03-17-2013, 12:04 | #166 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Code: Selected: Motorola V360, firmware: R4513 Clicked button: UNLOCK (&Unlock) Wait for TCI started. Established connection to: \\.\Motorola USB Modem Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Test Command Waiting for flash interface init... Detected motorola interface: Motorola Flash Full bootcore version: 011302FF05000902 Full firmware version: R4513_G_08.B7.ABR:GSTV360VFLIRO1C1 Decision: bootcore flashing needed. Full bootcore version: 011302FF05000902 Full firmware version: R4513_G_08.B7.ABR:GSTV360VFLIRO1C1 Uploading ramloader of version: 0A.B2 Show WINDOW: Head = "Stage complete.", line1 = "Unplug cable, remove battery, insert battery, insert cable. Press PowerON shortly.", line2 = "If you use REPAIR cable, do not use it this time. Use USUAL cable.", line3 = "Wait for phone to be detected (see below). Then Click OK...", button1 = "", button2 = "&OK" Showed WINDOW modal result: 2 Full bootcore version: 00130200FF000300 Phone serial number: 181017C00E1A092B51E49151B945F002A300 Uploading ramloader of version: custom ramloader used. Flash ID: 0089 8810, SCC status: 80 Unlocked OK |
03-29-2013, 14:11 | #167 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | Motorola EM325 successfully unlocked.. Code: Check if phone already booted Power ON phone shortly Searching device ... Phone found Sending signature Sending boot Sending signature Boot sent Boot Succesfully Loaded Locosto HS Flash: Intel RD384060MOY3CE 32 MB Flash size : 33554432 FW version : DOC-4-130A-000 LP : DOC-0-0004-028 IMG : DOC-0-0004-005 MELODY : DOC-0-0003-005 FLEX : DOC-0-0006-061 IMEI : 35688502076953 Reading lock codes Please wait ... NCK code : 62228546 State : Locked NS code : 39135024 State : Unlocked Done. |
10-16-2013, 12:42 | #168 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | motorola v975 unlocked.. Code: Selected: Motorola V975, firmware: R24 Clicked button: UNLOCK (&Unlock) Wait for TCI started. Established connection to: \\.\Motorola USB Modem #4 Clicked button: UNLOCK (&Stop) Waiting for flash interface init... Clicked button: UNLOCK (&Unlock) Wait for TCI started. Established connection to: \\.\Motorola USB Modem #4 Checking connected interface: Motorola Accessory Checking connected interface: Motorola Accessory Checking connected interface: Motorola Accessory Checking connected interface: Motorola Accessory Checking connected interface: Motorola Accessory Checking connected interface: Motorola Accessory Checking connected interface: Motorola Accessory Checking connected interface: Motorola Accessory Checking connected interface: Motorola Accessory Checking connected interface: Motorola Accessory Checking connected interface: Motorola Accessory Checking connected interface: Motorola Accessory Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Test Command Waiting for flash interface init... Detected motorola interface: Motorola Flash Full bootcore version: 010804FF04000631 Full firmware version: R26_U_83.38.49.01P:USV975VFDEPREPR26004 Decision: bootcore flashing needed. Full bootcore version: 010804FF04000631 Full firmware version: R26_U_83.38.49.01P:USV975VFDEPREPR26004 Phone serial number: 221C6CEC6CEC748C002800480010DB12 Uploading ramloader of version: 0D.36 Show WINDOW: Head = "Stage complete.", line1 = "Unplug cable, remove battery, insert battery, insert cable. Press PowerON shortly.", line2 = "Wait for phone to be detected (see below). Then Click Continue...", line3 = "", button1 = "", button2 = "&Continue" Showed WINDOW modal result: 2 Full bootcore version: 00080400FF000310 Phone serial number: 221C6CEC6CEC748C002800480010DB12 Uploading ramloader of version: custom ramloader used. Flash ID: 0089 8810, SCC status: 80 Unlocked OK |
03-02-2014, 13:47 | #170 (permalink) |
Freak Poster Join Date: Sep 2009
Member: 1123539 Status: Offline Thanks Meter: 14 | Dead Indeed!!! Legija Biggest Liar in GSM World!!! Do not support this guy or his team, he is a failure!!! Rocker Donger ended abruptly and up to now he is mum on questions posed by his clients. Its the same with Cyclone Box. Promises of updates and then...silence. When the client asks, these guys behave as if they are not obligated to answer questions on updates or even support questions. What is wrong here? is it that you can't deliver? well, say so and fold!!! i am obligated to my clients and if i can't do the job...i tell the customer, regardless of any embarrassment. Silence is not a definite answer!!! |
01-31-2016, 10:07 | #171 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | motorola v1075 unlocked done Code: Welcome dear user. Motorocker version used: 2.28 Selected: Motorola V1075, firmware: R25221LD Current language: Rocker Clicked button: UNLOCK (&Unlock) Wait for TCI started. Established connection to: \\.\Motorola USB Modem #3 Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Test Command Waiting for flash interface init... Detected motorola interface: Motorola Flash Full bootcore version: 010804FF07000681 Full firmware version: R252211LD_U_85.97.C6P:USV1075VFESR25221007 Decision: bootcore flashing needed. Full bootcore version: 010804FF07000681 Full firmware version: R252211LD_U_85.97.C6P:USV1075VFESR25221007 Uploading ramloader of version: 06.90 Reading 16 bytes... Reading 59392 bytes... Reading 262144 bytes... Show WINDOW: Head = "Stage complete.", line1 = "Please wait till phone is powered on or put it to flash mode manually.", line2 = "Wait for phone to be detected (see below). Then Click Continue...", line3 = "", button1 = "", button2 = "&Continue" Showed WINDOW modal result: 2 Wait for TCI started. Established connection to: \\.\Motorola USB Modem #3 Checking connected interface: Motorola Accessory Checking connected interface: Motorola MCU Data Logger Checking connected interface: Motorola Test Command Waiting for flash interface init... Full bootcore version: 010804FF07000681 Full firmware version: R252211LD_U_85.97.C6P:USV1075VFESR25221007 Uploading ramloader of version: 06.90 Show WINDOW: Head = "Stage complete.", line1 = "Unplug cable, remove battery, insert battery, insert cable. Press PowerON shortly.", line2 = "If you use REPAIR cable, do not use it this time. Use USUAL cable.", line3 = "Wait for phone to be detected (see below). Then Click OK...", button1 = "", button2 = "&OK" Showed WINDOW modal result: 2 Full bootcore version: 00080400FF000310 Phone serial number: 22228CEC0CAC8C740018003000E0DB12 Uploading ramloader of version: custom ramloader used. Flash ID: 0089 8810, SCC status: 80 Unlocked OK |
08-06-2016, 12:10 | #172 (permalink) |
Insane Poster Join Date: Jul 2013
Member: 1975486 Status: Offline Thanks Meter: 0 | Hello rocker team ! I am a riff user and my riff 1.56 is not connecting with server . i have download all from update and installed . Please provide me license so i can use riff 1.56. please ..MY riff serial no is RIFF Box S/N: FF.183F:4E2B-A77C:2D3B |
08-23-2018, 10:43 | #174 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2740228 Status: Offline Thanks Meter: 0 | Hello. I'm sorry for my english. In the rocker program samsung dongle version 1.6, the reconstruction imei and the unlock of the phone (I have a samsung SGH L760) involves dump of the memory ???????. This is my doubt. thank you |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
