Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks: 382
| << Z310a AT&T unlocked w/o tp with SETool >> Z310a AT&T unlocked w/o tp successfully with SETool. Great tool. Thanks Laser.... v0.914032/UNI CARD SERIAL: 000***xx Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ChipID 000,EMP protocol:0301PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 skipping empty loader... OTP LOCKED:1 CID:51 PAF:1 IMEI:35781201425760 CERT:RED Model:Z310a Brand:ATT MAPP CXC article: R7AB004 prgCXC1250762_CINGULAR_AL MAPP CXC version: R7AB004 Language Package:CINGULAR CDA article: CDA102670/340 CDA version: R24A Default article: cxc1250595 Default version: R7AB004 PROVIDER: 000-00 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 35 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID 000,EMP protocol:0301PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35781201425760 CERT:RED LDR:070212 1651 GENCXC1720441_R2A019_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok LDR:070503 1431 HANCXC1250610_R3A015_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM55 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" bypassing security... ChipID 000,EMP protocol:0301PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Trying to launch embedded bootloader... INT LDR:PNX5230_PRELOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok FOUND: R7AB004_CXC1250762_CINGULAR_AL Restore from:R7AB004_CXC1250762_CINGULAR_AL full sig complete. USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock DONE Elapsed: 188 secs. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| how to repair gdfs of w830 no tp with setool | SATISH | Sony Ericsson | 1 | 10-21-2009 19:22 |
| z310a at&t unlocked successfull... | frooze_angel | SETool2 | 10 | 03-12-2009 00:27 |
| Nokia BB5/DCT4+ Cingular AT&T unlock By Imei only with GsmFather Server | :::GsmFather::: | GsmFatherOnline Unlock Terminal | 21 | 06-27-2008 22:08 |
| << Successfully Unlock & Change Imei K810i CID52 by Patch with SeTool >> | jhepoy_org | SETool2 | 7 | 12-24-2007 11:31 |
| >>> V3XX - AT&T Unlocked by SMART TP <<< | RNC_EBM | Smart-Clip | 9 | 10-30-2007 01:45 |
