03-30-2016, 12:05 | #1 (permalink) |
Registered User Join Date: Jul 2012
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | Why I Can't Unlock Sharp SH-06D ??? Help i checked there's still 10 free credit, just 6 free credit to do this job, right? logs Code: Universal Tool version: 2.57 OS Version: Windows 7 [NT 6.1] Service Pack 1 Administrative privileges: yes Locale: Indonesia / Indonesian CPU frequency: 3092 MHz Total memory: 3488 MB Free memory: 1764 MB Free space on system disk C:\: 4.00 GB Free space on disk D:\: 838 MB Free space on disk F:\: 2.00 GB You are not using Windows XP. Correct work can only be guaranteed on Windows XP operating system. You have small amount of free space on system disk C:\. Recommended free space is 5 GB or more. Connecting with SH-06D In order to connect with phone you should: 1. Install Sharp ADB drivers 2. Turn on the phone 3. Enable Debug mode in phone (Settings->Applications->USB Debug) 4. Check your Internet connection 5. Plug USB Cable WARNING: Don't forget to click "Disconnect" at the end. Probing ADB Interface... Android Debug Bridge version 1.0.31 Starting ADB server... Waiting for device... Device Found: 6D96000200000001 Connected Receiving phone info Getting phone info Waiting for data... Waiting for boot completion... Getting data... Android Version: 2.3.5 IMEI: 355670-04-202924-0 Linux Kernel Version: 2.6.35.7+ Unlock Codes: INTERNAL ERROR B Info received Stopping ADB server... Adb: AdbCmdFail: cmd=kill-server, exit=1, output=, error=* server not running * Connecting with SH-06D In order to connect with phone you should: 1. Install Sharp ADB drivers 2. Turn on the phone 3. Enable Debug mode in phone (Settings->Applications->USB Debug) 4. Check your Internet connection 5. Plug USB Cable WARNING: Don't forget to click "Disconnect" at the end. Probing ADB Interface... Android Debug Bridge version 1.0.31 Starting ADB server... Waiting for device... Device Found: 6D96000200000001 Connected Receiving phone info Getting phone info Waiting for data... Waiting for boot completion... Getting data... Android Version: 2.3.5 IMEI: 355670-04-202924-0 Linux Kernel Version: 2.6.35.7+ Unlock Codes: INTERNAL ERROR B Info received Receiving phone info Getting phone info Waiting for data... Waiting for boot completion... Getting data... Android Version: 2.3.5 IMEI: 355670-04-202924-0 Linux Kernel Version: 2.6.35.7+ Unlock Codes: INTERNAL ERROR B Info received |
