Service Products News & Updates Service Products and Tools New and Updates |
11-28-2018, 15:54 | #1 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,340 | Medusa PRO v.1.7.0 is out! - Added possibility to work with MediaTek CPU-based devices via USB: Write Firmware using scatter ("MTK Factory Repair"), Read/Write/Erase Full Flash/Custom Flash operations are supported. To connect MediaTek CPU-based device you need to do the following steps: select "USB" interface option in the Software, select "Brand: Custom Settings", select "Device (Core): MTK Custom" and press "Connect" button. Then select proper DA file, preloader and AUTH file (if necessary), and press "Continue" button. After successful connection supported operations will be available. - Added support for the following models via eMMC:
- New “Live logs” uploaded into the Support Area. - Some adjustments and improvements were made. - All pinouts and repair procedures are described in the manual ("Help" button in the software). More info and discussion are HERE __________________________________________________ WBR, Medusa Box Team |
The Following 60 Users Say Thank You to Gsmserver For This Useful Post: |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f475/medusa-pro-v-1-7-0-out-2522759/ | ||||
Posted By | For | Type | Date | |
Medusa PRO v.1.7.0 is out! - GSM-Forum | This thread | Refback | 11-29-2018 16:34 | |
Medusa PRO v.1.7.0 is out! - GSM-Forum | This thread | Refback | 11-28-2018 17:20 |
