Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > MSS Box II
Old 05-19-2008, 22:37   #1 (permalink)
Z-RocK's Avatar
Member: 294953
Sonork: 100.1576570
Thanks Meter: 230
[Info] What is MSS BOX II ? [info]
MSS Box II is a new generation box from the producers of MSS3 and MSS4 solutions.
With MSS Box II you get universal communication device for servicing electronic equipment (including mobile phones) and modern platform for protection of all released and future developed software products. This small box incorporates all our experience inside and extremly easy to use!
- Built on a modern highly secured platform - In future can be easily upgraded with the use of a smart card.
- You can purchase any our software as activation for this box. Activation is done online and takes several seconds.
- High speed USB 2.0 chip - use a full speed flashing for your mobiles!
- Multiplatform support - built to work on different platforms. Service Motorola, Sony Ericsson, Nokia, Samsung, LG, Sharp or any other mobile phone with ease! (FBUS,MBUS,USB,RS232,JTAG are supported)
- Multiapplication support - use different programs on one box
- 3rd party application support - can be used as universal box to work with the solutions developed by other companies
- Unlimited unlocking - the most safe unlocking methods, have your phone unlocked in seconds with no damage to phone (no dead phones, no erased phonebooks, no problems after unlocking)
- Repairing - got a dead phone? MSS Box II will try to repair any dead phone you might have.
- Flashing - the most reliable flashing software with direct USB-to-phone communication makes sure that the phone will be flashed safetly and quickly. MSS Box II can flash both GSM and 3G phones!
- Band management (unlocking) - it may happen that your phone is dual/tri/quand band, but some bands are locked and unsuable
- MSS Box II will easily unlock all locked bands.
- User code reset / Security code reset
- Read phone information, including GPS chipset version, AP/BP versions
- Unlock browser and WAP settings
- Java uploading
- Europe->Asia, Asia->Europe flashing (for phones like C450, C550 etc)
Box Service Tool
This software is used to register, configure and service the box.
MSS Service Software
New generation of Motorola software for MSS Box II.
ODM Service Software
Motorola ODM service software for MSS Box II. Allows you to service phones like C115, C139, C155 and etc.
MotoIMEI Service Software
Software to restore (repair) IMEI on Motorola phones.
ODM IMEI Service Software
Software to restore (repair) IMEI on ODM Motorola phones.
Hardware specification:
- Dimensions: (LxHxW) 70x33x70mm
- Weight: 120 gramm
- Power: 7.5V (not required for normal operation in most cases)
- USB hub: 2 ports, builtin
- Smartcard reader: 1 internal (for box upgrade), 1 external (for use with 3rd party software which uses smartcards)
- MMC reader: builtin
- USB service port: available
- RJ45 port: available
- JTAG enabled: yes
Ports description:
1
Universal RJ45 configuration port - Configurable Virtual COM port mode. You can configured this connector as high-speed COM-port or any GSM product communication devices or special cable - Vygis box, Infinity box, Cruiser box, SETool box, Cruiser USB UC-10 Cable and etc.
Can also be used as configurable JTAG interface. For low level programming. Can be used for repairing boot problems on any mobile device, unlocking without drilling metal cover on some Motorola phones.
2
SD/MMC CardReader. This slot can be used for low level SD/MMC card formatting/repairing/password reset.
3
Integrated smart card reader - You can use your box as a smartcard reader with any smartcard based software (SETool,Cruiser,Infinity,Vygis, etc)
4
USB Service Port - Can be used as service interface for mobile phones which use USB protocol for service/programming.
5
Integrated USB 2.0 hub with 2 ports. You can connect any other USB device (like MSS4 HASP, UFS Box, USB Drive, USB Dongle, printer, etc)
6
Power: 7.5V (not required for normal operation in most cases). Can be used to power devices which require to be externaly powered.
7
PC USB connection port. Used to connect your Box to your PC.
The Following 19 Users Say Thank You to Z-RocK For This Useful Post:
Old 05-19-2008, 22:38   #2 (permalink)
Z-RocK's Avatar
Member: 294953
Sonork: 100.1576570
Thanks Meter: 230
Flashing & Servicing:
A-series: A1000, A830, A835, A845, A920, A925, A630
C-series: C975, C980, C385, C650, C550, C450, C450L, C380, C250, C260, C266, C236, C350L, C350V, C355V, C353, C370, C359V, C350, C330, C331,C332, C333, C334, C335, C336
V-series: V235, V3x, V3i, V3r, V360, V360v, V190, V185, V186, V188, V330, V975, V980, V505, V551, V551M, V535, V545, V550, V3, V620, V525M, V557, V547, V80, V220, V226, V180, V300, V303, V400, V400p, V500, V500m, V525, V600, V150, V66, V66e, V66m, V60, V70, V71, V60i, V66i.
E-series: E1, E790, E770v, E1000, E398, E398B, E550, E396, E390, E370, E380
T-series: T720, T720i, T722i, T721i, T280, T280m, T280i
U-series: U6
L-series: L6, L7
Online unlocking: (unlock time is 10-30 seconds depending on the model)
Special: MPX200, MPX220 Code Reading
A-series: A1000, A830, A835, A920, A925, A630
C-series: C975, C980, C385, C650, C380, C550, C450, C450L, C370, C250, C260, C266, C236, C350L, C350V, C355V C353, C359V, C350, C330, C331, C332, C333, C334, C335, C336
V-series: V235, V3x, V3i, V3r, V360, V360v, V190, V185, V186, V188, V330, V975, V980, V505, V551, V551M, V535, V545, V550, V3, V620, V525M,V557, V547, V80, V220, V226, V180, V300, V303, V400, V400p, V500, V500m, V525, V600, V150, V66, V66e, V66m, V60, V70, V71, V60i, V66i
U-series: U6
L-series: L6, L7
The Following 6 Users Say Thank You to Z-RocK For This Useful Post:
Old 05-19-2008, 22:42   #3 (permalink)
kaligola's Avatar
Member: 239318
Thanks Meter: 51
wellcome in this support section
glad to see everlasting product here!
The Following 2 Users Say Thank You to kaligola For This Useful Post:
Old 05-20-2008, 18:17   #4 (permalink)
v11
v11's Avatar
Member: 214827
Sonork: 100.1597158
Thanks Meter: 59
............................ V8 Not Suported?.....................
The Following User Says Thank You to v11 For This Useful Post:
Old 05-20-2008, 19:20   #5 (permalink)
Z-RocK's Avatar
Member: 294953
Sonork: 100.1576570
Thanks Meter: 230
MSS Software for MSS Box II
Description:
MSS Service Software for MSS Box II is a new generation of MSSv4 software. Developing this new edition, we were thinking about the stability and the ease of use.
Highlights:
MSS Service Software was developed by the authors of PDS repair. We were the first in the world to offer PDS repair to our customers!
The first moto software with SmartDetect ™ function - no need to select model or any parameter, simply powerful and wonderfully easy to use - when you need to unlock, simply press "Unlock" button and the software will do the rest for you!
Unique Diagnostics ™ function which let you to find out why your phone doesn't power on! It can detect 99.9% software problems!
Features:
Important: On our support area we have flash files for all supported models with all language packs, different customizations types & ******* files. Currently it's over 180GB of tested flash files and our database is constantly growing. Daily we upload hundreds of different flash and flex files!
Phone information reading
Phone flashing (including dual processor phones with Symbian (A920,A1000,etc) and Linux (A1200,E2,E6,etc)
Flash reading without testpoint (reflash, *******, language pack, drm, flex, etc)
Phone flexing (with ability to flex media and seem elements separately)
RF Settings read/write
LCD Settings read/write
Battery Settings read/write
Master reset, master clear
User code/security code reset
Band management
Lock to network
Unlock subsidy lock
PDS (security zone) repair
IMEI repair (P2K/LCA/LTE/LTE2/POG)
PDS / BOOT / Full image backup and restore
Repair "Contact provider"
Repair "SW Version: not found"
Repair "Phone code sig error"
Repair "Core corrupt"
Read / write bootloader
Automatic PDS (security zone) backup on each operation
Full backup reading (including bootloader and PDS - security zone)
Full flash erase option
Diagnostics option
The only software that can work with JTAG adapters
Multilingual interface (English, Russian, Arabic, German, Spanish, Greek, Hebrew, Hungarian, Polish, Romanian, Vietnamese)
Professional support
ESN repair (CDMA)
Supported models:
A-series:
A630, A830, A835, A845, A920, A925, A1000, A1200
C-series:
C250, C260, C266, C268, C330, C331, C332, C333, C334, C335, C336, C350, C350L, C350V, C353, C355V, C359V, C370, C380, C381P, C384, C385, C390, C450, C450L, C550, C650, C651, C975, C980.
E-series:
E1, E2, E3, E6, E370, E375, E378i, E380, E770, E770v, E790, E396, E398, E550, E825,E920, E1000, E1070, E1075
K-series:
K1, K1s, K3, K3 (music edition)
L-series:
L2, L6, L6r, L6g, L6i, L7, L7-red, L7i, L7e, L71, L72, L7v, L9
T-series:
T280, T280i, T720, T720i, T721, T722i, T725e
U-series:
U6, U3
V***x-series:
V1050, V1075, V1100, V1150
V***-series:
V150, V151, V180, V186, V188, V190 , V190R, V191, V195, V196, V220, V220i, V226, V270, V280, V235, V300, V303, V330, V360, V360v, V361, V365, V400, V500, V501, V505, V525, V525M, V535, V540, V547, V545, V550, V551, V551M, V557, V557P, V560, V600, V600i, V620, V635, V975, V980
Vxx-series:
V60, V60i, V66, V66i, V70, V80
Vx-series:
V3, V3L, V3e, V3i, V3ie, V3r (rohs), V3re (V3_06), V3t, V3x, V3x BLUE, V3m, V3xx (incl. V3xx from Cingular/AT&T), V6, V8, V9
Z-series:
Z3, Z3n, Z6, Z8
W-series:
W490, W510, W5
CDMA-series:
V9m, Z6m, Ve (V6 MAXX), C305, C364, V710, A840, K1m, V3c, V3m, L7c, E815, E816, V260, V262, V265, V266, V267, V276, V323, V323i, V325, V325i
The Following 5 Users Say Thank You to Z-RocK For This Useful Post:
Old 05-20-2008, 19:21   #6 (permalink)
Z-RocK's Avatar
Member: 294953
Sonork: 100.1576570
Thanks Meter: 230
ODM Service Software for MSS Box II
Features:
- Phone flashing (firmware / language pack / EEPROM / flex (customization areas) at once or separately)
- Flash reading (firmware / language pack / EEPROM / flex (customization areas) at once or separately)
- IMEI change / repair
- Format FMGR
- Read unlocking codes / unlock
- Repair phones with dead / erased boot
- Repair EEPROM
- Repair "Phone hacked"
- Up to 921600 bps communication speed!
Supported models:
- C115-TF, C118-TF, C139-TF
- C115-Cin, C118-Cin, C139-Cin
- C112, C113, C113a, C115, C116, C117, C118, C121, C122, C123
- C115i, C136, C138
- C139, C140, C141
- C155, C156, C157
- C168, C168i
- C257, C261
- V170, V171, V172, V173
- V175, V176, V177
- W200, W205, W208, W209, W210, W220
- W215, W218
- W355, W370, W375
- W377
- F3
- L6i (i-Mode)
- L7i (i-Mode)
- MPX200
- MPX220
- SE J110i
The Following 3 Users Say Thank You to Z-RocK For This Useful Post:
Old 06-13-2008, 17:17   #7 (permalink)
SEMEN's Avatar
Member: 333494
Sonork: 100.1607053
Thanks Meter: 190
Thanks to all users but may be som one have manual to use with this box?
i whant to bay this box but before i whant to see if its hard to use or no.
Thanks.
B.R.,
semen
The Following User Says Thank You to SEMEN For This Useful Post:
Old 06-13-2008, 23:25   #8 (permalink)
Member: 758509
Thanks Meter: 8
Thanks.
B.R.,
semen
Official manual from MSS Team is located here: http://www.mssbox.com/v2/manual/
The Following 4 Users Say Thank You to Ghost555Ghost For This Useful Post:
Old 06-13-2008, 23:50   #9 (permalink)
jamal2010's Avatar
Member: 243827
Sonork: 100.1583557
Thanks Meter: 243
verrry gooood box for motorola
Old 06-21-2008, 22:50   #10 (permalink)
Member: 367870
good afternoon friends of the forum, some of friends know me if you can repair the imei of V3re boot file 0C.C1 with MSS Box? grateful to all
Old 06-23-2008, 17:47   #11 (permalink)
treo29's Avatar
Member: 279394
Sonork: 1591760
Thanks Meter: 90
excellent
thankz
br
treo29
Old 06-24-2008, 06:19   #12 (permalink)
kalixhe's Avatar
Member: 567269
Thanks Meter: 19
ok good good good
thenks
caliche team
The Following User Says Thank You to kalixhe For This Useful Post:
Old 06-24-2008, 06:34   #13 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,045
manual in supprt area.....just visit....nice tool to work for motrola...i like it
Old 07-10-2008, 06:15   #14 (permalink)
Member: 420244
Thanks Meter: 41
goooood exelent boxs !!!
Old 07-10-2008, 06:58   #15 (permalink)
Chandreshswami's Avatar
Member: 370998
Sonork: 100.1582579
Thanks Meter: 218
welcome to support section
looking sound for motorola
waht about cost and reseller in india?
The Following User Says Thank You to Chandreshswami For This Useful Post:
NEED Main MSS Software for MSS Box II...... rumenshom MSS Box II 15 11-30-2017 03:05
what is CPF-BOX II sharaz191 CPF-BOX Ⅱ 4 09-06-2010 14:52
MSS Box II with MSS & ODM activations for only 329$! Also you can unlock W205&W208! VictorGSM Main Sales Section 0 11-16-2007 16:40
MSS box II - really tricky idea from MSS TEAM ! PBB Lover The Market Feed Back 31 07-03-2007 15:04
Christmas price for mss4 with no test point unlock feature And MSS BOX II announcemen VictorGSM Main Sales Section 0 12-12-2006 00:15
Page generated in 0.45017 seconds with 8 queries
