03-31-2010, 05:47 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: India
Member: 449060 Status: Offline Sonork: 100.1670591 Thanks Meter: 260 | w200 after repair gdfs FLASH CID: 0051 Speed:921600 FLASH ID: 2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35544101399384 CERT:RED FLASH CID:51 COLOR:RED IMEI MISMATCH ! GDFS IMEI:00000000000000 Model (from GDFS):W200i MAPP CXC article: R4GC012 prgCXC1250719_GENERIC_ME MAPP CXC version: R4GC012 Language Package: M_EAST_N_AFR CDA article: CDA102737/109 CDA version: R1A Default article: cxc1250728 Default version: R4GB001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 5 secs. |
03-31-2010, 07:47 | #3 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
format for flash. Enter otp imei number in imei field and tick write imei. 2. go to setting tab tick path otp, change imei when unlocking, format gdfs . 3. go back to emtyfill tab and do flash. (when flashing it informe you that imei not changed, but its not prob. you must see sig compleet.) 4. then click unlock. 5. then go to sony ericcson tab. make full flash and complete after flash. 6. your phone ok, (Dont try to write erom or revert color to red. "Devoloper" state give us more power for flashing and unlocking.) | |
03-31-2010, 07:58 | #4 (permalink) |
Member: 449060 Status: Offline Sonork: 100.1670591 Thanks Meter: 260 | 1. go to emptyfill tab select your phone model . select file w200 gdfs in ssw format for flash. Enter otp imei number in imei field and tick write imei. 2. go to setting tab tick path otp, change imei when unlocking, format gdfs . 3. go back to emtyfill tab and do flash ------------------------------- PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35544101399384 CERT:RED LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738 FLASH ID: 2019 writing "H:\Mobile software\setool\v1.01\gdfs_in_ssw_format\db2010\w2 00_gdfs_in_ssw_format.ssw" CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is: 32 HDR block not accepted,error: 02 Elapsed: 21 secs. help sir |
03-31-2010, 08:59 | #5 (permalink) | |
03-31-2010, 09:20 | #6 (permalink) |
Freak Poster Join Date: Sep 2008 Location: delhi
Member: 857876 Status: Offline Sonork: cellexpert-33 Thanks Meter: 63 | re flash handset with 3 file 1 . ssw gdfs 2 main 3 ffs tik extra option format gdfs when writing is possible. ur handset will ok 100% tested soution |
03-31-2010, 10:15 | #7 (permalink) |
Member: 449060 Status: Offline Sonork: 100.1670591 Thanks Meter: 260 | PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35544101399384 CERT:BROWN LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 2019 Searching... OTP IMEI CHECK NOT FOUND Setting up GDFS... WRITING OTP IMEI:35544101399384 write OTP fail,err:05 OTP WRITE FAILURE WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "56583566" SIGNING... Unlock FINISHED Elapsed: 60 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 |
03-31-2010, 12:41 | #9 (permalink) |
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | |
04-01-2010, 07:11 | #12 (permalink) | |
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote: SETool BOX GDFS Repair solution here | |
After repaired GDFS phone cid become CID 49 | supermatrix | SETool2 | 4 | 08-19-2008 20:00 |
K810i After repair GDFS no network on DCS | anthony cheah | DreamBox | 4 | 07-01-2008 13:28 |
K618 white lcd blinking after repair gdfs | tgcommss | DreamBox | 2 | 05-10-2008 18:11 |
C62 - Freezes after repair GDFS | *MaTeOoSh* | NON Siemens Brand (ODM Phones) | 3 | 10-30-2004 19:55 |
