Go Back   GSM-Forum > News Section > Service Products News & Updates
Service Products News & Updates Service Products and Tools New and Updates
Old 08-07-2011, 13:43   #1 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
MXKEY v3.5 revision 1.3 The only NOKIA BOX with TMA included
v3.5 revision 1.3, Public-Release
MEGA UPDATE
PUBLIC DISCUSSION THREAD
http://forum.gsmhosting.com/vbb/f550...luded-1323642/
What is new added, changes and improvements:
- added USB STANDALONE security repair function *** for ALL HASH for RAPUYAMA phones.
( required HTI with firmware 00.17 )
- added USB STANDALONE security repair function *** for ALL HASH for RAPIDO phones.
SX4AUTH (PA_SL/PA_SL2/PA_SL3/PA_SIMLOC30)
SD REPAIR (PA_SL/PA_SL2/PA_SL3/PA_SIMLOC30)
SIMLOCK REPAIR (PA_SL/PA_SL2)
NCK CALC (PA_SL/PA_SL2)
SL3 BF HASH CALC (PA_SL3/PA_SIMLOC30)
SL3 NCK CALC (PA_SL3/PA_SIMLOC30)
- added: SL3 Logger (sl3u.exe - Standalone SL3 Logger/Unlocker/LOG Converter)
Optimized for SL3 unlock task using HTI or USB cable.
http://www.mx-key.org/mxkey/pictures/35rev13e.png
- added: SL3 Bruteforce (sl3bf.exe) 'load at windows startup' option.
http://www.mx-key.org/mxkey/pictures/35rev13d.png
- added, notification messages for important function
http://www.mx-key.org/mxkey/pictures/35rev13a.png
- added, optional screen recorder
using separated application "camcl.exe", use "Record Session" on system menu
(right click window titlebar)
captured videos will be saved as "capture.avi" in the windows temp folder
will be usefull for reporting bug or something else
http://www.mx-key.org/mxkey/pictures/35rev13b.png
- added: connection status/speed information on connect
http://www.mx-key.org/mxkey/pictures/35rev13c.png
- moved "[BB5,USB]Use New Protocol for RAPIDO" option to config->Directory
If enabled, will use new loader else will use old loader(embedded to MCU file)
RAPIDO phones with New Protocol connected to HS(High-speed) USB allows to use CERT backup/restore.
Old RAPIDO and RAPIDO connected to non HS USB will not backup CERT due to USB limitation.
NEW ADDED
- added: model selection by type designator or phone description
- added, fw version check between connected phone, mcu image, server during 'Scan Phone'
- added, fw version check between selected mcu image and server during 'market select'
- added, "Copy All Links" on Nokia Download Window
- added, auto complete on Model selection
- added: more detailed description of errors if an error occurs
- added: "[BB5]Use New Protocol for RAP3Gv3" option to config->Directory
- added: phone`s image load from server(if any).
- added: latest firmware version check(if any) for BB5 phone on market select.
- added update dialog window when HTI firmware outdated.
BUG FIXED:
- bugfixed: Nomadik dead usb flashing (Bootstrap failed)
- bugfixed: RAP3Gv3 dead usb flashing (stop at sending bootloader)
- bugfixed: usb3 connection status query
- bugfixed: XGOLD 213 "Use Embedded SBL from MCU" does not work if BB5 selected in generation dropdown.
- bugfixed: access violation on synchronize files when Download window opened.
- bugfixed: application crash on load in some os(win7 x86 no sp).
- bugfixed: XGOLD213 usb flashing error when no mcu spesified
- bugfixed: SL3 read PhoneIDs shows 'Operations not supported'
- bugfixed: X1-01 XGOLD flashing bug.
- bugfixed: No progressbar on flashing.
- bugfixed: New RAPIDO SL3 read PhoneIDs shows 'Operations not supported'
- bugfixed: processing file with size more than 900MB.
- bugfixed: emulate phone on New Protocol causing application to be hang.
- bugfixed: random crash on buscheck with usb connection
- bugfixed: dead after flashing in NOR flash devices (affected on x64 pc with memory more than 4GB)
OTHER CHANGES IN IMPROVEMENTS
- Renamed 'Image DL' caption to 'Download' as this will be easier to understand
- 'Download' will show input dialog if no product code spesified
- local rfbb will also handle rfbb file format
- local dcc will also handle pm file format
- changed FlashLoader selection from dropdown to checklist as this will be more user friendly.
- changed SoftTMA to slider as this will be more user friendly.
- Some UI changes
Add fading on loading module using balloon hint instean of ordinary hint
- changed manifest of mobileEx.exe, SL3 Bruteforce (sl3bf.exe) from 'asInvoker' to 'requireAdministrator'.
Library and modules will need to update their xml configuration files regularly,
or create if xml configuration is not exists. This operation required admin level on vista and win7 core.
- to not confuse users, Nokia USB ROM is now displayed only when no physical NMWCD* device connected
for dead usb flashing, Nokia USB ROM should be used instead of 'Phonet' device
* NMWCD: Nokia Mobile Wireless Communication Devices
- improved auto enable RAPIDO "FUR Cold Boot" by usb hub information
- improved synchronize files routine, auto retry when download failed.
- improved GetFlashAddress and Custom Erase function
(not pooling phone after operation)
- improved *.default(config update) file handling
- removed experimental "run in main thread" bug caused app hang
- usb flashing routine improved
- usb connection handling improved
420 Links to download MxBox/MxKey v3.5 rev1.3 for FREE
1. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
2. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
3. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
4. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
5. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
6. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
7. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
8. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
9. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
10. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
11. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
12. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
13. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
14. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
15. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
16. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
17. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
18. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
19. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
20. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
21. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
22. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
23. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
24. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
25. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
26. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
27. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
28. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
29. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
30. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe
!!! MXKEY CABLES - LED SERIES !!!
17 pcs SL3 cables in 1 SET, 44 phones supported
MXKEY CABLES - LED SERIES - 17 pcs cables in 1 SET, 44 phones supported (WORLD FIRST) - GSM-Forum
11 pcs SL3 cables in 1 SET, 15 phones supported
MXKEY CABLES - LED SERIES - 11 pcs cables in 1 SET, 15 phones supported (WORLD FIRST) - GSM-Forum
BR,
Manole
PS: ORIGINAL XTC CLIP
The Following 257 Users Say Thank You to MANOLE For This Useful Post:
[IMG] code is Off
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f475/mxkey-v3-5-revision-1-3-only-nokia-box-tma-included-1323646/
Posted By For Type Date
MXKEY v3.5 revision 1.3 The only NOKIA BOX with TMA included - phone answers This thread Refback 12-05-2013 20:40
Thread direct download link Mx-key MXKEY v3.4 revision 1.9 released | GSM-Forum | BoardReader This thread Refback 04-10-2012 10:35
Thread MXKEY v3.4 revision 1.2, Public Discussion goes here. | GSM-Forum | BoardReader This thread Refback 03-11-2012 19:52
Thread Mxkey MXKEY v3.4 revision 1.5: E5 flash USB problem | GSM-Forum | BoardReader This thread Refback 11-12-2011 07:35
Thread MXKEY v3.4 revision 1.2, Resume Support Here | GSM-Forum | BoardReader This thread Refback 10-15-2011 08:28
Included | KURSUS HANDPHONE This thread Refback 08-31-2011 11:33
GSM-новости со всего мира! This thread Refback 08-24-2011 07:36
MXKEY v3.5 revision 1.3 The only NOKIA BOX with TMA included | Tutorial Box Flasher This thread Refback 08-16-2011 14:57
MXKEY v3.5 revision 1.3 The only NOKIA BOX with TMA included | KURSUS HANDPHONE This thread Refback 08-11-2011 18:54
GSM-новости со всего мира! This thread Refback 08-09-2011 05:37
GSM-Hosting This thread Refback 08-08-2011 21:37
Untitled document This thread Refback 08-08-2011 20:58
v3.5 revision 1.3, Public-Release MEGA UPDATE - MCRF.RU This thread Refback 08-08-2011 08:36
Untitled document This thread Refback 08-08-2011 07:14
GSM News & Updates - GSM-Forum This thread Refback 08-08-2011 04:12
MXKEY v3.5 revision 1.3 - MAGIC UPDATE - The only NOKIA BOX with TMA included This thread Refback 08-07-2011 17:47
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.19603 seconds with 9 queries
