03-21-2009, 16:41 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: nigeria Age: 44
Member: 176997 Status: Offline Thanks Meter: 5 | extra work from vepro surpport |
03-22-2009, 07:27 | #2 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
Bro buy other box but not VE_PRO or Xintel_Box bcoz its just dead box cannot even detect any or spydefine,,,,buy like SPIDERMAN,,, BR | |
03-23-2009, 04:53 | #4 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | Quote:
i have much experience with my xintel pininder and usually i give prefrence to use xintel as pinfinder then as a interface using infinty chinease mircle. all thing are based on your experince. in 99% cases i found no problems using it as pinfinder.rest of 1 % counts for hard ware troubles. there is a cable in xintel that is with out jack and it is opemn cable with 12 wires, this is the most importnt cable, do you know its use??? only xintel stops detecting pinout when the + and -ve powers comming out of cables re broken. to identify u can use 2 ways. manual: just attach both + nd _ve together and observe for the production of a little spark, if spark not produced its mean +ve or -ve tracks are broken and can be repaired very eaasily??when have problem i will post some video mnual for u. 2ndly, u cn use multivoltmetet on dc to check the voltge of these wires. only thing is infinity team is much ahead in support and support server, a very rapid updates, onthe other hand xintel to vpreo to vebox and so on keep on changing its some hard ware modiication but no remarkable advancement in chinease miracle softwre. anyway i love infinity team, i love xintel box my old companion. br hmid | |
03-23-2009, 06:57 | #5 (permalink) | |
03-23-2009, 07:30 | #6 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | ok welcome; 1. suppose, u are working with a chin phone that is having mtk cpu. 2.u have vpro/xintel as an interface. 3. conncet vpro and dongel with pc and start the xintel main working software 2.5 to find out pinouts. 4. for that pupose u select the cable according to the pins in the phone jack. suppose u scan define sucessfully and then u set pess set define.keep on pressinf power button/key. now u check the comport which is being used with xintel(can be seen on the top of xintel software) 5. now u start ininitybox shell and select chinese miracle nd select mt62xx bsed models and press run. 6.now chinease miracle software will start. 7.now u change the comport numberom the comport window of chinease mircle software main first page(that is disp[alyed when u open it)while holding the power key and have selected xintel as an interfaace using xintel cable. now u can start format or flash or unlock the mobile. this is the way to use xintel cbles and xintel to work with infinity chinease mircle soft. any other question lso welcome. br hamid |
03-23-2009, 08:24 | #7 (permalink) |
Member: 214340 Status: Offline Thanks Meter: 906 | Bro Im trying to format LG_KG195 but it cannot spy c the pic http://g.imagehost.org/0478/LG_KG195.jpg thanx for gr8 help BR |
03-23-2009, 14:06 | #8 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | why u r not using xintel new version 2.5? to detect it use cable L5A. 2ndly it is usually detected as follows> attach cable ,keep on pressing power key and in the window select chip:mtk and then press auto spy define, when pinout detected, in the set define window clear all the rx, tx, gnd, vpp and preesing the power key preess internl define and the open mtk5.2 or infinity soft and do as required. br hamid |
03-24-2009, 08:26 | #9 (permalink) | |
Bro I'm using ver_2.50 now i tell u that i acted upon ur advice n it detected successfully thanx for that help ,,,but BRo it could read info or format nither with INIFINITY nor with Xintel_Box,,,more help needed,,, BR | |
03-24-2009, 10:40 | #10 (permalink) |
Member: 214340 Status: Offline Thanks Meter: 906 | SUCCESSFULLY_FORMATED_MY_LG_KG_195 Bro thanx alot for such gr8 help NOW I MUST say Xintel_BOX is gr8 BOX for chinese models,,, her is the logs PL2303 USB To COM9 Found VE-Dongles ... connect to VE-Dongles! Ve-Dongles sn:068AEC4D-020011F8 VE-Dongles Ver.:V2.3 Datetime:2007-10 VT-Dongles data success! ---------------- READ INFO ---------- open comport:COM9 please turnon your phone ,until connect success(press F4 Abort). connect to Phone. CPU model :6226 ( HW_VER: 8A02 ) LG_KG_195 download Boot ... boot File Ver.:04.02 NOR flash model :[TOSHIBA] TV00578002DABD NOR flash size:01000000 (16.0M) NOR flash ID code :00980049 (00000000) [92] NAND flash model :[TOSHIBA] TC58NWM9S3B NAND flash size:04000000 (64.0M) NAND flash ID code :00800095 (00000000) [65] Int.RAM size:00047000 (0.284M) Ext.RAM size:00400000 (4.0M) Bootloader in [NOR] flash Read flash information operation done! ---------------- READ_FLASH ------------ open comport:COM9 please turnon your phone ,until connect success(press F4 Abort). connect to Phone. CPU model :6226 ( HW_VER: 8A02 ) download Boot ... boot File Ver.:04.02 NOR flash model :[TOSHIBA] TV00578002DABD NOR flash size:01000000 (16.0M) NOR flash ID code :00980049 (00000000) [92] NAND flash model :[TOSHIBA] TC58NWM9S3B NAND flash size:04000000 (64.0M) NAND flash ID code :00800095 (00000000) [65] Int.RAM size:00047000 (0.284M) Ext.RAM size:00400000 (4.0M) Bootloader in [NOR] flash Read flash information operation done! baud set:921600 start address :00000000 operation size:01000000 Read flash... operation done. elapse:3 min55 sec speed :69 KB/ sec File save to:C:\Documents and Settings\XPPRESP3\My Documents\LG_KG_195_MT_6226.bin Phone Lock Password:0000 ---------------- FORMAT_FLASH ---------------- open comport:COM9 please turnon your phone ,until connect success(press F4 Abort). connect to Phone. CPU model :6226 ( HW_VER: 8A02 ) download Boot ... boot File Ver.:04.02 NOR flash model :[TOSHIBA] TV00578002DABD NOR flash size:01000000 (16.0M) NOR flash ID code :00980049 (00000000) [92] NAND flash model :[TOSHIBA] TC58NWM9S3B NAND flash size:04000000 (64.0M) NAND flash ID code :00800095 (00000000) [65] Int.RAM size:00047000 (0.284M) Ext.RAM size:00400000 (4.0M) Bootloader in [NOR] flash Read flash information operation done! Auto format address £؛00E00000 operation len£؛00200000 NOR (auto) format operation ... >>operation done. BR |
03-27-2009, 05:41 | #11 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | very good, nice to see all logs. i am here to help for any other matter, on some other day i will write a tutorial for sets which are difficult to detects with xintel like trend 7..... series. br hamid |
03-27-2009, 05:45 | #12 (permalink) | |
as i am using xintel 2.50 and i am able to format and read using xintel soft and making it interface for infinity also. br hamid | |
03-27-2009, 08:52 | #13 (permalink) | |
thanx for gr8 help BR | |
03-27-2009, 11:10 | #14 (permalink) | |
Member: 176997 Status: Offline Thanks Meter: 5 | Quote:
Jobs in India, work from home online jobs, Form Filling Jobs From Home, Form Filling | pradeep101 | Job Opportunities / Vacancies | 0 | 02-01-2010 08:04 |
Form Filling Jobs From Home, Form Filling Job, Form Filling Work from Home, Online Fo | pradeep101 | Motorola P2K (USB-Smart) | 0 | 01-16-2010 08:26 |
Extra money from your opinion- Possible? | fahmohd | Off Topic Zone | 0 | 08-29-2006 18:05 |
