:48:34 AM Elapsed: 6 secs. 10/15/2008 2:48:41 AM SIGNED MODE (USING SERVER). 10/15/2008 2:48:41 AM Open COM port OK 10/15/2008 2:48:53 AM ChipID:8040,EMP protocol:0301 10/15/2008 2:48:53 AM NEW SECURITY (MARITA RESPIN) PHONE 10/15/2008 2:48:53 AM 10/15/2008 2:48:53 AM PHONE IS RED RETAIL PRODUCT 10/15/2008 2:48:53 AM FLASH CID detected:53 10/15/2008 2:48:53 AM Speed:921600 10/15/2008 2:48:54 AM OTP LOCKED:1 CID:51 PAF:1 IMEI:35201402280431 CERT:RED 10/15/2008 2:48:55 AM LDR:071219 1257 ESG_DB2012_FLASHLOADER_R2B017_CXC1326738 10/15/2008 2:48:55 AM Flash ID check:897E 10/15/2008 2:48:55 AM Flash props sent ok 10/15/2008 2:48:55 AM writing G:\SETOOL\FILE SETOOL\FILES SONY\w200\cid53\R4GB001_1250719_GENERIC_ME.ssw 10/15/2008 2:48:58 AM CURRENT FLASH FILE CID:53 10/15/2008 2:48:58 AM SSW uses complete hash, hash len is:6340 10/15/2008 2:48:59 AM Will flash 317 blocks... 10/15/2008 2:56:06 AM SSW loading returns:0 10/15/2008 2:56:06 AM writing G:\SETOOL\FILE SETOOL\FILES SONY\w200\cid53\R4GB001_1250719_GENERIC_ME.ssw 10/15/2008 2:56:09 AM CURRENT FLASH FILE CID:53 10/15/2008 2:56:09 AM SSW uses complete hash, hash len is:6340 10/15/2008 2:56:10 AM Will flash 317 blocks... 10/15/2008 3:03:16 AM SSW loading returns:0 10/15/2008 3:03:27 AM LDR:070904 1147 AN2CXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B014 10/15/2008 3:03:27 AM loader startup: executed 10/15/2008 3:03:34 AM Loader refused to start GDFS services,error is:16 10/15/2008 3:03:34 AM loader GDFS startup failed, that is fatal 10/15/2008 3:03:34 AM Elapsed: 893 secs. GDFS already repair with SE ultimate unlocker its shown OK...but \ when i Flash with sedbx make error "NOT DEFINED BOOTLOADER" any else solution sir |
10-15-2008, 11:40 | #6 (permalink) | |
Goto emptyfill Write Correct ErOM & GDFS than Full Flash Phone......! | |
10-18-2008, 00:21 | #7 (permalink) |
Freak Poster Join Date: May 2007
Member: 502659 Status: Offline Thanks Meter: 101 | baypass absent brother i dont known how to slove this problem any set plz hepl me v0.914037/UNI CARD SERIAL: 00065509 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 skipping empty loader... OTP LOCKED:1 CID:52 PAF:1 IMEI:35586502181583 CERT:RED Model:W350i Brand:Generic MAPP CXC article: R10BA015 prg1208-0242_NAM_1_JH MAPP CXC version: R10BA015 Language Package:C_ASIA CDA article: CDA12345678/123 CDA version: R2A Default article: 1204-3119 Default version: R10BA015 PROVIDER: 234-33 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE NOT PRESENT "R10BA015_1208-0242_NAM_1_JH.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" SECURITY UNITS BACKUP CREATED. Elapsed: 5 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:115200 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35220701410949 CERT:RED FLASH CID:52 COLOR:RED Model:K790a MAPP CXC article: R1CC003 prgCXC1250477_GENERIC_EV MAPP CXC version: R1CC003 Language Package:AMERICA_2 CDA article: CDA102295/1 CDA version: R2A Default article: cxc1250491 Default version: R1CC003 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE NOT PRESENT "R1CC003_CXC1250477_GENERIC_EV.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" SECURITY UNITS BACKUP CREATED. Elapsed: 4 secs. |
10-18-2008, 04:02 | #8 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: sn,fdo,lu philippines
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks Meter: 664 | Quote:
br keaelite | |
10-18-2008, 04:28 | #9 (permalink) | |
Freak Poster Join Date: Jul 2007
Member: 547523 Status: Offline Thanks Meter: 20 | Quote:
who can solve this problem???? china phone wrong flashed | nakshatra | Chinese Models & Cloned Phones | 1 | 07-30-2009 07:37 |
who can solve this problem | shahab1966 | Nokia Hardware & Hardware Repair | 4 | 12-05-2008 11:57 |
Who Can Solve This Problem ? | sunrise gsm | E-Gold Based Phones | 3 | 06-04-2003 22:24 |
