why can not chage imei w810 logs here RUNNING v 1.089/UNI CARD SERIAL 00076646 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:49 PAF:1 IMEI:35233701590993 CERT:RED ACTIVE CID:49 COLOR:RED Model (from GDFS):W810i MAPP CXC article: R4EA031 prgCXC1250316_GENERIC_HN MAPP CXC version: R4EA031 Language Package: EUROPE_1 CDA article: CDA102555/10 CDA version: R5A Default article: cxc1250324 Default version: R4EK001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE NOT PRESENT "R4EA031_CXC1250316_GENERIC_HN" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 9 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111100000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:49 PAF:1 IMEI:35233701590993 CERT:RED ACTIVE CID:49 COLOR:RED Model (from GDFS):W810i MAPP CXC article: R4EA031 prgCXC1250316_GENERIC_HN MAPP CXC version: R4EA031 Language Package: EUROPE_1 CDA article: CDA102555/10 CDA version: R5A Default article: cxc1250324 Default version: R4EK001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 SEARCH:F:\setool\W810\R4EA031_1250316_GENERIC_HN.s sw.cry "R4EA031_CXC1250316_GENERIC_HN" CREATED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 15 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111100000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:49 PAF:1 IMEI:35233701590993 CERT:RED ACTIVE CID:49 COLOR:RED Model (from GDFS):W810i MAPP CXC article: R4EA031 prgCXC1250316_GENERIC_HN MAPP CXC version: R4EA031 Language Package: EUROPE_1 CDA article: CDA102555/10 CDA version: R5A Default article: cxc1250324 Default version: R4EK001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 8 secs. THAT ACTION IS ILLEGAL,IF YOU DOING IT FOR ANY PURPOSE, OTHER THAN REPAIR PHONE SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110110000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35233701590993 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 FLASH ID: 897E LDR:070524 1030 AN2CXC1327364_COMPACT_SEMC_CS_LOADER__R3A010 Executing CSCA-based unlock. Backup security data... loader GDFS startup executed Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM32 PHONE READY TO PROCEED. GOT SEED:00B49CD7 ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 740 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110010000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35233701590993 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 FLASH ID: 897E LDR:070524 1030 AN2CXC1327364_COMPACT_SEMC_CS_LOADER__R3A010 Executing CSCA-based unlock. Backup security data... loader GDFS startup executed Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM32 PHONE READY TO PROCEED. GOT SEED:0072E617 ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 160 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110010000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35233701590993 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 FLASH ID: 897E writing "F:\setool\W810\R4EA031_1250316_GENERIC_HN.ssw.cry " CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 344 Will flash 344 blocks... writing "F:\setool\W810\R4EA031_EUROPE_2_fs.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is: 161 Will flash 161 blocks... LDR:070524 1030 AN2CXC1327364_COMPACT_SEMC_CS_LOADER__R3A010 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 344 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111100110000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35233701590993 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 FLASH ID: 897E LDR:070524 1030 AN2CXC1327364_COMPACT_SEMC_CS_LOADER__R3A010 Executing CSCA-based unlock. Backup security data... loader GDFS startup executed Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM32 PHONE READY TO PROCEED. GOT SEED:003EB49B ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 171 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000110000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35233701590993 CERT:RED PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0 LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738 FLASH ID: 897E LDR:070524 1030 AN2CXC1327364_COMPACT_SEMC_CS_LOADER__R3A010 Executing CSCA-based unlock. Backup security data... loader GDFS startup executed Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM32 PHONE READY TO PROCEED. GOT SEED:0019A2BE ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 105 secs. |
UNTICK all settings except 'allow change imei while ..." + "patch otp..." DB2010 CID49 Change IMEI.rar |
use com/ufs port change usb at bottom to whatever com u on... im sure to do this to w810i it can only b done through com way :) |
