Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Rocker Dongle (By Legija)
Old 05-22-2008, 17:45   #1 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
W156i, W160, W175, W180 USB Drivers!
Here is USB Drivers installation procedure for Locosto USB based models :
  • Run "Motorola Driver Installer.exe" from "C:\Program Files\Common Files\Motorola Shared\MotPCSDrivers\" dir
  • Select "Clean only" and press start, wait untill its finished then close the software,
  • Open Control Panel, Add/Remove Programs and uninstall Motorola Drivers
  • Open Rocker Dongle Support, and navigate to ".. / .. / RockerDongle / Drivers / W156i_W160_W175_W180_USB_Drivers / dir.
  • Download and install http://rapidshare.com/files/10510313...a.9.0.msi.html
  • Restart PC
  • Connect above mentioned Motorola model with mini USB cable to pc, with battery removed
  • Insert battery, windows will detect "LOCOSTO" device and install drivers
  • Remove and insert battery again, and check in device manager for "Motorola Flash" device.
If You have done everything as described, You will have installed drivers correctly. Take note, these models will remain in flash mode for only 5 seconds, if no comunication started, phone will go to charging mode.
The Following 7 Users Say Thank You to sharaz191 For This Useful Post:
Old 05-23-2008, 23:32   #2 (permalink)
Member: 778593
Thanks Meter: 10
useful share brother thnx
Old 03-12-2009, 20:27   #3 (permalink)
Member: 953100
what is this ?
what is rocker dongle support ? it is hard ware or software ?
and if it is software tell me from i can download it ?
Old 03-17-2009, 19:03   #4 (permalink)
Member: 46350
Thanks Meter: 885
Check here:
Updated ! EM325, W156i, W160, W175, W180, W230, W270, W388, W396, W450, ZN200
Old 04-21-2012, 09:58   #5 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 9,868
Here Drivers USB Motorola v3.7.rar - 4shared.com - online file sharing and storage - download - Pingazo
Old 04-26-2014, 23:10   #6 (permalink)
Member: 790437
Thanks Meter: 35
support for windows 7
Old 11-14-2014, 15:53   #7 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
What about new drivers - supports win7x64 ?
Need Haier c5000 usb driver monto Various CDMA/TDMA Cell Phones 5 06-17-2013 09:28
Updated ! EM325, W156i, W160, W175, W180, W230, W270, W388, W396, W450, ZN200 legija Rocker Dongle (By Legija) 17 05-01-2009 21:16
Need w175/w180 usb driver mgcelulares Rocker Dongle (By Legija) 9 04-22-2009 16:14
Driver W175 w180 here Gabiunlock Motorola ODM 9 04-10-2009 01:24
Page generated in 0.31747 seconds with 8 queries
