Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > MSS Box II
Old 05-29-2008, 23:49   #1 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
***MssBox***
What is MSS Box II?
MSSBox II is a standalone hardware platform that tends to be a logical evolution of MSS3 and MSS4 boxes. With both old and new capabilities MSSBox II as always in past stays on-top of current Motorola software market providing its users unlimited capabilities and outstanding support.
Box Benefits:
Completely standalone with no internet connection required for any operation.
No need to have internet at your workplace any more.
Secured extensible fault-tolerant hardware platform includes CPU controlled smartcard reader.
Highest level of protection is brought by complex internal infrastructure that can be at anytime upgraded with additional protection levels.
Detailed categorical support area with flash files described and explained.
Confused by amount of flash files we have at our support area? No wonder! But new encyclopedia-styled support area engine with two display modes will help you by explaining all you want to know about specified flash file.
SafeBackup® technology: completely automated backup/restore phone operations.
Like to make experiments on phones? In this case you will probably value our new invention: complete automatic phone backup/restoral. Just make a backup of your phone and change language packs, DRM packs, manipulate PDS etc. You will always be able to restore it back!One small gift from MSS Team: you are also able to backup phone's firmware areas so that you can safely use them on other phones. Make your own flash files collection!
Over 100 firmware releases supported (and growing)!
It is not a secret, that almost every new firmware release from Motorola is like a new phone with a bit improved security here, a bit changed structure there and so on. That is why supporting just given phone model is no more enough. Good software must support each particular firmware release and MSSBox II does!
Extra-easy "One-button" operated.
Have you ever dreamed about performing any operation on phone via one button? Dream came true! Want to unlock phone? Connect it and press unlock button. Want to Repair PDS in phone? Connect it and press Repair PDS button. No need to select even phone model! Not to mention any parameters, versions etc. MSS will make everything itself!
IntelliDream® technology enables never-seen-before intelligent phone parameters recognition.
Bothered with remembering if this phone requires testpoint or not? Tired of downgrading bootloaders before performing any operation? Forget it! IntelliDream® will take care of all that! Just click one button and software will detect if your phone needs bootloader downgrade or firmware patch and will make everything by itself. If testpoint use will be needed you will be provided with a detailed on-screen instruction on what do you need to do and how. At last you can relax and watch how the job is done by machine!
Detailed software operation manual is always up-to-date at support area.
Feel yourself like professional? Want to know more not only about MSSBox II, but about Motorola phones architecture? Download and read professionally made software operation manual from our support area and rise your knowledge to a new level!
Professional support via MSSBox II support forum.
Have a question? MSS Team professionals are waiting for you on forum to answer your any question about software and Motorola phones.
Box highlights:
Built on a modern highly secured platform - In future can be easily upgraded with the use of a smart card.
High speed USB 2.0 chip - use a full speed flashing for your mobiles!
Multiplatform support - built to work on different platforms. Service Motorola, Sony Ericsson, Nokia, Samsung, LG, Sharp or any other mobile phone with ease! (FBUS,MBUS,USB,RS232,JTAG are supported)
Multiapplication support - use different programs on one box
3rd party application support - can be used as universal box to work with the solutions developed by other companies
__________________________________________________ _
Hardware specification:
- Dimensions: (LxHxW) 70x33x70mm
- Weight: 120 gramm
- Power: 7.5V (not required for normal operation in most cases)
- USB hub: 2 ports, builtin
- Smartcard reader: 1 internal (for box upgrade), 1 external
(for use with 3rd party software which uses smartcards)
- MMC reader: builtin
- USB service port: available
- RJ45 port: available
- JTAG : yes
Ports description:
1
Universal RJ45 configuration port - Configurable Virtual COM port mode. You can configure this connector as high-speed COM-port or any GSM product communication devices or special cable - Vygis box, Infinity box, Cruiser box, SETool box, Cruiser USB UC-10 Cable and etc.
Can also be used as configurable JTAG interface. For low level programming. Can be used for repairing boot problems on any mobile device, unlocking without drilling metal cover on some Motorola phones.
2
SD/MMC CardReader. This slot can be used for low level SD/MMC card formatting/repairing/password reset.
3
Integrated smart card reader - You can use your box as a smartcard reader with any smartcard based software (SETool,Cruiser,Infinity,Vygis, etc)
4
USB Service Port - Can be used as service interface for mobile phones which use USB protocol for service/programming.
5
Integrated USB 2.0 hub with 2 ports. You can connect any other USB device (like MSS4 HASP, UFS Box, USB Drive, USB Dongle, printer, etc)
6
Power: 7.5V (not required for normal operation in most cases). Can be used to power devices which require to be externally powered.
7
PC USB connection port. Used to connect your Box to your PC.:
* Please kindly note, that the color and size of the box may differ.
__________________________________________________ ____
Service Tool for MSS Box II
Description:
Service Tool is used to service, diagnose, tune and activate different features on MSS Box II.
Features:
- Integrated box registration on first run
- Box firmware (bootloader) upgrade
- Box library upgrade
- Hardware testing
- MMC reader mode initiation
- Universal box mode - virtual com port emulation with configurable parameters
- Automatic download and update (when updates are available) of all activated software applications
ODM Service Software for MSS Box II
Features:
- Phone flashing (firmware / language pack / EEPROM / flex (customization areas) at once or separately)
- Flash reading (firmware / language pack / EEPROM / flex (customization areas) at once or separately)
- IMEI change / repair
- Format FMGR
- Read unlocking codes / unlock
- Repair phones with dead / erased boot
- Repair EEPROM
- Repair "Phone hacked"
- Up to 921600 bps communication speed!
Supported models:
- C112, C113, C113a, C115, C116, C117, C118, C121, C122, C123
- C115i, C136, C138
- C139, C140, C141
- C155, C156, C157
- C168, C168i
- C257, C261
- V170, V171, V172, V173
- V175, V176, V177
- W200, W205, W208, W209, W210, W220
- W355, W370, W375
- F3
- L6i (i-Mode)
- L7i (i-Mode)
- MPX200
- MPX220
MSS Software for MSS Box II
Description:
MSS Service Software for MSS Box II is a new generation of MSSv4 software. Developing this new edition, we were thinking about the stability and the ease of use.
Highlights:
MSS Service Software was developed by the authors of PDS repair. We were the first in the world to offer PDS repair to our customers!
The first moto software with SmartDetect ™ function - no need to select model or any parameter, simply powerful and wonderfully easy to use - when you need to unlock, simply press "Unlock" button and the software will do the rest for you!
Unique Diagnostics ™ function which let you to find out why your phone doesn't power on! It can detect 99.9% software problems!
Features:
Important: On our support area we have flash files for all supported models with all language packs, different customizations types & ******* files. Currently it's over 180GB of tested flash files and our database is constantly growing. Daily we upload hundreds of different flash and flex files!
Phone information reading
Phone flashing (including dual processor phones with Symbian (A920,A1000,etc) and Linux (A1200,E2,E6,etc)
Flash reading without testpoint (reflash, *******, language pack, drm, flex, etc)
Phone flexing (with ability to flex media and seem elements separately)
RF Settings read/write
LCD Settings read/write
Battery Settings read/write
Master reset, master clear
User code/security code reset
Band management
Lock to network
Unlock subsidy lock
PDS (security zone) repair
IMEI repair (P2K/LCA/LTE/LTE2/POG)
PDS / BOOT / Full image backup and restore
Repair "Contact provider"
Repair "SW Version: not found"
Repair "Phone code sig error"
Repair "Core corrupt"
Read / write bootloader
Automatic PDS (security zone) backup on each operation
Full backup reading (including bootloader and PDS - security zone)
Full flash erase option
Diagnostics option
The only software that can work with JTAG adapters
Multilingual interface (English, Russian, Arabic, German, Spanish, Greek, Hebrew, Hungarian, Polish, Romanian, Vietnamese)
Supported models:
A-series:
A630, A830, A835, A845, A920, A925, A1000, A1200
C-series:
C250, C260, C266, C268, C330, C331, C332, C333, C334, C335, C336, C350, C350L, C350V, C353, C355V, C359V, C370, C380, C381P, C384, C385, C390, C450, C450L, C550, C650, C651, C975, C980.
E-series:
E1, E2, E3, E6, E370, E375, E378i, E380, E770, E770v, E790, E396, E398, E550, E825,E920, E1000, E1070, E1075
K-series:
K1, K3, K3 (music edition)
L-series:
L2, L6, L6r, L6g, L6i, L7, L7-red, L7i, L7e, L71, L72, L7v, L9
T-series:
T280, T280i, T720, T720i, T721, T722i, T725e
U-series:
U6, U3
V-series:
V60, V60i, V66, V66i, V70, V80, V150, V151, V180, V186, V188, V190 , V190R,V191, V195, V196, V220, V220i, V226, V270, V280, V235, V300, V303, V330, V360, V360v, V361, V365, V400, V500, V501, V505, V525, V525M, V535, V540, V547, V545, V550, V551, V551M, V557, V557P, V560, V600, V600i, V620, V635, V975, V980, V1050, V1075, V1100, V1150
V3, V3L, V3e, V3i, V3ie, V3r (rohs), V3re (V3_06), V3t, V3x, V3x BLUE, V3m, V3xx (incl. V3xx from Cingular/AT&T), V6, V8, V9
Z-series:
Z3, Z3n, Z6, Z8
W-series:
W490, W510
__________________________________________________ ___________
and here u will find how 2 make tp adaptor 4 aragon model like as v3xx
and if u want 2 test ur adaptor
n ServiceTool
I. State "on" check
1) Set "VBATT" to "ON" state, "MBUS" to "OFF" state, BSI to "Z"
state
2) Press "Enter COM port emulation", wait for the "Done, COM port
emulation activated" message
3) Connect adapter to RJ45 port of MSS Box II
3) Check voltage between the needle and GND on the box (for
example on USB connector); It must be 1.8v
II. State "off" check (please reconnect MSS Box II before this
operation)
1) Set "VBATT" to "ON" state, "MBUS" to "ON" state, BSI to "OFF"
state
example on USB connector); It must be 0v
III. Contact line check
1) Make sure line #3 on RJ45 connector has contact with needle.
now ...how u can run ur box in the first time?
u need 2 download last programs
services 1.12
odm 1.10
MSS Service Software 1.24
u will find all here
http://www.actgsm.com/Moha/MssBox/
after u install all, u will conect ur box and u will find the box driver in program file or u can use driver 2.30 here
go 2 MSS Box II Service Tool 1.12 now and make updates and software download
now ur box will make connect with server and u will download ur applet
visit customer center
if u press this option u will automatic login support erea or support forum
u cant login without box connection
1-enter com port....2 make box work universal com
2-enter mmc....u can use it when u put memory card in box ..u can use ur box as reader
u can download all tp images and all cable chimantech and drivers from here
http://www.actgsm.com/moha/mss4/
The Following 7 Users Say Thank You to mohA™ For This Useful Post:
Old 05-29-2008, 23:58   #2 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
now lets start with some odm
as we know thats we will work with some models by t190 cable
u can use ufs cable but we will remove the resistor from it
almost of models work when it turned off
first image u will see in it succes connect with c156
in the left side of program u will see many options
from last option u can login into supprt area
in the next image u will see how u can chang ur box language
in next
u will see how u can use services optins
u can make repire or backup or restore ur eerom
format fmgr so fast so easy here
The Following User Says Thank You to mohA™ For This Useful Post:
Old 05-30-2008, 00:04   #3 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
easy way 4 unlock all odm here in few sc
l6imode unlock
c123 unlock
u will conect this model in powerd on and type no as c117 -**16379#
choice track and modem on
connect phone under model name -c115/c118tf
unlock now will be easy
in dump option u can save backup from ur phone flash
u will see in next image succesfull flash 4 c157
i think thats enough tonight
will be complet tomorow
br
mohA™
The Following 5 Users Say Thank You to mohA™ For This Useful Post:
Old 05-30-2008, 00:10   #4 (permalink)
Momo_Gsm's Avatar
Member: 755709
Sonork: 100.1592000 Momo...
Thanks Meter: 6,635
i think this box is perfect on working mtorola phones
Old 05-30-2008, 00:23   #5 (permalink)
Member: 683463
Thanks Meter: 188
yes mss2 the best box for motorola
The Following User Says Thank You to yunaced For This Useful Post:
Old 05-30-2008, 00:54   #6 (permalink)
Member: 85718
Thanks Meter: 448
This is a 5 ***** box
Old 05-30-2008, 01:12   #7 (permalink)
saiftc2's Avatar
Member: 231662
Sonork: 1607488
Thanks Meter: 390
best box .... for mororal ..
thanx mr.moha
GsmJoman
Tc
Old 05-30-2008, 03:06   #8 (permalink)
Orange_Dominica's Avatar
Member: 88701
Thanks Meter: 381
Your Work...well organized and easy to understand.
Can you show a screen where you are flashing an ODM phone from a DUMP image ?
I think this DUMP operation is better than sliced bread...no need to Load Main,Flex and LP ..just select your image from dump and flash.
No other ODM box supports this.
Also congrats for coming out of the dark ages and re introducing your product to the masses via this forum...as it was very hard to get questions answered involving MSS in the past....now we can talk to the actual users and get needed feedback.
MSS is on the MOVE
;smokin
Old 05-30-2008, 20:34   #9 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
MSS is on the MOVE
;smokin
better than sliced bread u r funny mate
if u want 2 talk about this box ..just say thats the best tool 4 moto in the world
yes sure its from dark ages and will be here and will still the best in the future
u can see here the dump flash how u can reflash with it
u can save all part u want..not one image
and victor not need 2 be here in this forum..he own his great forum &support and no one have this box cant get help any time from him
Old 05-30-2008, 22:26   #10 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
How we can unlock &flash &repair another models
we will see here how u can flash & unlock all models
first with v3ie
its better 2 connect ur phone without battary
original cable come with box is powred cable..so ,u wont need battary
just connect ur phone without battary and wait it turned on
u will see phone info like as last image
u will see original imei
platform type
hw version
sw version
boot
flex
language packeg
phone model
lock status
user code &security code
we see lock statu is lock
and language not arabic
so,we will make some changes here
sw version is very important
u must check it before flashing the phone
in this phone we see thats sw version is r3443u5
we have many model version under v3i name
if u try with another v3i sw file ,ur phone will dead or go 2 blank screen or bootloader show only..
after model version name we will check the version g-0e-c8.0dr
if u will flash with monester flash-ff-or language file only..its not important 2 flash with higher version ..u can flash with same or make downgrade..its so easy..
but in normal flash file-reflash- must be same version or higher
in this image we will see how flash is runing
we will add language file only
in dump option we will save backup from phone flash
u can backup language only or flex or drm
or save full flash -monester(firmeware+lp+drm+flex)
4 this model v3ie we will make tp 2 can make unlock
now after tp phone unlocked in 2sc
see the log info now
br
mohA™
The Following 2 Users Say Thank You to mohA™ For This Useful Post:
Old 05-30-2008, 22:32   #11 (permalink)
Member: 758509
Thanks Meter: 8
You are using old version?
Old 05-31-2008, 17:46   #12 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
yes
it was the last version when i was wrote this topic first time
Old 05-31-2008, 19:46   #13 (permalink)
Member: 758509
Thanks Meter: 8
Originally Posted by mohA™ View Post
yes
Topic written yesterday, MSS 1.21 from last year
1.22, 1.23 and 1.24 are newer.
Old 05-31-2008, 23:02   #14 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
i didnt say thats im posted here from some month
but what about another forum
and whats problem here plz?
br
mohA♥
Old 06-01-2008, 00:11   #15 (permalink)
jamal2010's Avatar
Member: 243827
Sonork: 100.1583557
Thanks Meter: 247
I Like this Box verry gooood in motorola first in the world
Page generated in 0.35265 seconds with 9 queries
