12-24-2008, 03:47 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: QBinh-VietNam
Member: 478447 Status: Offline Thanks Meter: 9 | z310i can't unlock with setool , help me ! SECURITY UNITS BACKUP CREATED. Elapsed: 1 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35464001606845 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM34 SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. Elapsed: 68 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35464001606845 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM34 PHONE READY TO PROCEED CAN'T START EXECUTOR,RETRYING... EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Trying to launch embedded bootloader... embedded flashloader not responds ! Elapsed: 243 secs. to end the phone is automatically switched on the source should not be Unlock. I never encountered this case. desire to help . thanks........ |
12-24-2008, 04:11 | #3 (permalink) |
Junior Member Join Date: Feb 2007 Location: philippines
Member: 449007 Status: Offline Sonork: 100.1618467 Thanks Meter: 1 | hi tick this on seting tab signed mode server enable alternative security bypass enable preloader security bypass bypass package must be present on detected firmware and restoration file.. then tick unlock repair goodluck.. |
12-24-2008, 04:20 | #4 (permalink) |
Member: 478447 Status: Offline Thanks Meter: 9 | I have setiing side kick is: A signed server mode, Enable Alternative Security Bypass Enable preloader Security Bypass. but I still can not Unlock. I have a lot of machines Unlock ok but only machines z310i this is the problem. Remove FROM CABLE PHONE Remove FROM PHONE BATTERY, INSERT IT BACK THEN Then PRESS "READY" problem in this place, I am ready, then press hold the key C + cable plugged but automatically on the source, because the main source of self-up so I can not be Unlock |
12-24-2008, 04:26 | #5 (permalink) |
Insane Poster Join Date: Mar 2008 Location: Robinson's Metro,Philippines
Member: 719577 Status: Offline Thanks Meter: 59 | Sir, try to check phone memory, if there is still much free space. If low free space already, try to delete some files, to create more free space for phone memory, then try unlocking again. If still unsuccessful, please identify phone first and kindly post logs mate. Goodluck. |
The Following User Says Thank You to harungaz For This Useful Post: |
12-24-2008, 05:03 | #6 (permalink) |
Member: 478447 Status: Offline Thanks Meter: 9 | I try to Unlock the machine W350 ok. logs here: v0.915020/UNI CARD SERIAL: 00069485 Loaded 51 flash descriptors ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 skipping empty loader... OTP: LOCKED:1 CID:52 PAF:1 IMEI:35586502457689 CERT:RED Model:W350i Brand:Generic MAPP CXC article: R10BA015 prg1205-7402_VODAFONE_JH MAPP CXC version: R10BA015 Language Package:APAC CDA article: 1207-2173 CDA version: R2A Default article: 1204-3119 Default version: R10BA015 PROVIDER: 000-00 Network subset LOCKED SEARCH:G:\DIEN THOAI DI DONG\SE TOOL\file setool box\w350\r10ba015_app_sw_1205_7402_vodafone_jh_red _cid53_pnx5230.software "R10BA015_1205-7402_VODAFONE_JH" CREATED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 25 secs. ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 skipping empty loader... OTP: LOCKED:1 CID:52 PAF:1 IMEI:35586502457689 CERT:RED Model:W350i Brand:Generic MAPP CXC article: R10BA015 prg1205-7402_VODAFONE_JH MAPP CXC version: R10BA015 Language Package:APAC CDA article: 1207-2173 CDA version: R2A Default article: 1204-3119 Default version: R10BA015 PROVIDER: 000-00 Network subset LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 6 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35586502457689 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:2019 Flash props sent ok LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM37 PHONE READY TO PROCEED There is NO EXECUTOR in phone ! Elapsed: 804 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35586502457689 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:2019 Flash props sent ok LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM37 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Trying to launch embedded bootloader... INT LDR:PNX5230_PRELOADER_FOR_SETOOL2 LDR:PNX5230_PRODUCTION_LOADER_FOR_SETOOL2 Flash ID check:2019 Flash props sent ok FOUND VERSION "R10BA015_1205-7402_VODAFONE_JH" full sig complete. USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock DONE Elapsed: 304 secs. |
12-24-2008, 05:11 | #7 (permalink) |
Member: 478447 Status: Offline Thanks Meter: 9 | I have tried to delete many files in the machine go, but still is not. PHONE STATE: "RETAIL" FLASH CID: 0053 skipping empty loader... OTP: LOCKED:1 CID:51 PAF:1 IMEI:35464001606845 CERT:RED Model:Z310i Brand:Generic MAPP CXC article: R8BA024 prgCXC1250737_CHINA_AL MAPP CXC version: R8BA024 Language Package:APAC CDA article: CDA102669/1 CDA version: R2A Default article: cxc1250595 Default version: R8BA024 PROVIDER: 000-00 Service provider LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 17 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35464001606845 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM34 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Trying to launch embedded bootloader... embedded flashloader not responds ! Elapsed: 150 secs. here the device automatically turn on the source, should not I be able to Unlock log indentify here : PHONE STATE: "RETAIL" FLASH CID: 0053 skipping empty loader... OTP: LOCKED:1 CID:51 PAF:1 IMEI:35464001606845 CERT:RED Model:Z310i Brand:Generic MAPP CXC article: R8BA024 prgCXC1250737_CHINA_AL MAPP CXC version: R8BA024 Language Package:APAC CDA article: CDA102669/1 CDA version: R2A Default article: cxc1250595 Default version: R8BA024 PROVIDER: 000-00 Service provider LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 9 secs. |
12-24-2008, 06:08 | #8 (permalink) |
Member: 719577 Status: Offline Thanks Meter: 59 | Try this sir, in settings, check only enable preloader then press unlock repair. |
12-24-2008, 06:11 | #9 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Circuitcorner
Member: 551599 Status: Offline Thanks Meter: 139 | i think its already unlock PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 Trying to launch embedded bootloader... INT LDR:PNX5230_PRELOADER_FOR_SETOOL2 LDR:PNX5230_PRODUCTION_LOADER_FOR_SETOOL2 Flash ID check:2019 Flash props sent ok FOUND VERSION "R10BA015_1205-7402_VODAFONE_JH" full sig complete. USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock DONE Elapsed: 304 secs. |
12-24-2008, 06:47 | #11 (permalink) |
Member: 719577 Status: Offline Thanks Meter: 59 | Check if you have installed the csca driver completely sir. if you want,you can try to flash it with generic firmware. Then try unlocking again. |
05-10-2014, 07:14 | #15 (permalink) |
Registered User Join Date: Mar 2013 Location: pakistan
Member: 1901604 Status: Offline Sonork: 100.1622736 Thanks Meter: 72 | (DRIVER) SONY ERICSSON Z310i - Download - 4shared here is z310 usb drivers |
z310i not unlocked with setool it's erom problem | leader_gsm | Sony Ericsson | 2 | 05-24-2008 20:28 |
part 2 1st in the world Z310i CID52 unlock with setool | keaelite | Sony Ericsson | 15 | 03-06-2008 15:52 |
8150 unlock with redbox help me!!! | akgiray | Redbox | 16 | 08-17-2006 22:44 |
My S40 can't comunicate with PC... Help me | Monty | x1x to x45/x50 | 3 | 10-16-2002 18:05 |
