Service Products News & Updates Service Products and Tools New and Updates |
07-17-2012, 16:39 | #1 (permalink) |
Product Supporter Join Date: Mar 2005 Location: in CPU
Member: 128745 Status: Offline Thanks Meter: 16,936 | Infinity Nokia BEST Version 1.48 released !! Discussion HERE Whats New - USB flashing improved - BB5 USB loaders updated - MSM72x flashing (Lumia 610) was broken on previous release, fixed - Added ASIC check for BB5, from now not possible flash wrong firmware (e.g. RAP4 to BCM and others) - Maemo/Meego flashing revised, work now on XP without problems - Maemo (N900) error handling added (if will be errors, like CMT,APE, e.t.c. faults, BEST show reasons and way to fix them) - RPL reading during flash improved for XG213 - MeeGo eMMC only flash improved - MeeGo USB loader updated - Service operations improved - Improved XG213 RPL reading - Added SelfTest option for Lumia series (battery/power/e.t.c diagnostic) - Fixed hang during PM read/write on some models - During Cam Check/Repair also will be done HW check (Detect HW fault, show reasons of error) - For CNT reset added default SL tables for XG213 phones (replace/repair damaged tables, CS repair after bad reset) - XG110/DCT4+ reset user code improved ( set to default 12345 without data lost / full reset) - New Operator/Country info with new base (BB5/Infineon - Lock info) - Security repair for N73 improved (res tore ccc/hwc) - SL3 simlock extraction improved sl: Added support for new types sl: Added new way of rpl validation during recovery sl: Added support SL3/SL30 simlock extraction even from working , but SL damaged phones (!!!in SOME cases!!!) sl: Added auto rpl complete in some damage cases sl: Added support for locked phones (under test) sl: Improved SL3 simlock extraction and pre-validation sl: Rewriten SL30 simlock extraction sl: Added SL30 simlock pre-validation sl: SPR reading improved sl: Revised support of override SL types (skip not SL3/SL30 phones) As always, simlock present check for free, so, handjob lovers can find some more things now - User data operations improved - Added support for new-type XG213 phones (110,111,112 and same) XGnew: Phonebook backup/extract/write XGnew: LifeTimer edit XGnew: Gallery backup XGnew: SMS read/write/extract - Improved s4pb format - full cross-writing between BB5 S40 , DCT4+ ARM (XG213) , DCT4+ - Improved SMS/Gallery/PhoneBook extraction from phones with partialy damaged FS - Improved Phonebook/Gallery/e.t.c extraction for some S40/S60 models f rom FullFlash - Improved data extraction from fullflash from S40/S60/S^3 models - Improved PhoneBook reading from BB5 S40 phones (C3 bug and some others fixes) - Fixed freeze during extraction on some model (Note! some big-sized (512,1024mb flash - can take up to 10-20-40 minutes!) - Low Format fixed for 8800 arte - Other - Maemo flashing from Normal (powered on state) mode fixed - MeeGo/Maemo flash file info added (region, langs, PR version, e.t.c) - Improved flashfiles check (Maemo/MeeGo/BB5/Lumia/Infineon) - Fixed VPL parser (modem part clear and file checking for Lumia) - RSA check improved (added new models) - INI revised - Some bugfixes - New WP7 models added (L610c) - Updated WP7 wipe files - Updated stuff files (tune/rpl) T R U S T T H E B E S T |
The Following 245 Users Say Thank You to Infinity-Box For This Useful Post: |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f475/infinity-nokia-best-version-1-48-released-1507262/ | ||||
Posted By | For | Type | Date | |
Infinity Nokia BEST Version 1.48 released !! - ????? ?? ?? ?? ???? ???? ??????? ????? ?????? | This thread | Refback | 08-14-2012 14:56 | |
Infinity Nokia BEST Version 1.48 released !! - RevoSupport Forum | This thread | Refback | 07-19-2012 02:39 | |
Infinity Nokia BEST Version 1.48 released !! - GSM-Forum | This thread | Refback | 07-18-2012 15:16 |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
