Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Rocker Team products > Rocker Dongle (By Legija)
Old 12-19-2008, 14:14   #1 (permalink)
wiliam's Avatar
Member: 241831
Mot em325 unlock problem help
TODAY I RECEIVE MOT EM325 FOR TRY WITH ODM 1.32,1.33 BUT CANNOT UNLOCK HERE IS LOGS BELOW
Check if phone already booted
Power ON phone shortly
Searching device ...
Phone found
Sending signature
Boot Loading Error
I TRY WITH DIFFERENT PC TOO
Old 12-19-2008, 15:59   #2 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
Hi,
Make sure to install USB Locosto drivers following this procedure.
Old 12-19-2008, 16:56   #3 (permalink)
wiliam's Avatar
Member: 241831
Originally Posted by legija View Post
hi,
make sure to install usb locosto drivers following this procedure.
thx in advance for reply.i know about this driver.is same as mot w56,160,175.180 are same driver.i do unlock this type with rocker witout any problem.
Old 12-19-2008, 17:27   #4 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
This hapens because you have smart moto installed. Them is "smart" and fuk locosto usb drivers using their own crap.
So, You must clean this crap manually and install ORIGINAL drivers.
The Following User Says Thank You to legija For This Useful Post:
Old 12-19-2008, 18:05   #5 (permalink)
wiliam's Avatar
Member: 241831
this hapens because you have smart moto installed. Them is "smart" and fuk locosto usb drivers using their own crap.
So, you must clean this crap manually and install original drivers.
i remove smart moto but still same problem
Old 12-19-2008, 18:17   #6 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
Not smart moto, you have to reinstall drivers. Do this:
1. Open Device manager and expand it
2. Connect phone
3. As soon You see phone apears there, double click on it and select to uninstall drivers
4. Download driver package from rocker support and install it
5. Connect phone again and install driver from \\Program Files\Common Files\Motorola Shared
That should do the trick.
EDIT
Here's tool to remove the mess from PC: You'll have to install proper driver after cleaning with this.
www.rockerdongle.com/Clear_SC_Driver.rar
Old 12-19-2008, 22:13   #7 (permalink)
legija's Avatar
Member: 256342
Sonork: 100.45940
Updated drivers installation procedure, please check here.
Old 01-07-2009, 10:28   #8 (permalink)
weru's Avatar
Member: 55124
2. Connect phone
EDIT
SURE THE OLD SmartMOTO locosto drivers are hindrance
Phone found
Sending signature
Sending boot
Sending signature
Boot sent
Boot Succesfully Loaded
Locosto HS
Flash: Intel RD384060MOY3CE 32 MB
Flash size : 33554432
FW version : DOC-4-135D-000
LP : DOC-0-0004-219
IMG : DOC-0-0004-018
MELODY : DOC-0-0003-005
FLEX : DOC-0-0005-237
IMEI : 356xx50204xxx
Read backup...
Stage 1 Complete
Stage 2 Complete
Stage 3 Complete
Stage 4 Complete
Unlock ok.
The Following User Says Thank You to weru For This Useful Post:
Old 03-30-2009, 23:34   #9 (permalink)
Member: 16237
I get the error with EM325 motorola
Phone found
Sending signature
Sending boot
Sending signature
Boot sent
Boot Loading Error
i try on new computer where no drivers installed for moto, on PC with SC evry time i get the this error????
Old 03-30-2009, 23:44   #10 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Have you read the whole thread? Install drivers, first time you connect the phone the drivers will be automatically installed, next disconnect phone and you are ready to unlock it, luck
Old 03-31-2009, 00:11   #11 (permalink)
Member: 16237
allready done ,maybe 5 times
Old 04-11-2009, 14:47   #12 (permalink)
A1 Cell Solution's Avatar
Member: 25759
EM-325 tried with other tool but cannot unlock but unlocked with odm rocker in first try
Phone found
Sending signature
Sending boot
Sending signature
Boot sent
Locosto HS
FW version : DOC-4-034F-000
LP : DOC-0-0004-106
IMG : DOC-0-0004-022
MELODY : DOC-0-0003-011
FLEX : DOC-0-0005-204
IMEI : 35248702033253
Read backup...
Stage 1 Complete
Stage 2 Complete
Stage 3 Complete
Stage 4 Complete
Unlock ok.
Reading lock codes
Please wait ...
NCK code : 22534740 State : Unlocked
NS code : 08
Done.
Old 05-21-2009, 16:48   #13 (permalink)
Member: 5926
3 pcs done ok , but one not.
I think is new sec flash chip. like new locosto in sagems.
Old 08-25-2009, 02:41   #14 (permalink)
Member: 148017
Sonork: 1608728
new sc
yes its new sc bro no think to do
Old 09-01-2009, 16:22   #15 (permalink)
Member: 715429
very Good
Good Job Mr legija
read code ok.. Unlock direct ok.. new FW no supported
Phone found
Sending signature
Sending boot
Sending signature
Boot sent
Locosto HS
FW version : DAC-4-1400-000
LP : DAC-0-0008-313
IMG : DAC-0-0004-024
MELODY : DAC-0-0003-006
FLEX : DAC-0-0008-247
IMEI : 01174700181457
Reading lock codes
Please wait ...
NCK code : 80001613 State : Locked
NS code : 87115552 State : Unlocked
Done.
Friend this is new fw that are not supported by any box yet.
residentGSM
em325 unlock problem radu_adriansv Smart-Clip 24 08-25-2009 15:06
em325 unlock problem soft stay on sending boot .:M@ster:. Smart-Clip 3 04-29-2009 13:58
siemens frev15 frev10 c30 unlock problem help Gsm_box1 NON Siemens Brand (ODM Phones) 2 04-08-2005 19:47
cx65 unlock problem!!! help James-R S-Gold Based Phones 6 04-05-2005 10:16
New mot talkabout unlock problem mtony969 Old Legacy Motorola (EMMI) 0 09-21-2003 21:17
Page generated in 0.44605 seconds with 11 queries
