Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Rocker Dongle (By Legija)
Old 05-03-2014, 19:20   #1 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Rocker service.
Here ' a series of procedures in this BOX ...
Unlock and Repair Sony J100a Imxx :
ODM_Rocker_v1.34
- Direct Imei
- Unlock after .
Unlock and Repair Sony K200 Imxx :
ODM_Rocker_v1.34
- IMEI ( After repair imei stays INCATIVA SIM )
- Unlock to remove it (All proeceso with the rocker . )
Unlock and Repair Sony T250 Imxx :
- Unlock_odm_120g
- Interface Setool3
- Run the program and rj45 cable com port you choose appropriate
- Choose the model and give r300 unlock , then we do the repairing ixxx
Unlock and Repair Sony R306 Imxx :
- Unlock_odm_120g
- Interface Setool3
Repairing Imxx Sony T303 and K330
- Use ODM_Unlock_v1.20g
- Interface Setool3
- For the T303 models , choose the R300 model , hit repair and ready imxx
- For the K330 model choose the T280 model , you give rapair imxx and ready
Unlock and Repair Sony R300 Imxx :
- You open the ODM_Unlock_v1.20g
- Interface Setool3
- Select Model R300
- Connect the cel with j100 rj45 cable
Unlock Motorola W175 , W230 , W231 , W233 and W270 with ODM Rocker v1.34 :
- Connect the phone with USB cable and battery SIN
- Click the Connect button
- Allow install drivers
- Start the software ODM Rocker
- Select the model
- Insert the battery
- Go to flap Unlock
- Click Unlock Net
- Ready
Repair IMXX Motorola W175 , W230 , W231 , W233 and W270 with ODM Rocker v1.34 :
- Select the model
- Go to flap Unlock
- Press ctrl + alt + i
- Write the stunt and give imxx repair .
- Ready
Imei and Unlock W218 ( Remember that camera runs out )
1. The program Open omd see 30,31 or 32
Two . Connect the cel then flash the flash special rocker support ( w208_w205_w209_imei_lp_. ..)
and then you repair the Imex , after you repair the eeprom it without disconnecting the cell) . runs once repair
imxx the cel is in English and repaired imxx ,
March . MSSBox With , you pass this flash W208_LP_0059_T03.molp you connect the computer as w208 .
phone in Spanish and the imxx repaired .
The Following User Says Thank You to gcceleghg For This Useful Post:
Page generated in 0.12212 seconds with 8 queries
