GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Service Products News & Updates (https://forum.gsmhosting.com/vbb/f475/)
-   -   eMMC Pro V1.09 / Samsung eMMC CID Patch , Re-Partition , Dead eMMC Firmware [ LOTS ] (https://forum.gsmhosting.com/vbb/f475/emmc-pro-v1-09-samsung-emmc-cid-patch-re-partition-dead-emmc-firmware-lots-2231317/)
Electroboys 06-05-2017 13:27
eMMC Pro 1.09 Release Notes
[5 JUNE 2017]
Release Notes and Discussion
We are trying to make more powerful eMMC software with every each update
There are alof of optimizations and progress based on customers requests and demands.
  1. # Detection Routines improved .
  2. # Samsung eMMC Firmware Update ( FFU Update )
  3. # Samsung eMMC Firmware Read
  4. # Qualcomm Disk with eMMC Booster interface selected
  5. # Samsung eMMC Boot Resize ( Partition )
  6. # Samsung eMMC RPBM Resize ( Partition )
  7. # eMMC BOOT CFG Setup
  8. # Samsung eMMC CID Writing / Patch
  9. # MTK Preloader.bin CID Parsing for the UI
  10. # UI - Selection of BOOT Size : 1MB to 8MB
  11. # UI - Selection of RPMB Size : 128KB to 1024KB
  12. # UI - Selection BOOT Configuration
  13. # UI - CID Write Module
  14. # UI - CID Load from preloader.bin
  15. # UI - Firmware list with Upgrade and Read options
  16. # New Firmware Released Version = 2017052915210004
When you first run eMMC Pro V1.09 sw will update your firmware .
With the new firmware we have implemented better detection and more features.
and makes it more stable and alot more powerful with more powerful features.
[Samsung eMMC Firmware Update]
Vendor CMDs and sequences implemented in order to update and repair Dead eMMCs
Solution for the known problems :
  • Brick boot
  • Boot Loop
  • SD Mounting Problems
  • E:failed to mount /data (No such file or directory)
  • ODIN Flashing failed on PIT known as PIT Failed.
  • Complete(Write) operation failed.
Firmware List :
KLM4G1FE3B-B001
KLM8G1WE4A-A001
KLM8G1WEMB-B011
KLM8G1WEMB-B031
KLM8G2FB3B-D001
KLM8G2FB3B-D001
KLM8G2FE3B-B001
KLM8G2YE4C-C001
KLMAG2GE2A-A001
KLMAG2GE4A-A001
KLMAG2GE4A-A002
KLMAG2GEAC-B001
KLMAG2GEAC-B002
KLMAG2WE4A-A002
KLMAG2WEMB-B031
KLMAG4FE4B-B002
KLMAG4FEAB-B002
KLMBG4GE4A-A001
KLMBG4GEAC-B001
KLMCG8GE4A-A001
KMJ5U000WA-B409
KMJ5U000WM-B409
KMJJS000WA-B409
KMJJS000WM-B409
KMK2U000VM-B604
KMK3U000VM-B410
KMK5U000VM-B309
KMK5W000VM-B312
KMK5X000VM-B314
KMK5X000YM-B314
KMK7U000VM-B309
KMK7X000VM-B314
KMK8U000VM-B410
KMKJS000VM-B309
KMKTS000VM-B604
KMKUS000VM-B410
KML5U000HM-B505
KMN5U000ZM-B203
KMN5W000ZM-B207
KMN5X000ZM-B209
KMN9W000RM-B203
KMNJS000ZM-B205
KMS5U000KM-B308
KMS5X000KM-B313
KMSJS000KA-B308
KMSJS000KM-B308
KMV2W000LM-B506
KMV3U000LM-B304
KMV3W000LM-B310
KMVIS000LM-B503
KMVTU000LM-B503
KMVUS000LA-B304
KMVUS000LM-B304
KMVWU000LM-B900
KMVYL000LM-B503
[Samsung eMMC Firmware Read:]
You can read Samsung eMMC Firmware's in case you have New Samsung eMMC in your hand which is not supported !
[Qualcomm Disk with eMMC Booster:]
When there is a Qualcomm disk is connected you can choose eMMC Booster on the interface and write proper dump for it.
eMMC Pro Software handle the procedures directly into Qualcomm Disk !
[Samsung eMMC Boot Resize ( Partition ) :]
Re-Configuring BOOT1 , BOOT2 , RPMB
Configuring Partition Sizes is important if you do not have matching eMMC for another device .
[Solution for :] MTK Devices or any Device for this matter should be able to match the original device (eMMC Configuration ) will let the device work properly .
[eMMC BOOT CFG Setup :]
BOOT Configuration Setup Device (eMMC) to boot in particular Area of the
  • Device
  • BOOT1
  • BOOT2
  • USER Area
  • No Boot
[Samsung eMMC CID Writing / Patch :]
Writing any CID into device will help you configure Samsung eMMCs into any eMMC !
For ex : Hynix CID into Samsung eMMC to act as Hynix eMMC
Solution for : Many MTK Mobile phones with unique CID determined !
[MTK Preloader.bin CID Parsing for the UI ]
Parse the preloader.bin and select in order to make it compatible eMMC CID .
[UI Definitions :]
[BOOT Size : ]
You can select the BOOT Size that you want to configure
1MB , 2MB , 4MB , 8MB
[RPMB Size: ]
You can select the RPMB Size that you want to configure
128KB , 256KB , 512KB , 1024KB
[BOOT Configuration : ]
User selects boot data that will be sent to device
  • Device not boot enabled (default)
  • Boot partition 1 enabled for boot
  • Boot partition 2 enabled for boot
  • User area enabled for boot
[CID Write Module: ]
CID Box acts as Combobox when selected a preloader.bin
Modify and write the require CID into Device .
[CID Load from preloader.bin: ]
Small Button with [+] Loads the preloader.bin and parse into Combobox you to select !
[Upgrade Firmware : ]
It will write selected firmware into eMMC
eMMC ID should match with the Firmware otherwise writing process will fail or will not work .
[ New Firmware : 2017052915210004 ]
  • Box Firmware with New Functions and CMDs implemented .
Thank you for all eMMC Pro Customers to keep sending us requests and suggestions .
There is a lot more to come
Best Regards
eMMC Pro Team
Advanced eMMC Repair
eMMC PRo - Universal Device Programmer
Page generated in 0.08156 seconds with 6 queries
