Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > HTC > HTC android based
HTC android based General HTC Android phones discussion, firmwares, solution, root, help
Old 07-04-2009, 15:09   #1 (permalink)
PhoneCareCenter's Avatar
Member: 574123
Sonork: 100.1581804
Bypass T-Mobile G1 Google Activation by PhoneCareCenter
This Guide is for Customers who got Unlock Code but stuck with Google Activation Screen.
You must have either RC29 or earlier, or Modded RC30.(RC29 is US firmware, RC7 is UK firmware) If U have higher
Versions like (RC33 US firmware or RC8 UK firmware) then u Need to Downgrade.
To Check Firmware Version Do the following without Sim
<enter>reboot<enter>
If Phone Reboots then u have version RC29 or Lower, Skip Upgrading/Flashing Procedure.
(Flash your phone to RC29/RC7 or lower to be able to Exploit Root Access)
Step 1- Format the SD card to FAT32 (Make Sure of this, otherwise it wont Work.
Step 2- Unzip the RC29 or RC7 image file (DREAIMG.nbh) to the SD card & Rename it to (DREAIMG.NBH)
Step 3- Switch Off the Device then Insert the SD card.
Step 4- Now U have to Put your G1 in BootLoader Mode (Hold Down Camera Button, and press Power Button) DO NOT DO ANYTHING TO INTERRUPT THIS PROCESS.
Step 5- Press Power button to Start Upgrade/Flashing Procedure.
Step 6- Once its done, Reboot your G1.
For Those with RC29 or Earlier Versions, Just Follow The Below Guide.
You must have ADB installed on your Computer (Extract to C: Drive), Download & Install the USB drivers. U can Manually Install when Computer Asks for the Drivers once U Connect your G1.
1- Plug your G1 & Install Drivers.
2- Without Sim Card in Your G1, <enter>setprop persist.service.adb.enable 1<enter> Even though u dont see what u typing, but u are actually executing a Command on your G1 to Enable USB Debugging in Settings.
3- Once u Execute that Command USB Drivers will be Installed again, but this time will be recognised as ADB Interface.
4- Click Start>Run>cmd> to Command Prompt
5- Type c:\adb devices (If your Device is Connected u will see it)
6- Restart your G1 but now With Sim, to see the Activation Screen then Plug USB Cable & Type c:\adb devices (to make sure u are connected)
7- Type c:\adb shell (U will see a $ sign) Just Copy & Paste this into Command Prompt (am start -a android.intent.action.MAIN -n com.android.settings/.Settings) The Settings Screen will Appear, now Switch on Wi-Fi & Connect to the Internet.
8- Now u can either Login with your Existing or Create New Account with Google.
PhoneCareCenter
Monrovia-Liberia
McnPro Team
Good Luck
"Get your Codes from allGSMUnlock Server, Contact AtrixJ (MY GOOD FRIEND)for Credits, Contact me if u have any problems with this Guide & Pls no $tupid Talk like its Not working. Tested on my Personal Phone like 10 times before I made this Guide. Took me 5 hours the First Time, now takes less than 10minutes."
The Following 5 Users Say Thank You to PhoneCareCenter For This Useful Post:
Old 07-25-2009, 17:47   #2 (permalink)
Member: 1082565
I have d/l & installed all usb drivers. in device manager i find HTC DREAM COMPOSITEADB INTERFACE. in command when i type adb devices this is what i get - C:\Documents and Settings\Babe Murphy>adb devices
'adb' is not recognized as an internal or external command
operable program or batch file. plz help
The Following User Says Thank You to deedee307 For This Useful Post:
Old 07-25-2009, 17:53   #3 (permalink)
Member: 1082565
I have d/l extracted files& installed all usb drivers. in device manager i find HTC DREAM COMPOSITEADB INTERFACE & have updated driver, in command when i type adb devices this is what i get - C:\Documents and Settings\Babe Murphy>adb devices
operable program or batch file. plz help btw i have windows
Old 07-28-2009, 14:01   #4 (permalink)
Member: 574123
Sonork: 100.1581804
@deedee307
U are not giving the right Command: C:\Documents and Settings\Babe Murphy>adb devices
It should be: C:\adb devices
Good Luck
Old 07-30-2009, 00:08   #5 (permalink)
Member: 1082565
Red face
Originally Posted by PhoneCareCenter View Post
@deedee307
Good Luck
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Dee>adb devices
'adb' is not recognized as an internal or external command,
C:\Documents and Settings\Dee>cd..
C:\Documents and Settings>cd..
C:\>adb
C:\>adb devices
C:\>C:\adb devices
'C:\adb' is not recognized as an internal or external command,
C:\>
none of that works
Old 07-30-2009, 00:30   #6 (permalink)
Member: 382144
i belief we do not this, too hard
almost all gsm service provider has gprs
use gprs to creat google account the phone work fine
Old 07-30-2009, 02:20   #7 (permalink)
Member: 574123
Sonork: 100.1581804
@deedee307
Did u see how I typed it?? Did I include >?? No.... Follow the Instructions Carefully.. Now for the Second Time when u Open CMD Prompt type this : Microsoft Windows XP [Version 5.1.2600]
C:\Documents and Settings\Dee>C:\adb devices
By the way, did u Download & Extract (ADB) to C: Drive??
Good Luck
Old 07-30-2009, 02:22   #8 (permalink)
Member: 574123
Sonork: 100.1581804
@abbeylincon
Not all Countries in the World Have GPRS working with the G1, so this is very Usefull for them.....
Old 07-30-2009, 03:35   #9 (permalink)
Member: 1082565
@deedee307
Good Luck
LOL @ did i include >??... No
But i did not extract ADB to C: Drive, now that i have done that when i type adb devices in command i get
* daemon not running. starting it now *
* daemon started successfully *
List of devices attached
HT843GZ34558 device
C:\Documents and Settings\Dee>C:\adb shell
$ am start -a android.intent.action.MAIN -n com.android.settings/.Settings
Starting: Intent { action=android.intent.action.MAIN comp={com.android.settings/
com.android.settings.Settings} }
now i can connect 2 wifi thank u so much 4 ure help
Old 07-30-2009, 05:01   #10 (permalink)
Member: 611157
pls explain more about how to check the firmware version
Old 07-30-2009, 13:58   #11 (permalink)
Member: 574123
Sonork: 100.1581804
@deedee307
U r very much Welcome.
@jhongtech
In first Post, I explained that. Just Press Enter on Keyboard, type REBOOT, then Press Enter........
Good Luck
Old 08-02-2009, 15:02   #12 (permalink)
Member: 368732
Thank You very much But
I don't have Tmobile sim card
error (This could be a temporary problem)
How to do Please Help
Old 08-03-2009, 13:26   #13 (permalink)
Member: 574123
Sonork: 100.1581804
@chinhi
I never said anything about T-Mobile Sim Card, pls be more Specific....
Good Luck
Old 09-05-2009, 21:56   #14 (permalink)
Member: 548661
Nice job it worked!!!!
Old 09-16-2009, 04:50   #15 (permalink)
Member: 1120598
i try typin in the <enter>setprop thing and it didnt do nuttin wat can i do?
Bypass T-Mobile G1 Google Activation by PhoneCareCenter PhoneCareCenter HTC android based 242 05-13-2013 12:43
Bypass T-MOBILE MYTOUCH GOOGLE ACTIVATION SCREEN kdaviator Android based Phones / Tablets 8 11-01-2011 14:29
Bypass T-Mobile G1 Google Activation by PhoneCareCenter PhoneCareCenter allGSMunlock MultiOnline Remote Server 49 08-20-2010 11:44
Compatible USB Battery Cradle for T mobile HTC Dream G1 Google Android Phone IPMART ipmart WebShop 0 05-08-2009 01:50
[22-10-08] T-Mobile G1 (Android) supported by IMEI UnlockBase.com UnlockBase 1 10-24-2008 22:26
Page generated in 0.38694 seconds with 12 queries
