Service Products News & Updates Service Products and Tools New and Updates |
05-10-2011, 17:35 | #1 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | RIFF JTAG - CDMA LG VM265, CDMA Huawei Broadband Modem EC1260 supported Resurrecting LG VM265 is easy. Phone is auto powered on with USB Data Cable connected to the PC. Battery presence is not required; connection can be established with detached board. To resurrect LG VM265:
Resurrecting Huawei EC1260 is simple. Just make sure you solder all JTAG signals and insert modem into a USB port for it to get powered. If modem is not detected by RIFFBOX JTAG, disconnect JTAG connector, re-insert modem into USB and then connect back the JTAG connector. At resurrection startup you can select which zones are to be re-flashed. Thus you can save a lot of time if you know approximately which zone is damaged. Select EFS or MMC areas to be flashed only in case you are sure those are damaged – these areas quite big in size; unnecessary reflash is just a waste of time. Please note, if you chose EFS to be repaired, an original ESN will be lost and substituted with the one contained in resurrection data. Current resurrector does not support ESN repair. To resurrect Huawei EC1260:
Please click “Check For Updates” button in order to download and apply new files. Closing all running application before starting update process is recommended. RIFF Box – JTAG Revolution |
The Following 38 Users Say Thank You to legija For This Useful Post: |
Anyone have a link to CDMA unlocking forum | SKAS_2002 | GSM Mobile Links | 1 | 10-29-2001 07:34 |
Who have Bartek's 2.0 SOFTWARE support all 25&35Siemens? | Baza | GSM Mobile Links | 0 | 04-05-2001 20:07 |
nokia 6150 internal modem | mottile | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-21-2001 00:14 |
6150 + NCDS3.0 + Win2000 + IBM600X + Xyrcom GSM modem (realport)? | bibi2k | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-21-2000 17:33 |
