Go Back   GSM-Forum > News Section > GSM News & Updates
GSM News & Updates only for real news
Old 11-05-2010, 20:57   #1 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
LOCK13 CLIP Tool free for RCD or RCD PRO users !
LOCK13 Tool for Martech Clip
Martech Team presents new application to repair Ford radios with Locked10/13.
It's FREE for ALL RCD or RCD PRO USERS - one condition is you must have CLIP.
The first version supports the following models:
- Ford 3000
- Ford 4000
(Radios are based on MC68HC05L28)
Main application features:
- Reset counter and repair bad entries (lock3, lock10, lock13)
- Built-in calculator for M Series
The transmission path consists of only two lines, this simplify the system connection to a minimum.
The procedure for deleting Locked 10/13:
- Install applications on your Clip device
- Select Code Calculator, and generate the proper code for the radio (the serial number is located on the side of the label, such as M123456)
WARNING! Double-check your serial number and count the correct code to the radio.
Entering the wrong code will block the radio constantly.
- Connect the Clip to the radio as it's described in the program (two data lines and ground)
- Connect the power supply to the radio (remember about two GND and two +12V signals), turn on the radio
- Choose a model and function LOCK13 Remover, press OK to start the process
- After a moment on the radio display you see the "CODE" and you will be able to enter a code
- Properly written code will restore the functionality of the radio again
Download it: http://martech.pl/download/CLIP/LOCK...3_Tool_v10.zip
Connection diagram:
http://martech.pl/download/PINOUTS/lock13_1.jpg
http://martech.pl/download/PINOUTS/lock13_2.jpg
http://martech.pl/download/PINOUTS/lock13_3.jpg
http://martech.pl/download/PINOUTS/F...4000pinout.jpg
http://martech.pl/download/PINOUTS/clip_pinout.jpg
Warning about CLIP connection:
- pins are counted from right to left side (taking in mind keyboard top, for example GND signal – which is on port2, pin seventh from right side).
- from modular plug all signals are mirrored - pin 1st is counted from left plug side
Support for more radios in the next updates.
Martech Team
MARTECH Team - Official WebSite
[IMG] code is Off
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
Page generated in 0.20125 seconds with 11 queries
