09-04-2008, 03:15 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 47
Member: 142191 Status: Offline Sonork: 100.1589775 Thanks Meter: 297 | Is there anyway to use vepro with rj45 cable n how. is there any way to use vepro with rj45 cable as we use in infinity...because sometime vepro cant find correct pinouts (mostly sigmatel cases)..then we can attact direct rx tx gnd which was on board..plzz anyone tell the solution.. |
09-06-2008, 05:38 | #4 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | Bonnie_xuan you are totally wrong.seem u have never worked with china mobiles.... right answer is cut any jaf rj45 cable.use as under Red coloured cables is rx ie pin no 2 from left for my cable green tx pin no 3 from left side black gnd pin no 9 from left (while locating number of pins, hold it in the same way , direction u are inserting the cable in the box. understand) br hamid |
09-11-2008, 13:32 | #7 (permalink) |
Member: 142191 Status: Offline Sonork: 100.1589775 Thanks Meter: 297 | no support in this section from ve...plz reply supporter...if there is no rx tx define on charging jeck how we format the set...???? |
09-12-2008, 15:02 | #10 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | use this pinouts of rj45 connector. 100%worked. http://www.freeimagehosting.net/uploads/5c65eb5249.jpg |
09-14-2008, 20:39 | #12 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | Quote:
No confusions, no difficulties>>>> Just get a "RJ45 Female" connector and connect any 8 wires of "RJ48 Cable" which is shipped with your vepro box. Now your RJ48 connector is converted to RJ45. Tested by me, I am using Infinity Box cables through this RJ45 converter. BEST OF LUCK. yawarniazi | |
09-18-2008, 04:54 | #15 (permalink) |
Member: 142191 Status: Offline Sonork: 100.1589775 Thanks Meter: 297 | plz supporter give RJ45 pinouts definition for vepro box as spiderman box has discribed for there box.. http://forum.gsmhosting.com/vbb/showthread.php?t=483651 |
Is there anyway to unlock the C139 trackfone with no testpoints | etimoult | Infinity-Box | 0 | 06-05-2008 18:11 |
is there anyway to fix a60 buzz problem with martech? | ddhorn | Martech CLIP / Box / Key | 3 | 12-08-2006 15:51 |
Is there anyway to have more txt messages in the inbox | stukachu | Sharp | 0 | 11-27-2003 12:47 |
is there anyway to edit call duration time on8210? | excespeace | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-27-2002 22:05 |
Is there anyway to reset the user lock on GD93? | NUGSM | Panasonic | 1 | 10-03-2001 13:34 |
