spd flasher, phone connecting problem hello ve-king team,i got a problem connecting phone to spd flasher, it says: Quote:
But here, what should i do? with that instruction, i re-plug the cable to phone n also re-plug power clip, stilll won't connect :confused: thx d answer,:D |
give me the cpu details |
it is spreadtrum sc6600r1-2576 :) |
bro this phone requires usbscan use that scan mode and give me your results |
usb scan.. then i need to use usb cable from phone sales package? i see, i should ask it's usb cable from user first, later i post the result here.. thk Butamanya, :D |
oh seems support team is sleeping |
just use one of those cables whi图16 (4) When scan define succeed,it will show “continue to scan boot or not”,meanwhile please check whether the USB comport is there or not.About 5 seconds,if USB comport disappeard,so need to click “YES”,then go on to scan boot. after scan success you can run soft and read and your phone details remember to make backup |
just use one cables whict came with your box and fits into your box remember to thank me |
oiii, wake up!!! ok, Butamanya, thx giving me solution.. got to try it :) |
i tried this: Quote:
after you scan succeded, have it turn green on the top right corner of the mainsoft? if yes ,no need to scan boot |
ok thank for share bleh |
