05-23-2015, 12:21 | #1 (permalink) |
Freak Poster Join Date: Sep 2003
Member: 38138 Status: Offline Thanks Meter: 4 | Xperia E hard locked I have an Xperia E that is hard locked (x) and (0) on all 5 locks. Is there a way of unlocking this as currently it cannot locate any networks? Many thanks |
05-23-2015, 12:53 | #4 (permalink) |
No Life Poster Join Date: Sep 2012 Location: UK
Member: 1816005 Status: Online Thanks Meter: 299 | About alternative security bypass unlock for st21,st21i2,st23,st26,c1504,c1505,c1604,c1605 phones 1. select proper phone model 2. check signed mode + altbypass + do full unlock 3. press unlock and follow program instructions Our users tested all supported phones - and every phone was unlocked To prevent possible problems, in second step, when setool2 ask you to power on phone, disconnect cable from phone, power on phone FULLY, wait at least 30 seconds to allow sluggish android fully start up, then enable USB debugging and only then connect phone. if root procedure will fail ( hang on "Please wait ...." for long time or abort with error ) please press "stop" button and repeat procedure. it it will fail again, please fill complain with identify output , flash phone with different firmware version and retry. notice : - phone will NOT have network until procedure will complete - you CAN root phone with any other tool BEFORE attempt to process it with setool2 - pretty please remove any resident antiviruses, malware monitors, spy programs,debuggers and so on before operation. processed phone CAN be flashed with any other 3rd-party tools, which using original sony loaders. processed phone CAN be flashed with SEUS processed phone CAN NOT be FOTA upgraded processed phone WILL have UNLOCKED fastboot ( unlocked bootloader ) you CAN NOT flash or fix octopus-processed phones using this setool2 version. setool2 will refuse to process such phones. you should wait, until they get my proper patches and integrate it into their software with security units rebuild. finally, until i'll have reliable way to fix such phones without need to have live phone, i'll not enable IMEI change. your phone will not be killed and will be unlocked |
05-23-2015, 13:15 | #5 (permalink) |
Member: 38138 Status: Offline Thanks Meter: 4 | I have tried that again but still have (x) and (0) on all 5 locks. The handset cannot see a sim card and if you ask it to search for a network it shows a blank without searching. The current software is : Baseband 76xxu-usnskolym-2540 Build Number 11.3.A.2.33 Any thoughts greatly appreciated. Regards |
05-23-2015, 15:22 | #6 (permalink) |
No Life Poster Join Date: Oct 2005 Location: England
Member: 193192 Status: Offline Thanks Meter: 327 | Repeat unlock procedure again and WAIT until phone has rebooted fully before removing cable. If you remove cable before full reboot this will cause 5 locks closed. |
05-23-2015, 15:54 | #7 (permalink) |
Member: 38138 Status: Offline Thanks Meter: 4 | Thank you for the tip. Unfortunately I just tried this and got the same result of (x) and (0) on all 5 locks and the handset not being able to see the sim card. CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_BOOT VER "r10D030" ACTIVE_COMP_AID : 0002 HWCONF_AID : 0002 LOADER_AID : 0002 BOOT_AID : 0002 DEVICE ID: E0EA5DD4CD9A24FCF365E0F5B0688A3CFB1974E1 FLASH ID: "0015/00000003" LOADER VERSION: "r5D030" PHONE IMEI : 35.......... (edit ed) Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1520] REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED WARMING UP ... found existing ADB server 1.0.31, killing ... CHECKING ROOT ACCESS ... PROCESSING ... C1505 [13ab6276] FINALIZING ... Unlock DONE |
The Following User Says Thank You to soudies For This Useful Post: |
