05-24-2009, 19:18 | #17 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, Just uploaded one flash file for KU990i, and since i havent had a chance to test this solution (no sample) You can do it on Your risk. Though, i am unsure if LGMDP will flash the phone with different FW. |
05-24-2009, 20:28 | #19 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | /LGRocker/FlashFiles/KU990i/ Will also upload DZ unpacker to Software directory. To flash phone do this : Unpack KU990 DZ file with DZ unpacker, Start LGMDP, Enter "Emergency mode" by pressing simultaneously lock, camera, call, "C" and power button, Connect phone In LGMDP select directory with unpacked DZ file, it will load usb boot files and modem, In option select "NONE" Press "Start". After You finish unlocking phone, do exactly same procedure, but this time with KU990i file. There is strong chance You'll need to flash only modem and nothing else. |
The Following User Says Thank You to legija For This Useful Post: |
05-24-2009, 20:31 | #20 (permalink) | |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | Quote:
Fouriuse gold unlock this phone without flashing when you add the same ?????? | |
05-24-2009, 20:54 | #22 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | I would need to buy one FG then . It will take 4 days to arive here, then fight with sniffing etc . . We will check tomorrow what can be done, i just realized that i can upgrade my normal ku990 sample to this new version and do whats needed. So maybe tomorow, maybe in few days. |
05-24-2009, 23:05 | #24 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | @LoveLess there is no problem with these files, u can use another unpacker better then dzip. or use original flasher LGMDP and check picture for use of DZ file format (click on DZ button and u will be able to choose DZ file). OPN-DE or OPN-GB contain most of european langage inside. br Last edited by BouRRi_GSM; 05-24-2009 at 23:13. |
05-25-2009, 11:31 | #25 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | there is a pb on software.. software and phone is incompatible..? is there a special software for ku990ig.? i tried on different pc but still same error... |
lg ct810 can unlock rocker | sarbi | Rocker Dongle (By Legija) | 1 | 11-17-2009 05:59 |
Problem Unlock KU990ig :::ANSWERED::: | Tequilas | PolarBox 3 | 1 | 06-13-2009 20:04 |
Moto EM28 Can unlock with my rocker ? | Dany | Rocker Dongle (By Legija) | 6 | 05-23-2009 02:42 |
Can rocker dongle unlock k1, z3, v3 without tp? | emicabher | Rocker Dongle (By Legija) | 9 | 01-05-2009 21:18 |
CAN ROCKER BOX UNLOCK/FLASH SE J100i ? | Unlocker_001 | Rocker Dongle (By Legija) | 3 | 06-14-2008 01:21 |
