Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Ve Box > VE-PRO BOX
Old 06-18-2008, 20:37   #1 (permalink)
unlock_solution's Avatar
Member: 478791
Thanks Meter: 52
vepro canot find pinoouts sigmatel s 1 s 2 s3
hi all vepro can not find pinouts sigmatel s 1 s2 s3 i tried many phones but no sucess plz tell where i am wrong ........or i canot use vepro with infinity ............always error using latest
wbr
varun
Old 06-19-2008, 03:18   #2 (permalink)
Member: 731023
Thanks Meter: 59
what is the cpu of the phones ? and what error it shows ?
you may do as the manual shows
Old 06-27-2008, 08:30   #3 (permalink)
Member: 478791
Thanks Meter: 52
cpu is mt 6225 and i canot use vepro with infinity when i format with infinity it says read error ............wbr varun
Old 06-27-2008, 08:45   #4 (permalink)
Crazy Poster
Member: 747436
Sonork: 1580536
Thanks Meter: 7
you can use vepro II box or supper star box to pinfind .
www.hengwei168.com
Old 07-18-2008, 13:57   #5 (permalink)
rk_grover77's Avatar
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
yes this is a big problem with vepro box...i hv to open mobile to attach rx tx then format with infinity.
Old 08-02-2008, 20:44   #6 (permalink)
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
where is support..no one is answering....vepro finding pinouts 4 sigmatel yet giving initial error while formating.also infinity cant format on these pinouts..may be cant find actual pinouts.....supporter plz solve that problem.
Old 08-03-2008, 03:10   #7 (permalink)
Member: 811759
Thanks Meter: 14
Can you show us more detail? Or give us a picture, so that we can know exactly what problem you are facing, ok?
Old 08-04-2008, 10:46   #8 (permalink)
sahil00150's Avatar
Member: 624567
Thanks Meter: 256
ve-pro detects sigmatel s3........
use cable xtl8a xtl12b
pinouts
2-Vcc
5-Txd
7-Gnd
8-Rxd
11-Gnd
The Following 2 Users Say Thank You to sahil00150 For This Useful Post:
Old 08-29-2008, 18:01   #9 (permalink)
shailccna's Avatar
Member: 350232
Thanks Meter: 207
yes it detects by this cable but can not format phone by infinity or vipro .plz product supporter try to solve problem
Old 08-31-2008, 16:18   #10 (permalink)
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
yes this is what i want to say.."it detects by this cable but can not format phone by infinity or vipro".
Old 08-31-2008, 16:25   #11 (permalink)
ARS.Rehman's Avatar
Member: 491455
Sonork: On My LAB
Thanks Meter: 296
What is mobile condition ?
If Mobile is dead then heat on flash IC. Then format mobile.
Gd luck.
Old 09-11-2008, 13:33   #12 (permalink)
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
no support in this section from ve...plz reply supporter...if there is no rx tx define on charging jeck how we format the set...????
mostly we r facing problem in sigmtel's set..becouse vepro defines incorrect rx tx in these sets...
Old 09-12-2008, 02:44   #13 (permalink)
Member: 811759
Thanks Meter: 14
If shows initial error while format, maybe, it is not the correct pin out, so, you have to choose the “Repeat Scan” and scan again.
Old 09-12-2008, 03:41   #14 (permalink)
Member: 142191
Sonork: 100.1589775
Thanks Meter: 297
yes it is clear that it is not finding correct pinouts as pinouts finding by pinfinder is different from that.....i hv tried all thing like including repeat scan as in video course..if anyoe hv successfully format s3 with vepro plz give screenshots..thx..
Old 09-12-2008, 05:58   #15 (permalink)
Member: 278546
Thanks Meter: 145
i format so many sigmatel models successfully. first set spytime to 500ms if , rx.tx not detected then try in spytime 1000ms, both attempts in normal mode.remember first try in spytime 500ms then 1000ms .post me result, one more important was hold power button untilll finish format if not succes use battery for format after spy success
The Following User Says Thank You to yalamandareddy For This Useful Post:
Nokia 6300 canot find any usable backup file mobile-phone-service BB5BOX 7 03-20-2008 17:17
Help me to find driver for MS bluetooth transceiver 2.0 gaiver173 Bluetooth-Software 2 06-26-2006 01:34
the system canot find the file specified Nasmi VygisToolbox 3 01-16-2006 17:49
did some one find the way to run pemaster 2.17c? infogsm Motorola Old Legacy (EMMI) 8 08-28-2003 15:03
Page generated in 0.20697 seconds with 10 queries
