02-11-2009, 20:44 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 53
Member: 109996 Status: Offline Thanks Meter: 9 | Need w175/w180 usb driver |
The Following User Says Thank You to mgcelulares For This Useful Post: |
02-11-2009, 21:34 | #3 (permalink) |
Freak Poster Join Date: Nov 2006 Location: London Age: 65
Member: 389313 Status: Offline Thanks Meter: 30 | turn phone on connect to usb cable when its says phone not found remove tunn phone off remove battery replace phone must be off reconnect & power on & it will read |
02-11-2009, 22:04 | #4 (permalink) |
Product Supporter Join Date: Feb 2008 Location: Jat-Chi-Bangladesh Age: 46
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | br: motorola w175/w180 usb driver hear: |
The Following 9 Users Say Thank You to TUR@N ALAM For This Useful Post: |
02-11-2009, 23:13 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Made In Brazil Age: 42
Member: 264903 Status: Offline Sonork: 1584531 Thanks Meter: 3,350 | Procedure of how to do using Rocker 1) Open the program and select the model w175 2) Click to unlock 3) Put the usb cable with a click off quickly and the key power of the apparatus 4) Just wait for the process of fenal Note: When connecting the cable Windowns to prompt you to install the driver for the W180, Just Ignore the state does not need to be instalados.É drives Of course if you have installed the driver for the model specified. |
The Following User Says Thank You to LuisinhoCell For This Useful Post: |
03-19-2009, 22:30 | #9 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | Easy procedure to do it is: 1) Open software. 2) Select desire model. 3) Conect usb cable to phone and phone should be without battery. 4) Press connect in software 5) After software displays "Searching..." put battery to phone 6) Click unlock or read codes It is very easy and fast, for model ZN200 press connect in soft and then insert cable to phone, phone should be off. This is for Locosto based phones. Luck |
04-22-2009, 15:14 | #10 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Gujrat (India) Age: 38
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | Quote:
100000% working just remove battery n put the batt smart-clip logs Connect phone to computer USB port before proceeding...OK Sending boot...OK Software version: SW_%s_0.1.52.. Hardware version: MOTOROLA_H29 Language pack: H10 Hardware IMEI: 359223013090308 Manufacturer: Intel, Model: 28F640W18TPD Performing Format FFS (takes up to 3 min)...OK Turning phone off | |
W156i, W160, W175, W180 USB Drivers! | sharaz191 | Rocker Dongle (By Legija) | 6 | 11-14-2014 15:53 |
Need Haier c5000 usb driver | monto | Various CDMA/TDMA Cell Phones | 5 | 06-17-2013 08:28 |
I need NEC 411i usb driver | market_3b2002 | NEC | 11 | 05-09-2006 08:51 |
I Need Nsdongle Box Usb Drivers | petcy | NSPRO | 1 | 02-11-2006 15:45 |
