Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Rocker Dongle (By Legija)
Old 12-08-2008, 18:41   #1 (permalink)
Member: 177049
V9 change language
I tried to add S.Chinese (LP0024) to Moto V9, but got the JUMP Command Failed error message. My phone is
Phone/Platform: MOTORAZRV9
IMEI/SN: 35xxxxxxxxxxxxxx
Band: Dual Mode UMTS
Firmware version: R2633131-AS_U_A0.05.20R1
Language pack: LP_0055
FLEX: USEMERALD2100ORRTAUS3R263313100D
Phone code: 1234
Simlock: Not present
Bootcore: 90.00
Welcome dear user.
Motorocker version used: 2.25
Selected: Motorola V9, firmware: R263313
Current language: Rocker
New package file: S:\v9\LangPack\R263313_U_A0[1].03.09R_0024\R263313_U_A0.03.09R_0024.rsf
Clicked button: WRITE PACKAGE (&Write package)
Detected motorola interface: Motorola Flash
Full bootcore version: 011404FF02000790
Full firmware version: R2633131-AS_U_A0.05.20R1:USEMERALD2100ORRTAUS3R263313100D
In flash dialog selected: Flash only Language Pack
In flash dialog CONTINUE is clicked.
In flash dialog finally selected: Flash only Language Pack
Show WINDOW: Head = "Stage complete.", line1 = "Unplug cable, remove battery, insert battery, insert cable. Press PowerON shortly.", line2 = "Wait for phone to be detected (see below). Then Click Continue...", line3 = "", button1 = "", button2 = "&Continue"
Showed WINDOW modal result: 2
Wait for TCI started.
Established connection to: \\.\Motorola USB Modem
Checking connected interface: Motorola MCU Data Logger
Checking connected interface: Motorola Test Command
Waiting for flash interface init...
In flash dialog selected: Flash all contents of package file
In flash dialog finally selected: Flash all contents of package file
Uploading ramloader of version: 05.80
JUMP Command Failed
Old 12-08-2008, 20:04   #2 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
Bootloader in phone is 7.90 and ramloader is 5.80. You'll need newer flash file .
PS
Your phone is V9x, not the regular V9. This model has ORNAND flash, and language packs from regular V9 most probably will not work.
The Following User Says Thank You to legija For This Useful Post:
Old 12-09-2008, 07:52   #3 (permalink)
Member: 177049
Wher can I get S.Chinese Language file? I need this for toe make the V9 support Chinese Input.
Thanks
V9 Motorola Language Destinycz Motorola P2k 5 05-10-2010 22:33
V9 Italian Language pls help me Destinycz Motorola P2k 2 02-04-2010 11:22
V9 - Change frimware Vodafone eldoctor62 Motorola P2k 2 07-08-2009 19:39
Mofan.Mobi V9 Chinese language Pack V R263313-AS xiaotan Motorola P2k 7 01-01-2008 20:32
Can i change language in the 688 by changing new EEPROM file duyphuc Old Ericsson Phones & Sony Phones 1 06-17-1999 15:42
Page generated in 0.14189 seconds with 9 queries
