Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Ve Box > VE-KING
Old 04-29-2009, 12:38   #1 (permalink)
ru_dee's Avatar
Member: 911645
Question spd flasher, phone connecting problem
hello ve-king team,i got a problem connecting phone to spd flasher, it says:
connect mobile to box ,push cable to phone.(F4 exit)
>>connect fail, timeout exit !
get used to use mtk flasher and connect the phone by holding its pwr on
But here, what should i do?
with that instruction, i re-plug the cable to phone n also re-plug power clip, stilll won't connect
thx d answer,
Old 04-30-2009, 10:18   #2 (permalink)
Member: 924171
Sonork: 1615127:bamu
give me the cpu details
Old 05-01-2009, 02:58   #3 (permalink)
ru_dee's Avatar
Member: 911645
it is spreadtrum sc6600r1-2576
Old 05-01-2009, 09:22   #4 (permalink)
Member: 924171
bro this phone requires usbscan use that scan mode and give me your results
Old 05-01-2009, 10:48   #5 (permalink)
ru_dee's Avatar
Member: 911645
usb scan..
then i need to use usb cable from phone sales package?
i see, i should ask it's usb cable from user first, later i post the result here..
thk Butamanya,
Old 05-02-2009, 05:13   #6 (permalink)
Member: 597784
oh seems support team is sleeping
Old 05-02-2009, 10:12   #7 (permalink)
Member: 924171
just use one of those cables whi图16
(4) When scan define succeed,it will show “continue to scan boot or not”,meanwhile please check whether the USB comport is there or not.About 5 seconds,if USB comport disappeard,so need to click “YES”,then go on to scan boot. after scan success you can run soft and read and your phone details remember to make backup
Old 05-02-2009, 10:18   #8 (permalink)
Member: 924171
just use one cables whict came with your box and fits into your box remember to thank me
The Following User Says Thank You to butamanya For This Useful Post:
Old 05-04-2009, 02:46   #9 (permalink)
ru_dee's Avatar
Member: 911645
Yea, no answer from support team, maybe they're still sleeping
oiii, wake up!!!
ok, Butamanya, thx giving me solution.. got to try it
Old 05-04-2009, 13:07   #10 (permalink)
ru_dee's Avatar
Member: 911645
i tried this:
1. Run Ve-king s.w and then go to SCAN TAB
2. In Scan Tab, chose USB SCAN
3. Change to 6600M CPU
4. Select Correct Pin
5. Clip Negatif/Black Cable to Battery (-), then click scan Power.
s.w will find GND position.
6. Remove Clip and put on battery. Then Press SCAN USB.
s.w will find USBDM- and USBDP+
7. Move to tab DEFINE
8. If u want save the setting, in DEFINE TAB, Chose 18USB.
9. Write your model phone
10. Press save. So next time if got same phone dont need to find USB pin out again.
11. Then Press SET Define. Then we can use the s.w
but when set define succeeded, there was no option “continue to scan boot or not, and still can't connect to spd flasher
Old 05-06-2009, 03:54   #11 (permalink)
Crazy Poster
Member: 901121
after you scan succeded, have it turn green on the top right corner of the mainsoft? if yes ,no need to scan boot
Old 08-01-2009, 09:19   #12 (permalink)
Crazy Poster
Member: 722281
ok thank for share bleh
SPD .... connection problem with pinfinder this may face CPF DONGLE users..!!!!! Sudan-Mobiles CPF-Dongle 5 03-06-2009 04:05
Motorola Phone Connectivity Problems in ET-BoX nonu_don ET-BoX 22 01-01-2009 08:10
about spd 6600M/E/H/R cpu NAND Flash ic phone software problem repair ways gsmfans CPF-BOX Ⅱ 0 11-05-2008 10:59
solution for Motorola Phone Connectivity Problems in ET-BoX sneha ET-BoX 1 10-04-2008 08:26
chinese phone connection problem surajrasaq Chinese Miracle & PinFinder 1 08-10-2007 21:58
Page generated in 2.76298 seconds with 11 queries
