Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Ve Box > VE-KING
Old 07-26-2008, 05:29   #1 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
unable to connect spd
pls look here and tellme......what wrong ....pin define ok but while connection time out
Old 07-26-2008, 05:52   #2 (permalink)
Member: 493553
Hi Bro, try use this trick, working 100%..........
1. Run Ve-king s.w and then go to SCAN TAB
2. In Scan Tab, chose USB SCAN
3. Change to 6600M CPU
4. Select Correct Pin
5. Clip Negatif/Black Cable to Battery (-), then click scan Power.
s.w will find GND position.
6. Remove Clip and put on battery. Then Press SCAN USB.
s.w will find USBDM- and USBDP+
7. Move to tab DEFINE
8. If u want save the setting, in DEFINE TAB, Chose 18USB.
9. Write your model phone
10. Press save. So next time if got same phone dont need to find USB pinout again.
11. Then Press SET Define. Then we can use the s.w
Old 07-26-2008, 14:37   #3 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Above ..procedure I Followed But No Pin Out I Waited 30minutes But No Pin Define
Old 07-27-2008, 03:11   #4 (permalink)
Member: 811759
Try to use the newest VE-SPD V3.0 version
Old 08-09-2008, 20:07   #5 (permalink)
Member: 39948
What spd cpu that you dealing with??
6600D or 6600M/R
Br.
Old 08-10-2008, 04:00   #6 (permalink)
suwaree's Avatar
Member: 572409
ZTC C2000 SPD6600M/R VE GOOD BOX THAILAND
Unable to connect to phone-C330 sjakie UniMoto 2 01-13-2005 19:00
NEW C550 version & UNABLE TO CONNECT TO PHONE ??? Genius UniMoto 7 01-02-2005 11:54
MYX1 error while flashing! now unable to connect the phone to the soft??? AE177 SagMaster Team OLD Products 7 09-20-2004 21:14
LG7050 Unable to connect to phone msa Griffin 8 05-04-2004 18:23
r320sc unable to connect to mobile network ranenitin1 Old Ericsson Phones & Sony Phones 10 07-03-2003 12:22
Page generated in 1.04675 seconds with 13 queries
