Service Products News & Updates Service Products and Tools New and Updates |
08-07-2011, 13:43 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | MXKEY v3.5 revision 1.3 The only NOKIA BOX with TMA included v3.5 revision 1.3, Public-Release MEGA UPDATE PUBLIC DISCUSSION THREAD http://forum.gsmhosting.com/vbb/f550...luded-1323642/ What is new added, changes and improvements: - added USB STANDALONE security repair function *** for ALL HASH for RAPUYAMA phones. ( required HTI with firmware 00.17 ) - added USB STANDALONE security repair function *** for ALL HASH for RAPIDO phones. ( required HTI with firmware 00.17 ) *** SX4AUTH (PA_SL/PA_SL2/PA_SL3/PA_SIMLOC30) SD REPAIR (PA_SL/PA_SL2/PA_SL3/PA_SIMLOC30) SIMLOCK REPAIR (PA_SL/PA_SL2) NCK CALC (PA_SL/PA_SL2) SL3 BF HASH CALC (PA_SL3/PA_SIMLOC30) SL3 NCK CALC (PA_SL3/PA_SIMLOC30) - added: SL3 Logger (sl3u.exe - Standalone SL3 Logger/Unlocker/LOG Converter) Optimized for SL3 unlock task using HTI or USB cable. http://www.mx-key.org/mxkey/pictures/35rev13e.png - added: SL3 Bruteforce (sl3bf.exe) 'load at windows startup' option. http://www.mx-key.org/mxkey/pictures/35rev13d.png - added, notification messages for important function http://www.mx-key.org/mxkey/pictures/35rev13a.png - added, optional screen recorder using separated application "camcl.exe", use "Record Session" on system menu (right click window titlebar) captured videos will be saved as "capture.avi" in the windows temp folder will be usefull for reporting bug or something else http://www.mx-key.org/mxkey/pictures/35rev13b.png - added: connection status/speed information on connect http://www.mx-key.org/mxkey/pictures/35rev13c.png - moved "[BB5,USB]Use New Protocol for RAPIDO" option to config->Directory If enabled, will use new loader else will use old loader(embedded to MCU file) RAPIDO phones with New Protocol connected to HS(High-speed) USB allows to use CERT backup/restore. Old RAPIDO and RAPIDO connected to non HS USB will not backup CERT due to USB limitation. http://www.mx-key.org/mxkey/pictures/35rev13c.png NEW ADDED - added: model selection by type designator or phone description - added, fw version check between connected phone, mcu image, server during 'Scan Phone' - added, fw version check between selected mcu image and server during 'market select' - added, "Copy All Links" on Nokia Download Window - added, auto complete on Model selection - added: more detailed description of errors if an error occurs - added: "[BB5]Use New Protocol for RAP3Gv3" option to config->Directory - added: phone`s image load from server(if any). - added: latest firmware version check(if any) for BB5 phone on market select. - added update dialog window when HTI firmware outdated. BUG FIXED: - bugfixed: Nomadik dead usb flashing (Bootstrap failed) - bugfixed: RAP3Gv3 dead usb flashing (stop at sending bootloader) - bugfixed: usb3 connection status query - bugfixed: XGOLD 213 "Use Embedded SBL from MCU" does not work if BB5 selected in generation dropdown. - bugfixed: access violation on synchronize files when Download window opened. - bugfixed: application crash on load in some os(win7 x86 no sp). - bugfixed: XGOLD213 usb flashing error when no mcu spesified - bugfixed: SL3 read PhoneIDs shows 'Operations not supported' - bugfixed: X1-01 XGOLD flashing bug. - bugfixed: No progressbar on flashing. - bugfixed: New RAPIDO SL3 read PhoneIDs shows 'Operations not supported' - bugfixed: processing file with size more than 900MB. - bugfixed: emulate phone on New Protocol causing application to be hang. - bugfixed: random crash on buscheck with usb connection - bugfixed: dead after flashing in NOR flash devices (affected on x64 pc with memory more than 4GB) OTHER CHANGES IN IMPROVEMENTS - Renamed 'Image DL' caption to 'Download' as this will be easier to understand - 'Download' will show input dialog if no product code spesified - local rfbb will also handle rfbb file format - local dcc will also handle pm file format - changed FlashLoader selection from dropdown to checklist as this will be more user friendly. - changed SoftTMA to slider as this will be more user friendly. - Some UI changes Add fading on loading module using balloon hint instean of ordinary hint - changed manifest of mobileEx.exe, SL3 Bruteforce (sl3bf.exe) from 'asInvoker' to 'requireAdministrator'. Library and modules will need to update their xml configuration files regularly, or create if xml configuration is not exists. This operation required admin level on vista and win7 core. - to not confuse users, Nokia USB ROM is now displayed only when no physical NMWCD* device connected for dead usb flashing, Nokia USB ROM should be used instead of 'Phonet' device * NMWCD: Nokia Mobile Wireless Communication Devices - improved auto enable RAPIDO "FUR Cold Boot" by usb hub information - improved synchronize files routine, auto retry when download failed. - improved GetFlashAddress and Custom Erase function (not pooling phone after operation) - improved *.default(config update) file handling - removed experimental "run in main thread" bug caused app hang - usb flashing routine improved - usb connection handling improved 420 Links to download MxBox/MxKey v3.5 rev1.3 for FREE 1. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 2. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 3. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 4. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 5. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 6. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 7. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 8. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 9. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 10. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 11. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 12. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 13. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 14. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 15. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 16. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 17. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 18. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 19. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 20. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 21. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 22. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 23. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 24. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 25. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 26. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 27. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 28. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 29. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe 30. 14 links for mobileEx_setup_v3.5_rev1.3_20110806.exe !!! MXKEY CABLES - LED SERIES !!! 17 pcs SL3 cables in 1 SET, 44 phones supported MXKEY CABLES - LED SERIES - 17 pcs cables in 1 SET, 44 phones supported (WORLD FIRST) - GSM-Forum !!! MXKEY CABLES - LED SERIES !!! 11 pcs SL3 cables in 1 SET, 15 phones supported MXKEY CABLES - LED SERIES - 11 pcs cables in 1 SET, 15 phones supported (WORLD FIRST) - GSM-Forum BR, Manole PS: ORIGINAL XTC CLIP Last edited by MANOLE; 08-07-2011 at 13:49. |
The Following 257 Users Say Thank You to MANOLE For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
