10-14-2008, 14:50 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Monrovia
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | z310i Unlocking Problem.........? ALTERNATIVE SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:51 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35464001668790 CERT:RED LDR:061120 1602 HANCXC1720441_R2A016_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok bypassing security... No server found. loader unlock failed, that is fatal Elapsed: 16 secs. |
10-14-2008, 15:29 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | what you have checked in settings?? tick enable preloader tick use alt.bypass tick signed mode press unlock/repair when ask insert test sim card in phone |
10-14-2008, 15:38 | #3 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Use this Script i upload here Select files in "Misc" tab & Click Write Script after write script CID become CID52 than goto setting tick only 2 options 1.CSCA Signed Server 2.Alternative bypass & Do Unlock Repair...!but u must have REST file,USB Driver & Test Card for unlocking ......! | |
10-14-2008, 20:40 | #4 (permalink) | |
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | Quote:
CARD SERIAL: 00010990 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:51 skipping empty loader... OTP LOCKED:1 CID:51 PAF:1 IMEI:35464001668790 CERT:RED Model:Z310i Brand:Netcom MAPP CXC article: R1JC002 prgCXC1250594_GENERIC_AL MAPP CXC version: R1JC002 Language Package:EUROPE_4 CDA article: CDA102670/67 CDA version: R3A Default article: cxc1250595 Default version: R1JC002 PROVIDER: 000-00 Extended LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 24 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:51 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35464001668790 CERT:RED LDR:061120 1602 HANCXC1720441_R2A016_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok LDR:070503 1431 HANCXC1250610_R3A015_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM89 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:51 Speed:921600 Trying to launch embedded bootloader... INT LDR:PNX5230_PRELOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok FOUND: R1JC002_CXC1250594_GENERIC_AL Restore from:R1JC002_CXC1250594_GENERIC_AL full sig complete. USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock DONE Elapsed: 179 secs. i was using only two settings signed mode n alt bypass, as u told me now i select the three settings n the prb is solve. but b4 i was only selecting the these two option n phone unlock successfull, i dontknow this time why its showing me this thing. anyway my prb is solve now thnxxxxxxxxx a lot 4 quick reply SETOOL IS BEST............... | |
Z310i Unlock problem | rutek | Cruiser Suite | 1 | 10-08-2009 14:33 |
Z310i unlocking problem | kami1987 | Cruiser Suite | 4 | 09-12-2009 19:47 |
Z310i unlock problem | Spax | FuriousGold | 4 | 12-30-2007 15:30 |
Z310i earphones problem | Voytaz | Sony Ericsson Hardware Repair | 2 | 09-12-2007 15:16 |
