Service Products News & Updates Service Products and Tools New and Updates |
01-30-2015, 15:18 | #1 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | ATF EMMC Pin Finder v11.90 Update!! 30 JAN 2015!! Firmware Version Required : 11.0.10 ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit) ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit) [New ATF Box Firmware] LogiCore 11.0.10 * Added FIRST-IN-THE-WORLD eMMC Test Point Finder/Locator Engine * Improved eMMC Read/Write Speeds * Added more VCCIO Level Adjustments options [ATF Plus] * Added Find eMMC TP - eMMC Test Point Finder 1.0 * Absolutely FIRST-IN-THE-WORLD Feature which allows you to Locate the eMMC Programming Test Points WITH-OUT Removing the eMMC Chip from the PCB. * Supports Qualcomm, Marvell PXA and Broadcom CPU for CMD and CLK Detection * Supports Exynos for CLK Test Point Detection * Other CPUs will be supported soon For More Information, Check here: http://forum.gsmhosting.com/vbb/f609.../#post10829268 [GENERAL UPDATES] --> Added all variants of Microsoft Lumia 330 in Nokia.ini ******************************* ATF JTAG 1.0.13 Build 5935 ******************************* Release Date: January 30, 2015 Firmware Version Required : LogiCore 11.0.10 Change Log --> Uses new ATF Firmware LogiCore 11.0.10 --> Adjusted eMMC Read/Write Timeouts |
The Following 128 Users Say Thank You to gsmfun For This Useful Post: |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f475/atf-emmc-pin-finder-v11-90-update-30-jan-2015-a-1909412/ | ||||
Posted By | For | Type | Date | |
Thread Atf problem after v11.92 Update | GSM-Forum | BoardReader | This thread | Refback | 06-13-2015 08:59 | |
ATF EMMC Pin Finder v11.90 Update!! 30 JAN 2015!! - GSM-Forum | This thread | Refback | 02-16-2015 18:27 | |
ATF EMMC Pin Finder v11.90 Update!! 30 JAN 2015!! | GSM News | This thread | Refback | 02-14-2015 18:48 | |
ATF EMMC Pin Finder v11.90 Update!! 30 JAN 2015!! | This thread | Refback | 02-02-2015 01:17 |
