Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > TGT Products
Old 07-12-2008, 02:44   #1 (permalink)
Member: 503304
Sonork: 100.1585733
Thanks Meter: 34
Please help me 5310 bad software
I run this phone by TGT SOFTWARE SETUP 4.0. it run ok but my phone is bad software .I post this piture ask Suport TGT help.
http://www.4shared.com/file/54825341..._software.html
I am very reply from support TGT
Thank you very much!
Old 07-13-2008, 00:42   #2 (permalink)
turkgsmteam's Avatar
Member: 501877
Thanks Meter: 495
first fullflash write phone,and unlock ,reset ok you see your phone screen bad software phone off
open TGT BAD SOFTWARE press recoonect phone connect ok..
cpu mtk6225
- only pasword....LIFT OTHER MARKS and press clear and open database file TGTSOFTdatabase_MT6225_BADSOFT ok clr finished ok
tested ok
br
turksmteam
Old 07-13-2008, 11:07   #3 (permalink)
FasGsm's Avatar
Member: 283725
Sonork: 100.1584053
Thanks Meter: 1,927
If ur mobile have this file this file version X225B_PCB01_GPRS_MT6225_S00.BIN
then u can flash ur mobile with this file :
http://www.4shared.com/file/52753659...r_bad_soft.htm
But ist make backup before using this file.
Old 08-17-2008, 00:06   #4 (permalink)
Member: 501877
Thanks Meter: 495
Originally Posted by vijeeshkannur View Post
/vbb/showthread...310+bad&page=5
infinty v2.56 repaired badsoftware successfully
model :jinpeng v9188
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] v2.56
S/N: ***x:***x
Wait...
Device: Autodetect 6205-6227 NOR
Done
COM38 [VCP0] selected
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: repair "bad software"
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:7003:000A
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: SINGLE25_06B_PCB01_GPRS_MT6225_S00.J800_V1_00.BIN
ver. sw2: J800_V1.00, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting firmware protection...
detecting firmware structure #8...
done
detecting firmware structure #9...
done
detecting firmware protection failed
Finished, time used: 47 sec
Remove/Install battery now !
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
Connecting, wait...
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: J800_V1.00
Version: Single25_06B_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 13579024681122
warning: current phone imei is wrong !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #6 (mode-1)...
done
163 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 12 sec
heres the log
THANKS INFINITY
UR THE KING OF CHINESE PHONES
TGT plus mtk 6225 WITH DO FOR ONLY password MARK
mtk6225 check click pasword mark
mtk6226 an old cpu check click all phonebook,camera setting vs all mark..
tgt all cpu bad software rephaır 1 sec %100 ok
tgt plus bad software all mtk solulation best
Old 08-18-2008, 03:39   #5 (permalink)
Member: 503304
Sonork: 100.1585733
Thanks Meter: 34
why box infinity was solve problem bad software , TGT dongle wasn't solve this problem Although i was test 10 phone by Tgt but no solve.
Old 08-18-2008, 18:58   #6 (permalink)
FasGsm's Avatar
Member: 283725
Sonork: 100.1584053
Thanks Meter: 1,927
well v not know y this happins only to u perhpas u r doing some thing wrong .as ur problem solved with infinity it is good for u some times u can do one set software on one box and some time on another in gsm feild nothing is complete.
As ur problem solved thread is closed now.
please help me to unlock N97 [ANSWERED] longgiang81 Genie Universal 2 03-30-2010 09:18
6210n unlock please help me please AVCITHETCNC MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-29-2010 18:21
d500 pbm verif batery temp pbm please help me amirgsmbejaia Samsung Hardware Repair 0 03-29-2010 15:33
Page generated in 0.24545 seconds with 11 queries
