Service Products News & Updates Service Products and Tools New and Updates |
12-11-2012, 18:52 | #1 (permalink) |
No Life Poster Join Date: Jan 2003 Location: CDMA-WARE
Member: 20073 Status: Offline Thanks Meter: 250 | CDMA Workshop v3.9.0 - Powerful CDMA/GSM service software CDMA Workshop [3.9.0] (09-Dec-2012) - video overview on YouTube [+] Added new tool "pESN -> MEID bruteforcer" (Menu - Tools). MEID and pESN must be matching each other in CDMA devices, otherwise they will not work properly. It is not possible to retrieve exact original MEID value from the known pESN. But we can find (via bruteforce attack) any other MEID value that will match our pESN. This function is sometimes very useful when re-flashing MEID-based CDMA devices in ESN-based networks. Take less than a minute and it will find a correct MEID for you [+] Added support of Alternate way of access to EFS_RAW. Now all "EFS_RAW" methods in CDMA Workshop support and automatically detect both standard and Alternate ways to access to EFS_RAW. As a result, you will additionally be able to operate with more devices where "Alternate" way is used, for example: Huawei 3G Mobile WiFi (MiFi) E585, E5832, E5830, E583C, etc [+] Added new access type to a memory - "RAM_3A" method ("Memory" section - "Memory" tab). The access type to a memory which is only available in Download Mode and in devices with download protocol version 6 or greater. This method is mostly supported by newer devices, just for example: Novatel modems/routers PC770, C777 (Merlin), U720, U727, U760, MiFi2200, etc.. Huawei M635, M735.. Kyocera S3015 Brio.. GSM phones Sony XPeria X2, LG Optimus Elite, etc). You can use this method and then extract SPC, EVDO logins, passwords, etc from the resulting dump using "Keyboard codes searcher" [+] Added new universal method to read SPC - "Universal RAM_3A" method ("Security" tab - "SPC" section). See supported models in the above point [+] Added new universal method to read CAVE keys - "Universal RAM_3A" method ("CAVE" tab - "CAVE" section). This method has the same power and universality as "Universal EFS_RAW" method in "SPC" section, will work for the same models, but just intended to read authentication keys A-key, SSD_A, SSD_B instead of security codes. This method uses heuristic algorithms and as a result supports both structures of system files in EFS, older and newer, thus you will be able to operate with even older models also [+] New "A-key checksum calculator" ("CAVE" section). It now supports MEID-based devices (only for CDMA Workshop users). You can now manually program A-key via keypad on many of MEID-based devices where checksum based on pESN does not work (ex. all HTC smartphones) [+] Updated BlackBerry security codes calculator (SIM-lock) with 12 new MEPs to support newest latest Blackberry smartphones: MEP-12599-004, MEP-12907-003, MEP-17568-004, MEP-24660-002, MEP-26490-001, MEP-26900-001, MEP-27501-002, MEP-27559-001, MEP-27561-001, MEP-29080-001, MEP-40488-001, MEP-46976-001 (275 MEPs totally supported) [+] Added Pantech models security codes (NCK) calculator (Menu - Tools). Supported models: Pantech P1010, P2000 Breeze, P2020 Ease, P7040 Link, P7000 Impact, P8000 Crossover, P9020 Pursuit, P9050 Laser, C600, C610, C740 Matrix, C790 Alladin Duo, C810 Duo, C820 Matrix Pro, P6010, P5000, P7040P, P2030 Breeze III, etc [+] Added Doro models security codes (NCK) calculator (Menu - Tools). Supported models: Doro 345 GSM, PhoneEasy 345, 409, 409s, 410, 410s, 610, 610s, etc [+] Added Alcatel models security codes (NCK, SPCK) calculator (Menu - Tools). Supported models: - Alcatel V670, C700, C701, Playboy, C707, C717, Elle N3 - Alcatel V770, C820, C825, Mandarina Duck - Alcatel S215, S218, S319, S320, S321 - Alcatel S520, Miss Sixty - Alcatel S853 [+] "Test SPC codes" dialog is now directly accessible in Menu - Tools. We also improved it: you can now load files by right mouse click pop-up menu. All probable 6-digits SPC codes will be automatically found and extracted for testing [+] Added new function "Keypad emulator" ("Keypad" page - "Other" tab) [+] Added new function "Display capture" ("Display" page - "Other" tab) [+] Added new 16-digit passwords for Samsung R860 Caliber (MEID/pESN, SPC, A-key) [+] Added ability to do full rebuild on many of Novatel/Merlin modems (ex. Novatel S620, S720, PC770, C777 (Merlin), MiFi2200, etc). See "Rebuild" section - "Other" tab. Network settings, security codes will be reset to factory values. This function can recover damaged modems [+] Updated "nv_skip_list.txt" file with new models: Samsung U810 Renown, R350 Freeform [+] Added "get battery level" AT-commands script [+] New nice and functional "About" window with new nice logo [!] Fixed all reported and found till now bugs and defects [*] Buy original - get quality and benefits |
The Following 34 Users Say Thank You to Pluton For This Useful Post: |
