Service Products News & Updates Service Products and Tools New and Updates |
12-23-2012, 04:57 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,245 | NCK Dongle v9.5 Bug Fix Released 23/12/2012 Docomo SO-01B Direct Unlock. E10i Direct Unlock. E15i Direct Unlock. E16 Direct Unlock. E16i Direct Unlock. LT18i Direct Unlock. MK16a Direct Unlock. MT11i Direct Unlock. MT15i Direct Unlock. SK17i Direct Unlock. R800 Direct Unlock. SO-01C Direct Unlock. SO-02C Direct Unlock. SO-03C Direct Unlock. ST15i Direct Unlock. ST17i Direct Unlock. ST18i Direct Unlock. U20 Direct Unlock. X8 Direct Unlock. X10 Direct Unlock. X10 Mini Direct Unlock. X10 Mini Pro Direct Unlock. Xperia Active Direct Unlock. Xperia Arco Direct Unlock. Xperia Arc Direct Unlock. Xperia Arc S Direct Unlock. Xperia W8 Direct Unlock. Xperia X10i Direct Unlock. Xperia X10a Direct Unlock. Xperia Mini Direct Unlock. Xperia Mini Pro Direct Unlock. Xperia Pro Direct Unlock. Xperia Play Direct Unlock. Xperia Ray Direct Unlock. HOW TO USE FOR MODELS WITHOUT TP: MAKE SURE NO SIMCARD INSTERTED Code: Before unlocking go to menu, settings, applications->development then set the USB Debugging to ON (tip it) 1. Press Unlock. 2. Phone Must be power off, and press the back key then connect cable (install drivers if needed when prompt) if still not detected remove battery quick and put back while pressing back key. 3. after loader will be sent, software will prompt to remove cable and turn on phone then put cable back, here you must 1. Remove cable, 2. Turn on Phone, wait for anitmated logo then insert cable again. 4. Phone will detect again, then install drivers again if needed (ADB Drivers), then Phone will aut restart again once it restarted software will propmt Press ok when phone start ( wait until phone fully started) then Press ok. 5. wait few seconds and see Phone Unlocked MSG. Happy Unlocking MAKE SURE NO SIMCARD INSTERTED Code: Press Unlock De attach USB CABLE from phone Remove battery from phone Attach TEST POINT Then attach USB CABLE to phone Wait for unlock to start. Follow instruction on screen. PS. Please note that this solution is like all others in market and supports version up to 12w13 Sony Ericsson X8 Unlock OK Code: PROT_VER="02" DATE="20100615" TIME="17:28:00" VER="R4A045" CXC="1229-3641" TYPE="S1_LOADER" UNIQUE_DEV_ID="A70DC035D441C4FAD9D3D3073890D594A3539793" SEC_LOCK_STATUS="LOCKED" OTP_DATA="4DFD7700470404000F080420F94F3C3B" IMEI="01256000286866" AID_VERSION="0004" EROM_AID="0001" LOADER_AID="0001" SW_AID="0001" CUST_AID="0001" SIM_LOCK_AID="0001" HWCONF_AID="0001" PROD_AID="0000" ACTIVE_LOADER_AID="0001" MAN_ID="0020" DEV_ID="00BC" SIN_VER="0001" AID_TAMP="NOT_TAMPERED" MAX_PKT_SZ="00010000" AUTH_LEVEL="NONE" AUTH_MET="0001" CARD_PRESENT="NO" LOADER_ROOT="S1_Loader_Root_8e35" EROM_ROOT="S1_EROM_Root_f54f" SW_ROOT="S1_SW_Root_3edc" CUST_ROOT="S1_Cust_Root_732f" SIM_LOCK_ROOT="S1_SL_Root_a640" HW_CONF_ROOT="S1_HWConf_Root_4b8c" - SE UNLOCK STARTED. - WAITING USER ACTION Device removed from usb usb Device connected to usb - WAITING PHONE - PHONE FOUND - COMMUNICATING WITH THE PHONE Device removed from usb usb Device connected to usb - APPLYING CHANGES Device removed from usb usb Device connected to usb Device removed from usb usb Device connected to usb - WAITING PHONE Device removed from usb usb Device connected to usb - CHANGES APPLIED - VERIFYING CHANGES Device removed from usb usb - STATUS: - UNLOCKED!! Connect server setting true. Device connected to usb Also Official Public Download Link: https://hotfile.com/dl/185761611/1ad...ugfix.exe.html Full News & Updates: http://forum.gsmhosting.com/vbb/f691...dates-1316560/ PS Anyone we find posting 1 free check WE WILL BLOCK DONGLE FOR EVER WITHOUT ANY WARNING. BR NCK Dongle Team |
The Following 110 Users Say Thank You to Fast Unlocking For This Useful Post: |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f475/nck-dongle-v9-5-bug-fix-released-23-12-2012-a-1586893/ | ||||
Posted By | For | Type | Date | |
NCK Dongle v9.5 Bug Fix Released 23/12/2012 | This thread | Refback | 12-24-2012 09:36 | |
NCK Dongle v9.5 Bug Fix Released 23/12/2012 | This thread | Refback | 12-23-2012 18:51 |
