Service Products News & Updates Service Products and Tools New and Updates |
11-28-2018, 15:46 | #1 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,131 | 🐙 Octoplus JTAG PRO v.1.7.0 is out! 🐙 🐙 Added possibility to work with MediaTek CPU-based devices via USB: Write Firmware using scatter ("MTK Factory Repair"), Read/Write/Erase Full Flash/Custom Flash operations are supported.To connect MediaTek CPU-based device you need to do the following steps: select "USB" interface option in the Software, select "Brand: Custom Settings", select "Device (Core): MTK Custom" and press "Connect" button. Then select proper DA file, preloader and AUTH file (if necessary), and press "Continue" button. After successful connection supported operations will be available. 🐙 Added support for the following models via eMMC:
🐙 Added support for the following models via USB:
🐙 Added 15+ new unique Qualcomm USB Loaders to Software Loaders’ Data Base (Read/Write/Full Erase operations are supported). 🐙 New “Live logs” uploaded into the Support Area. 🐙 Some adjustments and improvements were made. 🐙 All pinouts and repair procedures are described in the manual ("Help" button in the software).More info and discussion are HERE _______________________________________________ WBR, Octoplus Box Team |
The Following 35 Users Say Thank You to Gsmserver For This Useful Post: |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f475/octoplus-jtag-pro-v-1-7-0-out-2522747/ | ||||
Posted By | For | Type | Date | |
🐙 Octoplus JTAG PRO v.1.7.0 is out! 🐙 - GSM-Forum | This thread | Refback | 11-28-2018 17:20 | |
🐙 Octoplus JTAG PRO v.1.7.0 is out! 🐙 - GSM-Forum | This thread | Refback | 11-28-2018 16:36 |
