Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Rocker Dongle (By Legija)
Old 12-03-2011, 12:54   #151 (permalink)
mojee's Avatar
Member: 629391
Thanks Meter: 373
Version : V 1.32 beta
03/12/2011
Loaded 15 models.
Please wait ...
Phone : KS360
Press PowerON button.
Phone Found. Loading Boot...
Boot started.
Baudrate : 115200
Flash: ID:00000000
Imei : 352074030xxxxxx
Unlock code : 00864908
BT adr : 0022A91B6DED
Saved to : C:\Program Files\Rocker Dongle\LGRocker\FLASH\caldata\KS360__3520740305xxx xx_3_December_2011_12_41_Caldata.lcf
Boot Succesfully Loaded
Unlocking, please wait.
Unlock done in 00:09 sec.
Old 12-06-2011, 02:47   #152 (permalink)
amyll's Avatar
Member: 502507
Sonork: 100.1648947
Thanks Meter: 154
v3 unlock done
Welcome dear user.
Motorocker version used: 2.26 (Motorola V3rEDGE, R3442A)
Package file: NOT SELECTED
Language file: NOT SELECTED
Selected: Motorola V3, firmware: R374
Clicked button: UNLOCK (&Unlock)
Wait for TCI started.
Checking connected interface: Motorola Flash
Waiting for flash interface init...
Detected motorola interface: Motorola Flash
Full bootcore version: 010C02FFFF000826
Full firmware version: R374_G_0E.42.15R:GSMV3MYCIN01NA1CD
Decision: bootcore flashing needed.
Uploading ramloader of version: 08.29
Reading 16 bytes...
Reading 59392 bytes...
Reading 128 bytes...
Reading 131072 bytes...
Show WINDOW: Head = "Stage complete.", line1 = "Please wait till phone is powered on or put it to flash mode manually.", line2 = "Wait for phone to be detected (see below). Then Click Continue...", line3 = "", button1 = "", button2 = "&Continue"
Showed WINDOW modal result: 2
Show WINDOW: Head = "Stage complete.", line1 = "Unplug cable, remove battery, insert battery, insert cable. Press PowerON shortly.", line2 = "If you use REPAIR cable, do not use it this time. Use USUAL cable.", line3 = "Wait for phone to be detected (see below). Then Click OK...", button1 = "", button2 = "&OK"
Full bootcore version: 000C0200FF000200
Phone serial number: F002000000003BA407261E170BC0AF1D9200
Uploading ramloader of version: 08.23
Flash ID: 0089 8810, SCC status: 80
Show WINDOW: Head = "Unlock complete.", line1 = "Reconnect your phone for software to make final step.", line2 = "Wait for phone to be detected (see below). Then Click Continue...", line3 = "", button1 = "", button2 = "&Continue"
Attempt to restore: Found restore point ok.
Done.
Unlocked OK
Old 12-06-2011, 03:13   #153 (permalink)
Member: 612140
Nokia 5610d-2b
need help unlucking my NOKIA 5610D-2B.
waiting
[email protected]
dennis
Old 12-06-2011, 03:17   #154 (permalink)
Member: 612140
waiting
[email protected]
dennis
Old 12-09-2011, 21:27   #155 (permalink)
Member: 1202427
Sonork: 100.1604781
Thanks Meter: 20
waiting
[email protected]
dennis
Hello dennis.
You are on the wrong section. Check Nokia related forums, like Cyclone.
Br,
Zeddicus
Old 12-09-2011, 21:29   #156 (permalink)
Member: 1202427
Sonork: 100.1604781
Thanks Meter: 20
Successful unlock-reset Samsung C3510
Doing Job, Please Wait
Open COM15 - OK
Speed: 115k
Press PowerOn button for Upload Preloader
Phone found, booting...
PhoneID: 39ED694040
PreLoader OK, Setting Speed to 921k
Speed: 921k, OK
BB Chip Version: 00003B11
FlashLoader sent
Boot OK
FlashID:00EC2206 - [ KAP29SN00M ]
Reading Flash...
Saved: C:\Archivos de programa\Rocker Dongle\SamsungRocker\data\EEPROM\C3510-EEP_01E00000-00200000_000665E0.bin
Phone BCD Imei: 353433-----------
Extended UNFREEZE Code: 00000256
Extended NCK Code: #7465625*638*00000000#
UNFREEZE Code: 00000000
NSCK Code: #7465625*782*00000000#
SPCK Code: #7465625*77*00000000#
CCK Code: #7465625*27*00000000#
PCK Code: #7465625*746*00000000#
----------Found SimLockBlock----------
Code6: 00000000
Code7: 00000000
Code8: 00000000
Code9: 00000000
Old 12-21-2011, 02:42   #157 (permalink)
Member: 390137
Thanks Meter: 28
i455L unlocked
Samsung Module for Rocker Dongle (v1.38)
Chipset: M6260A-KYRZ-2.1.300612
IMEI: 354996-02-01*****
Starting: Direct Unlock
Phease 1: OK
Phease 2: OK
Unlock: DONE
Please switch off phone! (Do not remove battery!)
Finished
Old 12-22-2011, 07:14   #158 (permalink)
amyll's Avatar
Member: 502507
Sonork: 100.1648947
Thanks Meter: 154
w181 unlock done
Check if phone already booted
Power ON phone shortly
Searching device ...
Phone found
Sending signature
Sending boot
Sending signature
Boot sent
Locosto HS
Flash: Intel RD28F640W18T, 8MB
Flash size : 8388608
Model type : MOTOROLA_H29
FW version : SW_%s_0.1.55
Flex version : FLEX_W181_AE_006_100
LP version : LP_%s_0155_H03
IMEI : 35772501431279
Unlocking started
Stage 1 done
Stage 2 done
Stage 3 done
Stage 4 done
Erase eeprom done
Erase eeprom1 done
Rebuilding security done.
Unlocking complete
yahhhooooo
Old 12-23-2011, 10:53   #159 (permalink)
Member: 121375
Thanks Meter: 25
E1050 unlock OK
S5230 unlock OK
S5570 unlock OK
I9000 unlock OK
Old 01-23-2012, 08:37   #160 (permalink)
amyll's Avatar
Member: 502507
Sonork: 100.1648947
Thanks Meter: 154
c117 unlock
Phone detected
Calypso lite
Flash: Intel 28F160C3TA 2MB
Flash size : 2097152
IMEI : 357394005870833
Model type : MOTOROLA_E88
FW version : 2.1.55.N
LP version : LPN_C115_ASIA3_149
FLEX version : FFN_C115_04_149
Unlock started
Flex is locked
Erasing started
Erasing finished
Writing started
Writing finished
Unlock done.
Old 01-24-2012, 08:35   #161 (permalink)
Member: 154448
Sonork: not yet
Thanks Meter: 26
unlock success lg gb130 by rocker lg
Old 02-09-2012, 16:44   #162 (permalink)
pinker's Avatar
Member: 5116
Thanks Meter: 4
Loaded 1000 models
Available COM ports:
COM1 (Communications Port (COM1))
COM132 (Agere Systems HDA Modem #2)
COM137 (SAMSUNG Android USB Modem #10)
Killing ADB server if running... OK
Starting ADB server...
try to parse ro.build.description or .fingerprint
d.product is obsolete; use ro.product.device
name=Android
platform=s5pc110
changelist=639474
date.utc=1287228906
date=2010. 10. 16. (ć) 20:35:06 KST
description=GT-P1000-user 2.2 FROYO XWJJ4 release-keys
display.id=FROYO.XWJJ4
fingerprint=samsung/GT-P1000/GT-P1000/GT-P1000:2.2/FROYO/XWJJ4:user/release-keys
hidden_ver=P1000XWJJ4
host=SE-S611
id=FROYO
PDA=P1000XWJJ4
product=GT-P1000
tags=release-keys
type=user
user=root
version.codename=REL
version.incremental=XWJJ4
version.release=2.2
version.sdk=8
Installing new temp root(please wait)... OK
Killing ADB server... OK
Starting ADB server... OK
Getting nv_data from phone... OK
NV Version: GT-P1000CWASER
Hw Revision: MP 1.200
Country Code: SER
FLAG: [01]
Calculating...
Using ROCKER table for speedup
NSCK: 00000000 - 0sec
SP: 00000000 - 0sec
SPCK: 00000000 - 0sec
ACTIVA: 00000000 - 0sec
NCK: 07070404 - 0sec
FREEZE: 82683969 - 6sec
Finished
Old 05-22-2012, 19:27   #163 (permalink)
mojee's Avatar
Member: 629391
Thanks Meter: 373
Alcatel e227 unlock done
Phone found
Sending signature
Sending boot
Sending signature
Boot sent
Locosto HS
Flash: S29NS032J 4MB
Flash size : 4194304
Part number : E227X
Commercial Reference : E227X-2DRGGB1
PTS : 145_906
PTM : OK_OKH
SN : CG_010
Imei :
Reading lock codes
Please wait ...
Master code(PKey) : 4524816045
NCK code : 1620143365 State : Locked
Old 02-14-2013, 09:05   #164 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
V3ROHS unlocked done..
Selected: Motorola V3RoHS, firmware: R4515
Current language: Rocker
Established connection to: \\.\Motorola USB Modem
Checking connected interface: Motorola Accessory
Checking connected interface: Motorola MCU Data Logger
Checking connected interface: Motorola Test Command
Full bootcore version: 011302FF02000A30
Full firmware version: R4515_G_08.BD.43R:SE6773AXXH106B
Uploading ramloader of version: 0A.50
Reading 16 bytes...
Full bootcore version: 00130200FF000300
Phone serial number: 68E011502029090B79CC10EBC555F002A300
Uploading ramloader of version: custom ramloader used.
Flash ID: 0020 880E, SCC status: 80
Unlocked OK
Old 02-14-2013, 21:43   #165 (permalink)
Member: 172120
Thumbs down dead
dead project rocker box
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.44802 seconds with 9 queries
