Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > MSS Box II
Old 05-10-2010, 01:57   #1 (permalink)
Member: 352414
v3re unlocking problem
hi friends i have problem v3re unlocking
[7:11:15 PM 1.28] MSS Service Software for MSS Box II - version 1.28 - MSS Box II - Mobile phones unlocking, flashing, repairing and servicing.
[7:11:15 PM 1.28] Session started 5/9/2010
[7:11:15 PM 1.28] Box UID:xxxxxxxxxxx connected
[7:11:18 PM 1.28] Phone connected in normal mode
[7:11:18 PM 1.28] IMEI: 352476xxxxxxxx, R3442A_G_0E.43.25R, GSVV3xx06TMB01NA120..., Boot:Unknown, LP:0003, Motorola Phone (V3re), Locked 001 - 01
[7:14:36 PM 1.28] [7:14:36 PM] Unlocking started - MSS Service Software ver. 1.28 - R3442A_G_0E.43.25R, Boot:Unknown
[7:14:36 PM 1.28] Switching phone to flash mode...
[7:14:43 PM 1.28] Reading data...
[7:14:53 PM 1.28] Phone is powered off
[7:14:53 PM 1.28] If phone will not power up within 10 seconds, please, reconnect phone cable (and battery if used). If phone will not power up after this, turn on phone in flash mode manually (*, #, PWR)
[7:15:15 PM 1.28] Phone found. Continue...
[7:15:15 PM 1.28] Switching phone to flash mode...
[7:15:27 PM 1.28] Loading RAM Downloader...
[7:15:31 PM 1.28] Erasing flash memory...
[7:15:32 PM 1.28] Flashing started
[7:15:35 PM 1.28] Phone is powered off
[7:15:37 PM 1.28] Please disconnect phone and connect battery hook (adapter version 3) and not powered (original) USB cable
[7:15:40 PM 1.28] Phone found. Continue...
[7:15:40 PM 1.28] Please connect special testpoint
[7:15:59 PM 1.28] Please hold testpoint connected...
[7:16:01 PM 1.28] Please disconnect special testpoint
[7:16:03 PM 1.28] Flash type: Tyax 16 bit, size - 32 Mb
[7:16:03 PM 1.28] Backing up PDS area...
[7:16:07 PM 1.28] Unlocking started...
[7:16:12 PM 1.28] Critical Error: 159!
[7:16:12 PM 1.28] [7:16:12 PM] Error - 40%
[7:16:12 PM 1.28] C:\Program Files\MSS_II_Box\MSS\Backups\Auto\PDS_IMEI35247602 746746_SN091B191B04101420_09.05.10_19.16.mbc
Old 05-10-2010, 01:58   #2 (permalink)
shoktong's Avatar
Member: 461188
Sonork: 1587510
use not powerd cable
wbr
shoktong
Old 05-10-2010, 02:43   #3 (permalink)
xannix_7575's Avatar
Member: 847117
when SW ask for a TP
remove first your BATT / supply
connect the red wire (supply) from your RJ45 to positive of your phone
now,
connect the TP and follow instruction
wait until done..
Old 05-10-2010, 03:54   #4 (permalink)
Member: 683463
yes don't use service cable ordinary v3 cable i got that problem when i unlock w490
Old 05-10-2010, 21:18   #5 (permalink)
Member: 352414
this what i get allway 3:09:44 PM 1.28] Please connect special testpoint
[3:10:10 PM 1.28] Error occured. Please reconnect THIS phone to retry
[3:10:25 PM 1.28] Phone found. Continue...
[3:10:35 PM 1.28] Error occured. Please reconnect THIS phone to retry
[3:10:46 PM 1.28] Phone found. Continue...
[3:10:56 PM 1.28] Error occured. Please reconnect THIS phone to retry
[3:11:06 PM 1.28] Phone found. Continue...
[3:11:24 PM 1.28] Error occured. Please reconnect THIS phone to retry
[3:12:12 PM 1.28] Phone found. Continue...
[3:13:45 PM 1.28] Error occured. Please reconnect THIS phone to retry
[3:15:12 PM 1.28] Phone found. Continue...
[3:15:57 PM 1.28] Error occured. Please reconnect THIS phone to retry
i am not new with tp connecting i unlock many phones
Old 05-22-2010, 16:26   #6 (permalink)
Member: 671754
i had the same problem how so do i connect complete the the process always saying 40% error even i used not power usb. and another thing dat i notice is when i connect the red tp adaptor make a phone batt low indicator maybe that would be the problems why i cant unlock. anyone can explain the error?
Old 05-22-2010, 20:36   #7 (permalink)
G$m
G$m's Avatar
Member: 995280
Sonork: 100.1582835
try this way worked with me
v3 Edge Unlocking Problem Please check all
BR. Zalhaf
Old 07-10-2010, 09:24   #8 (permalink)
Member: 1340542
Sonork: abcdslu
may be that phone is grounded
Old 07-24-2010, 06:05   #9 (permalink)
Member: 390137
@ uburo22 I have experienced some issues with my mssbox, here are some reasons that can make it work wrong, if you're telling that you have experience unlocking with mss box
1. PC power supply, use one with more watts
2. Bad RJ-45 connection, check cable and box conector and clean both, if you have an RJ-45 crimper then use it
3. Bad USB PC to box connection check cable
4. If your box isn't in warranty open it and check for cold solder in the USB and RJ-45 connectors
5. Check fuses and transistors next to USB connectors in mss box board
and replace them if need it
6. Check cold solder in mss testpoint cable
Old 07-27-2010, 02:13   #10 (permalink)
Member: 1340542
Sonork: abcdslu
sir that is tespoint I cant show the picture i dont have camera
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 07-09-1999 22:08
Page generated in 0.50746 seconds with 11 queries
