Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 08-26-2008, 21:40   #1 (permalink)
Member: 592081
z310 unlock imei repair failed
6.08.2008 23:01:52 v0.914037/UNI
26.08.2008 23:01:52 CARD SERIAL: 00064777
26.08.2008 23:01:52 Loaded 51 flash descriptors
26.08.2008 23:02:05
26.08.2008 23:02:05 THAT ACTION IS ILLEGAL,IF YOU DOING IT
26.08.2008 23:02:05 FOR ANY PURPOSE, OTHER THAN REPAIR PHONE
26.08.2008 23:02:05
26.08.2008 23:02:08 SIGNED MODE (USING SERVER).
26.08.2008 23:02:08 ALTERNATIVE SECURITY BYPASS ENABLED.
26.08.2008 23:02:12 phone pre-boot failed,possible RECOVERY needed.
26.08.2008 23:02:12 PROCEDURE WAS STOPPED BY USER
26.08.2008 23:02:12 Elapsed: 4 secs.
26.08.2008 23:08:23 SIGNED MODE (USING SERVER).
26.08.2008 23:08:23 ALTERNATIVE SECURITY BYPASS ENABLED.
26.08.2008 23:08:31 ChipID000,EMP protocol:0301
26.08.2008 23:08:31
26.08.2008 23:08:31 PHONE IS RED RETAIL PRODUCT
26.08.2008 23:08:31 FLASH CID detected:52
26.08.2008 23:08:31 Speed:921600
26.08.2008 23:08:32 OTP LOCKED:1 CID:51 PAF:1 IMEI:35603601544368 CERT:RED
26.08.2008 23:08:33 LDR:070212 1651 GENCXC1720441_R2A019_PNX5230_FLASHLOADER
26.08.2008 23:08:33 Flash ID check:897E
26.08.2008 23:08:33 Flash props sent ok
26.08.2008 23:08:37 LDR:070503 1431 HANCXC1250610_R3A015_PNX5230_CSLOADER
26.08.2008 23:08:37 loader startup: executed
26.08.2008 23:08:43 loader GDFS startup: executed
26.08.2008 23:08:44 loader filesystem startup: executed
26.08.2008 23:08:44 loader unlock: executed
26.08.2008 23:08:50
26.08.2008 23:08:50 DISCONNECT PHONE NOW
26.08.2008 23:08:50 INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
26.08.2008 23:08:50 BE SURE THAT YOU SET PHONE IN "PHONE MODE"
26.08.2008 23:08:50 IF ASKED, INSTALL PHONE DRIVERS
26.08.2008 23:08:50
26.08.2008 23:08:50 SEARCHING FOR PHONE, "STOP" TO ABORT
26.08.2008 23:10:14 PHONE FOUND AT COM69
26.08.2008 23:10:20 PHONE READY TO PROCEED
26.08.2008 23:10:24 There is NO EXECUTOR in phone !
26.08.2008 23:10:25 Elapsed: 121 secs.
26.08.2008 23:10:29 SIGNED MODE (USING SERVER).
26.08.2008 23:10:29 ALTERNATIVE SECURITY BYPASS ENABLED.
26.08.2008 23:10:39 ChipID000,EMP protocol:0301
26.08.2008 23:10:40
26.08.2008 23:10:40 PHONE IS RED RETAIL PRODUCT
26.08.2008 23:10:40 FLASH CID detected:52
26.08.2008 23:10:40 Speed:921600
26.08.2008 23:10:40 OTP LOCKED:1 CID:51 PAF:1 IMEI:35603601544368 CERT:RED
26.08.2008 23:10:41 LDR:070212 1651 GENCXC1720441_R2A019_PNX5230_FLASHLOADER
26.08.2008 23:10:41 Flash ID check:897E
26.08.2008 23:10:41 Flash props sent ok
26.08.2008 23:10:45 LDR:070503 1431 HANCXC1250610_R3A015_PNX5230_CSLOADER
26.08.2008 23:10:45 loader startup: executed
26.08.2008 23:10:52 loader GDFS startup: executed
26.08.2008 23:10:55 loader filesystem startup: executed
26.08.2008 23:10:55 loader unlock: executed
26.08.2008 23:11:02
26.08.2008 23:11:02 DISCONNECT PHONE NOW
26.08.2008 23:11:02 INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
26.08.2008 23:11:02 BE SURE THAT YOU SET PHONE IN "PHONE MODE"
26.08.2008 23:11:02 IF ASKED, INSTALL PHONE DRIVERS
26.08.2008 23:11:02
26.08.2008 23:11:02 SEARCHING FOR PHONE, "STOP" TO ABORT
26.08.2008 23:11:44 PHONE FOUND AT COM69
26.08.2008 23:11:51 PHONE READY TO PROCEED
26.08.2008 23:12:00 EXECUTOR STARTED
26.08.2008 23:12:00
26.08.2008 23:12:00 REMOVE CABLE FROM PHONE
26.08.2008 23:12:00 REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
26.08.2008 23:12:00 THEN PRESS "READY"
26.08.2008 23:12:29
26.08.2008 23:12:30 ChipID000,EMP protocol:0301
26.08.2008 23:12:31
26.08.2008 23:12:31 PHONE IS RED RETAIL PRODUCT
26.08.2008 23:12:31 FLASH CID detected:52
26.08.2008 23:12:31 Speed:921600
26.08.2008 23:12:31 Trying to launch embedded bootloader...
26.08.2008 23:12:31 INT LDR:PNX5230_PRELOADER_FOR_SETOOL2
26.08.2008 23:12:32 Flash ID check:897E
26.08.2008 23:12:32 Flash props sent ok
26.08.2008 23:12:38 FOUND: R8BA024_CXC1250594_GENERIC_AL
26.08.2008 23:12:38 Restore from:R8BA024_CXC1250594_GENERIC_AL
26.08.2008 23:14:31 verify block error
26.08.2008 23:14:31 last blk:44140000,00010000
26.08.2008 23:15:13 Searching...
26.08.2008 23:15:50 SEARCH TIMED OUT
26.08.2008 23:15:50 IMEI patching failed.
26.08.2008 23:15:50 Unlock FAILED
Old 08-26-2008, 23:11   #2 (permalink)
Member: 527046
try again with another DCU-60
regards
Old 08-27-2008, 08:22   #3 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
@merkezgsm47
chack firt the batry must be charge.
c3010s IMEI Repair failed/false... dmaetrey Z3X-Team Products 5 12-12-2009 03:04
S3650 IMEI repair failed Bakl Z3X-Team Products 1 12-09-2009 19:58
E900 IMEI repair failed Bakl NSPRO 3 09-29-2009 18:58
E250 imei Repair Fail.. LoveLess HWK 1 06-13-2007 19:52
z540V unlock or imei repair fail ! kimo59 NSPRO 0 01-17-2007 17:55
Page generated in 0.30012 seconds with 11 queries
