12-03-2011, 13:54 | #151 (permalink) |
No Life Poster Join Date: Nov 2007 Location: UK
Member: 629391 Status: Offline Thanks Meter: 396 | 03/12/2011 Loaded 15 models. Please wait ... Phone : KS360 Press PowerON button. Phone Found. Loading Boot... Boot started. Baudrate : 115200 Flash: ID:00000000 Imei : 352074030xxxxxx Unlock code : 00864908 BT adr : 0022A91B6DED Saved to : C:\Program Files\Rocker Dongle\LGRocker\FLASH\caldata\KS360__3520740305xxx xx_3_December_2011_12_41_Caldata.lcf Boot Succesfully Loaded Unlocking, please wait. Imei : 352074030xxxxxx Unlock code : 00864908 BT adr : 0022A91B6DED Saved to : C:\Program Files\Rocker Dongle\LGRocker\FLASH\caldata\KS360__3520740305xxx xx_3_December_2011_12_41_Caldata.lcf Unlock done in 00:09 sec. |
12-06-2011, 03:47 | #152 (permalink) |
No Life Poster Join Date: May 2007 Location: Islamic city of Marawi
Member: 502507 Status: Offline Sonork: 100.1648947 Thanks Meter: 154 | v3 unlock done Welcome dear user. Motorocker version used: 2.26 (Motorola V3rEDGE, R3442A) Package file: NOT SELECTED Language file: NOT SELECTED Selected: Motorola V3, firmware: R374 Clicked button: UNLOCK (&Unlock) Wait for TCI started. Checking connected interface: Motorola Flash Waiting for flash interface init... Detected motorola interface: Motorola Flash Full bootcore version: 010C02FFFF000826 Full firmware version: R374_G_0E.42.15R:GSMV3MYCIN01NA1CD Decision: bootcore flashing needed. Full bootcore version: 010C02FFFF000826 Full firmware version: R374_G_0E.42.15R:GSMV3MYCIN01NA1CD Uploading ramloader of version: 08.29 Reading 16 bytes... Reading 59392 bytes... Reading 128 bytes... Reading 131072 bytes... Reading 131072 bytes... Show WINDOW: Head = "Stage complete.", line1 = "Please wait till phone is powered on or put it to flash mode manually.", line2 = "Wait for phone to be detected (see below). Then Click Continue...", line3 = "", button1 = "", button2 = "&Continue" Showed WINDOW modal result: 2 Wait for TCI started. Checking connected interface: Motorola Flash Waiting for flash interface init... Full bootcore version: 010C02FFFF000826 Full firmware version: R374_G_0E.42.15R:GSMV3MYCIN01NA1CD Uploading ramloader of version: 08.29 Show WINDOW: Head = "Stage complete.", line1 = "Unplug cable, remove battery, insert battery, insert cable. Press PowerON shortly.", line2 = "If you use REPAIR cable, do not use it this time. Use USUAL cable.", line3 = "Wait for phone to be detected (see below). Then Click OK...", button1 = "", button2 = "&OK" Showed WINDOW modal result: 2 Wait for TCI started. Checking connected interface: Motorola Flash Waiting for flash interface init... Full bootcore version: 000C0200FF000200 Phone serial number: F002000000003BA407261E170BC0AF1D9200 Uploading ramloader of version: 08.23 Flash ID: 0089 8810, SCC status: 80 Show WINDOW: Head = "Unlock complete.", line1 = "Reconnect your phone for software to make final step.", line2 = "Wait for phone to be detected (see below). Then Click Continue...", line3 = "", button1 = "", button2 = "&Continue" Showed WINDOW modal result: 2 Wait for TCI started. Checking connected interface: Motorola Flash Waiting for flash interface init... Attempt to restore: Found restore point ok. Full bootcore version: 010C02FFFF000826 Full firmware version: R374_G_0E.42.15R:GSMV3MYCIN01NA1CD Uploading ramloader of version: 08.29 Done. Unlocked OK |
12-09-2011, 22:29 | #156 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Cuba
Member: 1202427 Status: Offline Sonork: 100.1604781 Thanks Meter: 27 | Successful unlock-reset Samsung C3510 Doing Job, Please Wait Open COM15 - OK Speed: 115k Press PowerOn button for Upload Preloader Phone found, booting... PhoneID: 39ED694040 PreLoader OK, Setting Speed to 921k Speed: 921k, OK BB Chip Version: 00003B11 FlashLoader sent Boot OK FlashID:00EC2206 - [ KAP29SN00M ] Reading Flash... Saved: C:\Archivos de programa\Rocker Dongle\SamsungRocker\data\EEPROM\C3510-EEP_01E00000-00200000_000665E0.bin Phone BCD Imei: 353433----------- Extended UNFREEZE Code: 00000256 Extended NCK Code: #7465625*638*00000000# UNFREEZE Code: 00000000 NCK Code: #7465625*638*00000000# NSCK Code: #7465625*782*00000000# SPCK Code: #7465625*77*00000000# CCK Code: #7465625*27*00000000# PCK Code: #7465625*746*00000000# ----------Found SimLockBlock---------- NCK Code: #7465625*638*00000000# NSCK Code: #7465625*782*00000000# SPCK Code: #7465625*77*00000000# CCK Code: #7465625*27*00000000# Extended UNFREEZE Code: 00000256 Extended NCK Code: #7465625*638*00000000# PCK Code: #7465625*746*00000000# Code6: 00000000 Code7: 00000000 Code8: 00000000 Code9: 00000000 |
12-21-2011, 03:42 | #157 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 390137 Status: Offline Thanks Meter: 28 | i455L unlocked Samsung Module for Rocker Dongle (v1.38) Chipset: M6260A-KYRZ-2.1.300612 IMEI: 354996-02-01***** Starting: Direct Unlock Phease 1: OK Phease 2: OK Unlock: DONE Please switch off phone! (Do not remove battery!) Finished |
12-22-2011, 08:14 | #158 (permalink) |
Member: 502507 Status: Offline Sonork: 100.1648947 Thanks Meter: 154 | w181 unlock done Check if phone already booted Power ON phone shortly Searching device ... Phone found Sending signature Sending boot Sending signature Boot sent Boot Succesfully Loaded Locosto HS Flash: Intel RD28F640W18T, 8MB Flash size : 8388608 Model type : MOTOROLA_H29 FW version : SW_%s_0.1.55 Flex version : FLEX_W181_AE_006_100 LP version : LP_%s_0155_H03 IMEI : 35772501431279 Unlocking started Stage 1 done Stage 2 done Stage 3 done Stage 4 done Erase eeprom done Erase eeprom1 done Rebuilding security done. Unlocking complete yahhhooooo |
01-23-2012, 09:37 | #160 (permalink) |
Member: 502507 Status: Offline Sonork: 100.1648947 Thanks Meter: 154 | c117 unlock Check if phone already booted Power ON phone shortly Phone detected Boot Succesfully Loaded Calypso lite Flash: Intel 28F160C3TA 2MB Flash size : 2097152 IMEI : 357394005870833 Model type : MOTOROLA_E88 FW version : 2.1.55.N LP version : LPN_C115_ASIA3_149 FLEX version : FFN_C115_04_149 IMEI : 357394005870833 Unlock started Flex is locked Erasing started Erasing finished Writing started Writing finished Unlock done. |
02-09-2012, 17:44 | #162 (permalink) |
Freak Poster Join Date: Jul 2001 Location: HYPERCUBE Age: 58
Member: 5116 Status: Offline Thanks Meter: 4 | Samsung Module for Rocker Dongle (v1.38) Loaded 1000 models Available COM ports: COM1 (Communications Port (COM1)) COM132 (Agere Systems HDA Modem #2) COM137 (SAMSUNG Android USB Modem #10) Doing Job, Please Wait Killing ADB server if running... OK Starting ADB server... try to parse ro.build.description or .fingerprint d.product is obsolete; use ro.product.device name=Android platform=s5pc110 changelist=639474 date.utc=1287228906 date=2010. 10. 16. (Ýćá) 20:35:06 KST description=GT-P1000-user 2.2 FROYO XWJJ4 release-keys display.id=FROYO.XWJJ4 fingerprint=samsung/GT-P1000/GT-P1000/GT-P1000:2.2/FROYO/XWJJ4:user/release-keys hidden_ver=P1000XWJJ4 host=SE-S611 id=FROYO PDA=P1000XWJJ4 product=GT-P1000 tags=release-keys type=user user=root version.codename=REL version.incremental=XWJJ4 version.release=2.2 version.sdk=8 Installing new temp root(please wait)... OK Killing ADB server... OK Starting ADB server... OK Getting nv_data from phone... OK Killing ADB server... OK NV Version: GT-P1000CWASER Hw Revision: MP 1.200 Country Code: SER FLAG: [01] Calculating... Using ROCKER table for speedup NSCK: 00000000 - 0sec SP: 00000000 - 0sec SPCK: 00000000 - 0sec ACTIVA: 00000000 - 0sec NCK: 07070404 - 0sec FREEZE: 82683969 - 6sec Finished |
05-22-2012, 19:27 | #163 (permalink) |
Member: 629391 Status: Offline Thanks Meter: 396 | Alcatel e227 unlock done Check if phone already booted Power ON phone shortly Searching device ... Phone found Sending signature Sending boot Sending signature Boot sent Boot Succesfully Loaded Locosto HS Flash: S29NS032J 4MB Flash size : 4194304 Part number : E227X Commercial Reference : E227X-2DRGGB1 PTS : 145_906 PTM : OK_OKH SN : CG_010 Imei : Reading lock codes Please wait ... Master code(PKey) : 4524816045 NCK code : 1620143365 State : Locked |
02-14-2013, 10:05 | #164 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | V3ROHS unlocked done.. Code: Selected: Motorola V3RoHS, firmware: R4515 Current language: Rocker Clicked button: UNLOCK (&Unlock) Wait for TCI started. Established connection to: \\.\Motorola USB Modem Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Test Command Waiting for flash interface init... Detected motorola interface: Motorola Flash Full bootcore version: 011302FF02000A30 Full firmware version: R4515_G_08.BD.43R:SE6773AXXH106B Decision: bootcore flashing needed. Full bootcore version: 011302FF02000A30 Full firmware version: R4515_G_08.BD.43R:SE6773AXXH106B Uploading ramloader of version: 0A.50 Reading 16 bytes... Reading 59392 bytes... Reading 128 bytes... Reading 128 bytes... Reading 128 bytes... Reading 128 bytes... Reading 128 bytes... Reading 131072 bytes... Show WINDOW: Head = "Stage complete.", line1 = "Please wait till phone is powered on or put it to flash mode manually.", line2 = "Wait for phone to be detected (see below). Then Click Continue...", line3 = "", button1 = "", button2 = "&Continue" Showed WINDOW modal result: 2 Full bootcore version: 011302FF02000A30 Full firmware version: R4515_G_08.BD.43R:SE6773AXXH106B Uploading ramloader of version: 0A.50 Show WINDOW: Head = "Stage complete.", line1 = "Unplug cable, remove battery, insert battery, insert cable. Press PowerON shortly.", line2 = "If you use REPAIR cable, do not use it this time. Use USUAL cable.", line3 = "Wait for phone to be detected (see below). Then Click OK...", button1 = "", button2 = "&OK" Showed WINDOW modal result: 2 Full bootcore version: 00130200FF000300 Phone serial number: 68E011502029090B79CC10EBC555F002A300 Uploading ramloader of version: custom ramloader used. Flash ID: 0020 880E, SCC status: 80 Unlocked OK |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
